Interceptors GB Gallery
The poll will appear here when the GB has finished
1 member has voted
  1. 1. Q1
    • A1
      1
    • A2
      0
Here she is, the Tamiya 1/48 P-38G done as Miss Virginia, the regular mount of Lt. Bob Petit (who later flew a P-51A named Mrs. Virginia with the 1st Air Commando). On April 18, 1943, Miss Virginia was flown by Lt. Rex Barber (whose own plane was undergoing repairs after he rammed a Japanese ship with it) on the mission to shoot down Admiral Isoroku Yamamoto. History records that the wildly unlikely mission was flown perfectly due to the planning and leadership of Maj. John Mitchell and that, almost certainly, Yamamoto's aircraft was destroyed by Barber in Miss Virginia.
Aside from a set of Eduard USAAF seatbelts, this kit is built out of the box using even Tamiya cement and paint and including the decals. What everyone says about it is quite true, it's a truly excellent kit.
Trust me, if you have any interest in the P-38, you can't afford to miss this kit!
Michael
  • Like 25
This is my build of the Hasegawa 1985 boxing of the F-15C Eagle, in the markings of 67TFS, 18TFW at Kadena AFB in Japan, probably in the early 1980's, which may explain the large number of very obvious stencils – I think they were reduced in number and more subdued in later years. I believe that this is a re-boxing of their original “F-15” kit released in 1974, which has caused a number of problems. Firstly, Hasegawa seem to have at that time been under the impression that all 8 undercarriage doors were open when on the ground, when in fact pictures show that 5 of them would normally be closed. The design of the kit parts make it somewhat difficult to fit them closed without a lot of filing, and the result is far from perfect! Also, the kit comes with the so called “Turkey Feathers” on the exhaust cans, which were removed quite early on, though I cannot find an exact date. They are probably correct in this instance but not for the late 1980's onwards AFAIK.
In 1988 Hasegawa released a new mould F-15E and F-15C which corrected both these problems and add a more detailed cockpit, undercarriage legs, engine intake faces, small pitot heads for the nose and pylons which can take both tanks and missiles, though they also removed the weapons, having by then issued their separate weapons sets. As I bought this kit new from Hannants I suspect it must have before the new version was released.
DSC04724-crop DSC04727-crop DSC04729-crop DSC04731-crop
Pete
  • Like 23
Airfix say this is a Bofors 40mm AA gun and tractor belonging to the 1st Battery, 8th Troop of the 15th (Manx) Light AA Regiment in 1940. I do not know about the user details - they may be correct, but the markings together with the gunsight shown on the box art say that it was somewhat later, almost certainly between mid 1942 and mid 1943, which makes sense as that unit did not become part of 7th Armoured Division until July 1942 AFAIK! I built it out of the box except for adding windscreen glazing and some nice etched sights from Dan Taylor's Modelworks as Airfix failed to provide any. It is painted in Colourcoats Light Stone, which I believe would be correct for the period.
DSC04655-crop DSC04658-crop DSC04660-crop
Airfix do provide an optional gun shield but I don't believe that they were often used with mobile units such as this, being usually seen on guns that were dug in.
It is quite a nice kit, and makes a fitting last entry to this GB, as something different to the various planes I have built.
As ever, thanks to the organisers for a very enjoyable GB.
Pete
  • Like 27
This i my entry for this GB. It is the Trumpeter Tu-128 (NATO Code name Fiddler) straight OOB. The build thread is here:-
resized_c7c375b3-8e9c-45d6-a25b-aa84fffa
resized_79a7d15b-7df9-4a05-ab16-6614a3a0
resized_13e067f7-8b3f-4b8a-9c6d-132582b1
resized_e1d674e3-7ab4-4b1c-9924-ce659d6d
resized_230acb95-2bcd-46b1-a9e6-2421e026
  • Like 31
Following on from all these fine builds, it's the Airfix 1:72 Angel Interceptor from Captain Scarlet,  inexpertly put together by a hairy ape with 2 left hands :)
DSCF0124
DSCF0128
DSCF0117
DSCF0126
DSCF0121
  • Like 23
Meng 1/72 Convair F-102A Delta Dagger
Decals from Xtradecal sheet X72-164
56-1405 496th Fighter Interceptor Squadron. USAFE, Hahn AFB, Germany. Early 1960s
  • Like 25
Here’s my second entry for this GB
Kinetic 1/48 Danish Lockheed CF-104D Starfighter
OOB except Stoppel Decals.
Edited by Dansk
  • Like 32
Meng 1/72 F-106A Delta Dart
Decals by Wolfpak Decals.
The 'Cornfield Bomber', a F-106, operated by the 71st Fighter-Interceptor Squadron. In 1970, during a training exercise, it made an unpiloted landing in a farmer's field in Montana, suffering only minor damage, after the pilot had ejected from the aircraft. The aircraft, was recovered, repaired and was returned to service, and is currently on display at the National Museum of the United States Air Force.
  • Like 27
1/72nd Amodel Fury II, K7266 41 Squadron, Catterick, Yorkshire 1938
this is my final entry for the group build and is the kit as supplied with rigging from Invisible mending thread and aerial wires from Uschi van der Rosten  thread. There is some added detail like the control surface horns and rods and aerial masts using nickel silver wire and plastic strip. The model is finished using Vallejo Metalcolor paints and decals are from Modeldecal for the roundels and Model Alliance for everything else.
Build thread is here
https://www.britmodeller.com/forums/index.php?/topic/235087475-amodel-hawker-fury-ii-172nd-41-squadron-catterick-yorkshire-1938/
I have enjoyed this group build as is it has encouraged me to have a good rummage in the stash(O'er missus!) My thanks to Col for hosting the Group and Enzo for overseeing the Group builds.
Off to build some models that don't have 'silver' finishes
  • Like 29
Kit: 1/48 Italeri Lockheed F-22A Raptor
Subject: Lockheed F-22A Raptor - 05-4093 - 90 FS, USAF Elmendorf AFB, Alaska, USA, 2007
Details: Modelled as per reference pics from interweb, and flight magazine
Misc: Mr Paint paints, Mr Color paints, Vallejo paints, Oils, PJ Pilot, Two Bob 48-146 F-22A Roll The Dice Raptors Decals kindly donated by @exdraken , filler (lots of it!), sense of humour....
Build Thread:
On a white background
Edited by Tim Moff
  • Like 23
Vickers 432 high altitude interceptor.  1/72 Kora resin kit. Out of the box with various aftermarket decals .
The 432 was designed as a high altitude interceptor to combat the intruding Luftwaffe high altitude reconnaissance and bomber aircraft such as the diesel engined Junkers 86s.  The prototype aircraft, which was to be pressurised, had various problems with both stability and engines. Vickers had a lot on their plate at this time in both production and development and decided not to pursue the project.
The Kora kit was reasonable with the usual drawbacks of resin manufacture. A struggle, but an enjoyable struggle 🙂
IMG_3780[7502]
IMG_3787[7504]
IMG_3782[7503]
IMG_3795[7505]
  • Like 28
Hasegawa 1/72 F-86D Sabre Dog (JRV - 14088)
- Gunze acrylics
- Artistic oils wash
- Lift Here decals
- Eduard PE Zoom set
- Landing light made from Kristal Klear
S.
  • Like 31
Čáslav Air Base, Czech Republic, June 30th 2005
The final QRA and last operational day of the Czech Air Force's legacy MiG-21 fleet. The jets were updated to modern standards as MiG-21 MFN and equipped with R60 missiles.
The kits are from a special limited edition boxing by JBr Decals, combining the exquisite Eduard plastic with resin and decals to cover a variety of types. To this I added an additional pair of etch sprues from JBr to model the extra antenna of the MFN.
The jets represented were two of those that stood the final duty, including 5581, the last of the type to receive the 21st Century modifications that carried a slightly different paint scheme.
The extra details are a photoetch ladder from a Brengun 'MiG-21 maintenence' set (only the utter rarity of which prevented me adding two to the scene - if anyone has a lead on any more of these, please message me!) and two superly detailed resin figures from Heroes Models of Italy.
https://www.britmodeller.com/forums/index.php?/topic/235087145-june-2005-the-last-mig-21-qra-at-čáslav/
Edited by Tim R-T-C
Added WIP link
  • Like 26
This is my Me 163B-1
The canopy was a problem for me. I tried to fix it and it seemed to go well until I noticed the masks had damaged the future coat I had put on it
and there is no time to fix it again, so it is what it is.
Me 163 image 15
Me 163 image 14
Me 163 image 12
Me 163 image 10
Me 163 image 11
  • Like 26
F-5E 50-460 Republic of Korea Air Force most recent photo I have seen is 2019.
Kit: Dream Model
Scale: 1/72
AM: Master cannon and pitot
Paints: Xrtacolor and some Humbrol enamel, all by brush
Weathering: Flory Grime
Backdrop: Coastal Kits
Mistakes: all my own
WIP at link below.
Chris
  • Like 20
finally finished!
did a quick start and then a long pause, mostly due to other GB commttments ;)
thanks mods for the  extension!
so you get here a Chinese Interceptor! not too many out there in modelled form, although Trumpeter did a great job on bringing them along! (I am desperately missing a Spey engined JH-7 though! )
J-8B Finback
PLAAF
Trumpeter 1/48
Metal landing gears from Up-Wind models from Taiwan! (better than SAC, imho, but also not really necessary. maybe it adds some stability to the generally flimsy gear!)
no more aftermaket available.... as simple as that!
the kit fits great, detail is good!
instructions could be a bit better in some areas, the landing gear assembly and some doors are a slight puzzle, as are the pylons and missile/ rocket / tank combinations. not helped by the fact that some of it was done for the J-10 kit and that all parts for the D/F are aslo included.
whatever, I'd do a second, grey one with modern weapons one day!
WIP:
thanks for your interest and thanks for the great BM GB community!
:cheers:
Werner
  • Like 28
A 1/48 scratchbuilt 1917 quadruplane Supermarine PB31 aka the Nighthawk. Designed to patrol for long hours and attack Zeppelins as they came in to bomb England, two prototypes were commissioned, one was definitely built and flown. The design wasn’t approved for service but it has a lot of advanced features for its day.
resized_23ef337b-42c1-4f5f-8172-b369953c
14a9f8be-d59e-4a91-9268-de71e6e050c5.jpe
65b5a8cf-c59f-4153-985d-552bb78c67d7.jpe
23e5215e-bb0d-4ea3-9c19-da0ed861e402.jpe
resized_2e3b5bc1-cfc6-45cd-a809-8f78c0aa
Doesn’t get much odder than this except for the Oertz W6 I’m intending to build for the anything but injection GB :)
Edited by Marklo
  • Like 28
I assembled the Meng 1:35 Kit ...
ZSU-23-4V1 "Shilka"
Shangai Cooperation Organization "Peace Mission 2014"
I hope you enjoy my work 🙂
The WIP  can be found here:
by Rodolfo Masti, su Flickr
  • Like 25
Kit: 1/48 Revell Eurofighter Typhoon
Subject: Eurofighter Typhoon FGR4  - ZJ917 - '917' - IX (B) Sqn, RAF Lossimouth, 2021 - QRA fit
Details: Modelled as per reference pics from interweb, books etc
Misc: Mr Paint paints, Mr Color paints, Vallejo paints, Oils, PJ Pilot, various decal sheets
Build Thread:
  • Like 24
Guest
