Julien Posted November 12, 2020 Share Posted November 12, 2020 Miles M.9 Master Mk.I (48033) 1:48 Dora Wings via Albion Alloys The M.9 Master was a conventional low wing monoplane two seat trainer produced by Miles Aircraft Ltd for the RAF and FAA. The Air Ministry had produced specification T.6/36 in the mid 1930s for a new trainer. This was won by the DH.30 Don, however this aircraft in the end proved unsuitable. The RAF was forced to look elsewhere and Miles developed the Master from its earlier proposed trainer the Kestrel. The Air Ministry ordered 500 for the training role. The master used initially a Rolls Royce Kestrel engine which have it a speed of nearly 300 mph, comparable with the fighters of the day. With a student in front and the instructor behind the read cockpit was a full 12 inches higher. Other aids to training were a reinforced nose area to cope with nose overs and a tail design used to aid stall recovery. While the aircraft was fitted with a gunsight and a single for training, provision was made for an M24 Master Fighter with 8 guns to function as an emergency fighter. In the end over 3000 aircraft were built however none have survived. Aircraft were diverted to support various allies. These included, 426 aircraft to the South African Air Force, nine to the USAAF (Mainly for use as hacks), 23 to the Royal Egyptian Air Force, 23 to Turkish Air Force, two to Portuguese Air Force, and fourteen to the Irish Air Corps. The Kit The kit arrives on 5 plastic sprues, a clear sprue, a sheet of PE, canopy masks (not shown) and a sheet of decals. The clear sprue has both types of canopy used, and the ability to open the rear canopy. Construction starts with the cockpit. The dual flying controls are built up along with the seats and there PE belts for both cockpits. These are installed to the main floor then at the front and back main bulkheads are fitted. At the front the main instrument panel goes in. Sidewall detail is fitted into the fuselage halves and in the middle between the two seats the rear instrument panel and its structure go in. Now the main cockpit can go in and the fuselage is closed up. Work now moves to the main wings. There is a single part lower wing with left & right uppers. The wheel wells need to be boxed in and then the wings can go together. The ailerons are then fitted. Various subassemblies now need to be made up and set aside; these include the rudder, tail surfaces, radiators, propeller, landing gear; and practice bomb racks. The main wing is then joined to the fuselage and the canopy added. There is both the earlier more framed canopy and the later more blown style included. The tail planes, rudder and landing gear are then added. The large radiator goes underneath and the prop is added at the front. The practice bomb racks can be added if needed. Markings The decals are from Decograf and look good with no registration issues, there are four decal options provided; N7578 - 8th FTS, RAF Cranwell 1940 N7547 - Fleet Air Arm Training Unit 1940 N7412 - 1st Prototype Aircraft 1938 T8629 - No.5 Service Flying Training School. RAF Sealand, 1942 Conclusion This is certainly a kit modellers of British WWII aircraft and trainers in 1/48 have been waiting for. Very highly recommended. Available in the UK in most good model shops. Review sample courtesy of 4 Link to comment Share on other sites More sharing options...
