Supermarine Sea Otter Mk.I "WWII Service" 1:72 Special Hobby (72429)
Julien
The Se Otter was developed by Supermarine from its famous predecessor the Walrus. As a longer range Sea Plane the main difference is the arrangement of the engine from the pusher as seen on the Walrus to the more conventional puller. The Sea Otter was the last Sea Plane to be designed by Supermarine, and the last biplane to enter service with the RAF & FAA. Despite the prototype flying in 1938 it was not ordered until 1942 with only 292 of the nearly 700 ordered being produced before the end of WWII. Many aircraft were sold and used in civilian use post WWII with conversions to passenger and freight transport for remote locations being done.
The Kit
This is a re-release of the Azur Ffrom kit originally from 2011. The kit arrives on 4 spures, a clear spurue, A sheet of PE, a bag of resin parts and a cockpit film.  Construction starts with the interior. Two seats complete with PE belts are made up these are fitted to the cabin floor along with all of the internal bulkheads. The instrument panel with its POE part and film goes in. The two rear windows go into the fuselage halves from the inside and then the fuselage can be closed up around the cabin interior.
Now the tailplanes and rudder are fitted to the completed fuselage before work can start on the wings. Both the upper and lower wings are 3 part. There is a single upper with left & right lowers. The engine pod fits under the top with with the engine, cowl, and exhaust being in resin. The lower wing is attached to the main fuselage and then the upper wing is fixed on with all of the struts. There are shallow locating points for all the struts. Under the lower wing the stabilising floats can be fitted along with a pair of resin & PE bomb racks.  At the rear the tail wheel is added and the main wheels are also built up ad added. To finish up PE & wire (not supplied) hand rails are fitted to the front and rear fuselage. These were used in SAR operations.  A full rigging diagram is provided if the modeller wishes to rig the finished aircraft.
Decals
Three options are provided on the decal sheet, these look to have been made in house, they look to be in register with no issues.:
  • JN106 - No. 1701 Sqn FAA, Maryborough Australia 1945
  • JM744, No.771 Sqn FAA, RNAS Hatson (HMS Sparrowhawk) Orkney Islands, 1944
  • JM808, No.712 Sqn FAA, RNAS Hatson (HMS Sparrowhawk) Orkney Islands, 1944/45
Conclusion
This is a good kit of an overlooked aircraft. The fabric effects are well represented without being overscale and there is a fair amount of detail. With some care this will build up into a good looking model. Recommended.
Review sample courtesy of
  • 7 months later...
