HoolioPaulio Posted November 5, 2020 Share Posted November 5, 2020 I know most of us are using the same kit, but feels strange not starting a WiP thread with the box image, so here it is for those not familiar Going with a WHIF theme, decals from some guy on Ebay (they are actually designed for vehicle use on an 00 gauge railway dio), and a bundle of 1/72 resin pilots on order to keep in my spares box as too many aircraft kits these days don't come with any. Other than the decals and random pilots, this will be an OOB build. Hopefully will make a start on the cockpit tonight. Paul 1 Link to comment Share on other sites More sharing options...
Davek72 Posted November 5, 2020 Share Posted November 5, 2020 Hi Paul Out of interest where do you get your resin pilots from? Cheers Dave Link to comment Share on other sites More sharing options...
HoolioPaulio Posted November 6, 2020 Author Share Posted November 6, 2020 3 hours ago, Davek72 said: Out of interest where do you get your resin pilots from? Hey Dave, I got them from Hannants.co.uk, they had a good selection and at the best price I'd found for 1/72 pilots. Paul Link to comment Share on other sites More sharing options...
Davek72 Posted November 6, 2020 Share Posted November 6, 2020 5 hours ago, HoolioPaulio said: Hey Dave, I got them from Hannants.co.uk, they had a good selection and at the best price I'd found for 1/72 pilots. Paul Thanks Paul. 1 Link to comment Share on other sites More sharing options...
HoolioPaulio Posted November 12, 2020 Author Share Posted November 12, 2020 OK, so real life, and an issue got in the way. I did back on the 5th prep all the cockpit parts as I said I would. Then I got stuck into decorating the living room over the weekend. During Sunday afternoon during a decorating break I tried to put a layer of primer on the cockpit parts and had my first issue, the primer would not go on properly like the surface of the plastic was repelling it. Looked like if you spray a heavy mist of plain water on to a glass or something, it had bobbled up in bulbous drops rather than pooling together and running of the surface like it would if you applied it too heavy. Never seen it before. I gave the parts a wash in fairy liquid and the primer has gone on perfectly. This is the first time I've ever had to wash the pieces before painting. Live and learn. Anyway, to prove I have done something, here is my primed cockpit, which doesn't look any different as I've primed in light grey, and my pilots that arrived today. 2 Link to comment Share on other sites More sharing options...
HoolioPaulio Posted November 14, 2020 Author Share Posted November 14, 2020 Still working on the cockpit, which is almost finished. Pilot pretty much done, just needs his flat(ish) top coat to seal the wash when I'm ready flat coat the cockpit too in one batch. 1 Link to comment Share on other sites More sharing options...
CliffB Posted November 14, 2020 Share Posted November 14, 2020 That's nice work on the pilot 1 Link to comment Share on other sites More sharing options...
HoolioPaulio Posted November 15, 2020 Author Share Posted November 15, 2020 Cockpit is finished, but it looks like I'll need to do some surgery on the third party pilots legs, as he won't fit into his seat properly. Gonna dry fit it onto the fuselage and see how much of them are visible before chopping anything. Also picked these up from Amazon for nose weights. There's 160g in total there so should do for quite a few models. The theory being that these ribbons of lead should be easy for me to trim and fold to what ever shaped space I have to fill 2 Link to comment Share on other sites More sharing options...
HoolioPaulio Posted November 17, 2020 Author Share Posted November 17, 2020 Tonight, as well as organising my new display cabinet so I could finally unpack most of my built models and finally display them, I got the cockpit glued in to one side of the fuselage, and then I filled all available nooks with my weight. There is 10.7g (ish), and I'm hoping that's going to be enough as mine won't have any weapons. I will be using the fuel tanks, but if any one needs the MATRA rocket pods or Gun pod for their build PM me and I'll be happy to chuck them in the post. That lead ribbon worked out really well. Then I got the exhaust/nozzle(?) in place And I began closing the fuselage up, starting with the tail 2 Link to comment Share on other sites More sharing options...
CliffB Posted November 17, 2020 Share Posted November 17, 2020 Beatties Liquid Poly 1 Link to comment Share on other sites More sharing options...
HoolioPaulio Posted November 17, 2020 Author Share Posted November 17, 2020 3 hours ago, CliffB said: Beatties Liquid Poly It still has the price ticket on, but it was too faded to read last night. Gonna see if I can see how much it was tonight in better light. 1 Link to comment Share on other sites More sharing options...
HoolioPaulio Posted November 17, 2020 Author Share Posted November 17, 2020 @CliffB 99p on that Beatties poly Dropped a bit of a clanger. Wanted to do it with the airbrake out, buuuut I forgot to put this bit in before zipping the fuselage up 😐 looks like it also stop the door from going all the way in when having it closed 😡 Link to comment Share on other sites More sharing options...
HoolioPaulio Posted November 17, 2020 Author Share Posted November 17, 2020 Never mind, I managed to get it in without pulling everything apart 6 Link to comment Share on other sites More sharing options...
HoolioPaulio Posted November 20, 2020 Author Share Posted November 20, 2020 Making steady progress, but not rushing as I'm still waiting for my pink primer which only just shipped today. Just getting various bits attached to the fuselage, and the wings have been glued and sanded. I also added a shim to eliminate the step where it meets the fuselage. 1 Link to comment Share on other sites More sharing options...
Hockeyboy76 Posted November 25, 2020 Share Posted November 25, 2020 Ooooooo Pink primer. Pink is the Word! 1 Link to comment Share on other sites More sharing options...
HoolioPaulio Posted November 27, 2020 Author Share Posted November 27, 2020 So I finished my parcel tonight And got it in place in the cockpit As you can see, the wings are in, as well as the fins and pylons for fuel tanks And I glued the fuel tanks (which hopefully will be re-purposed), and painted the canopy insert 2 Link to comment Share on other sites More sharing options...
HoolioPaulio Posted November 30, 2020 Author Share Posted November 30, 2020 OK, so the front windscreen was a horrendous fit, but I'm gonna live with it. The canopy had a gap, as it was too short to fill the space left by the badly fitting front Remedied with some .25mm plasticard It has since been glued in place ready for painting. I've also painted up all the landing gear bits and bobs but no photo as I forgot. Link to comment Share on other sites More sharing options...
HoolioPaulio Posted November 30, 2020 Author Share Posted November 30, 2020 Here's the gear I masked the canopy, then gave it a coat of black first so that would show through on the inside Then, and I hope you guys weren't winding me up about pink primer, I used Ultimate primer for the first time. And I have to say, as long as there are no reactions with the Vallejo paints over the top I'm going to switch to Ultimate primers cause it went on real nice 2 Link to comment Share on other sites More sharing options...
thepureness Posted December 1, 2020 Share Posted December 1, 2020 I've really noticed the canopy fit on mine was really bad just live you've pointed out. Quite a lot of flash around the plastic too 1 Link to comment Share on other sites More sharing options...
Hockeyboy76 Posted December 4, 2020 Share Posted December 4, 2020 Pink is the word. 1 Link to comment Share on other sites More sharing options...
HoolioPaulio Posted December 4, 2020 Author Share Posted December 4, 2020 Thats the wings done, ready to mask them and re-prime the body in preparation for the yellow 2 1 Link to comment Share on other sites More sharing options...
HoolioPaulio Posted December 4, 2020 Author Share Posted December 4, 2020 Its a bit out of focus, but you get the idea 2 Link to comment Share on other sites More sharing options...
HoolioPaulio Posted December 11, 2020 Author Share Posted December 11, 2020 Calling this one done. I need to patch up the front of the canopy, I had to lay that much yellow down trying to cover the pink primer that it was unusually thick and pulled some off. I also lost the little pitot tube thing on the other side of the nose. It was painted, then while trying to position it with the tweezers it pinged into another dimension 😐 Will try and get some better pictures for the gallery tomorrow in daylight. 6 Link to comment Share on other sites More sharing options...
nimrod54 Posted December 11, 2020 Share Posted December 11, 2020 That looks brilliant and would definitely be one rapid delivery service. 1 Link to comment Share on other sites More sharing options...
Doccur Posted December 12, 2020 Share Posted December 12, 2020 Looks great @HoolioPaulio! I had the same issue with the pitot in that when I had it in my tweezers it launched into the jaws of the carpet monster... there is an alternative pitot on the sprue, so I just used that. Cheers Ash 1 Link to comment Share on other sites More sharing options...
