Steve D Posted January 26 Share Posted January 26 5 hours ago, Courageous said: It should keep Steve happy for a short while with wood and metal playing a part, hardly his league though. The longest journey begins with the first steps.. However, I don't think the league thing is right, I still chuck and re-do more than I keep. Guess I'm just stubborn 1 Link to comment Share on other sites More sharing options...
Courageous Posted January 28 Author Share Posted January 28 Hi all, Still waiting for materials to do the deck, so until then... I continued with the cargo hatches by scribing-in the planks, painting them with Vallejo Iraqi Sand and when dry, a dose of burnt umber oil to get the wood effect. Surrounds were painted with RN antifouling red from Colourcoats. 3D bollards from Pascal were cleaned up (not that they needed much), primed and painted satin black... as were these cargo winches... as was the capstan windlass and some more winches, still the odd hair creeps in. Stuart 10 Link to comment Share on other sites More sharing options...
Iceman 29 Posted January 28 Share Posted January 28 You painted them with a brush? 1 Link to comment Share on other sites More sharing options...
Courageous Posted January 28 Author Share Posted January 28 1 hour ago, Iceman 29 said: brush? Nope, same as on the tug, airbrushed satin black, will be dry brushed grey later to highlight the details. Stuart 1 Link to comment Share on other sites More sharing options...
Adm Lord De Univers Posted January 29 Share Posted January 29 Those cargo hatches look unbelievable. Nope, I mean, completely believable. I don't think they could've looked more like wood even if you'd used a wood veneer. David 1 1 Link to comment Share on other sites More sharing options...
Courageous Posted January 30 Author Share Posted January 30 22 hours ago, Adm Lord De Univers said: I don't think they could've looked more like wood even if you'd used a wood veneer. That's very kind of you David. I must admit, I think it's the best wood effect I've done to date. Stuart 1 Link to comment Share on other sites More sharing options...
ArnoldAmbrose Posted January 30 Share Posted January 30 Gidday, I thought they were wood. Well done. Regards, Jeff. 1 Link to comment Share on other sites More sharing options...
Terry1954 Posted January 30 Share Posted January 30 On 1/29/2022 at 1:31 PM, Adm Lord De Univers said: I don't think they could've looked more like wood even if you'd used a wood veneer. Toally agree with David, they really do look rather good, and those 3D printed fittings look really neat as well. Terry 1 Link to comment Share on other sites More sharing options...
PAUL67 Posted January 30 Share Posted January 30 I’m liking those steam winches and windlass going the 3D route will save you a lot of time.. Paul. 1 Link to comment Share on other sites More sharing options...
Courageous Posted January 31 Author Share Posted January 31 Have been playing around with decks. Originally, I was going to go with 1/64 plywood and score-in a plank effect. No matter what I tried, I didn't get the effect I was after, so 'Plan B'. After being very happy with the wood effect cargo hatches, I decided to see if I can do the same with the decks using plastic. So experimenting with a few lighter base colours and oils, I set my palette. I scribed the decking on various bits of plastic, gave them a coat of white primer and when dry, applied Burnt Umber oil which a removed slowly to get the desired effect. So far, I've completed the forward upper deck, aft upper deck, poop deck and the bridge deck. Ignore the finger prints on the top left deck (bridge deck) as it will have a cabin structure on top of it. Still got to do the forecastle, over poop, promenade, boat and navigation decks. Stuart 7 Link to comment Share on other sites More sharing options...
Iceman 29 Posted January 31 Share Posted January 31 It looks good, did you make the slat lines with a pencil? 1 Link to comment Share on other sites More sharing options...
Courageous Posted January 31 Author Share Posted January 31 45 minutes ago, Iceman 29 said: It looks good, did you make the slat lines with a pencil? Thanks Pascal, slat lines were made with a scriber, never thought about a pencil. Stuart 1 Link to comment Share on other sites More sharing options...
ArnoldAmbrose Posted February 1 Share Posted February 1 Gidday Stuart, for wood 'planking' I use Evergreen V-groove styrene sheeting, usually 2025. The sheets are 0.5mm thick and the grooves 0.64mm apart. HTH. But what you've done looks very good. Regards, Jeff. 2 Link to comment Share on other sites More sharing options...
S-boat 55 Posted February 1 Share Posted February 1 That non wooden wood looks very good to me, 1 Link to comment Share on other sites More sharing options...
Dancona Posted February 1 Share Posted February 1 This is another ones of those "must follow" builds, great subject for a model, your woodworking skills are very impressive, I would recommend going for the thickest skin on the hull that you feel you can get away with, to avoid the dreaded rippling and give a good base for getting the surfaces right,I ended up using 1mm on my Vic and it worked out well, but that is significantly bigger, though yours must be a fair size,...... bit of an "Oooooh Matron " moment there, sorry ! 2 Link to comment Share on other sites More sharing options...
Courageous Posted February 1 Author Share Posted February 1 15 hours ago, ArnoldAmbrose said: The sheets are 0.5mm thick and the grooves 0.64mm apart Hi Jeff, thanks for the info. I wish I'd know about it before I started, would've saved myself much effort. I'll take a look for future builds. 12 hours ago, S-boat 55 said: That non wooden wood looks very good to me, Thanks mate. 5 hours ago, Dancona said: This is another ones of those "must follow" builds, Follow away. 1mm makes sense but because the hull sides run into bulwarks, I want a mixture of strength without it being overly overscale. I've decided that a compromise was in order and will go with .5mm. Stuart 2 Link to comment Share on other sites More sharing options...
ArnoldAmbrose Posted February 1 Share Posted February 1 3 hours ago, Courageous said: I'll take a look for future builds. Gidday, there are other sizes too. 4030 is 1mm thick with grooves 0.75mm apart, 4040 is 1mm thick with grooves 1mm apart. There may be other sizes too but I use the first I mentioned (2025) because of the narrow gap between grooves. Plus other formats are available, such as siding. This represents corrugated building sheeting I think. I used it for the deck of HMS York before I discovered V-groove. If your LMS has an Evergreen stand it might be worth checking it out. HTH. Regards, Jeff. 2 Link to comment Share on other sites More sharing options...
Courageous Posted February 2 Author Share Posted February 2 Another day... Poop deck & upper deck fitted. Forecastle and Promenade decks done, still have more decks to do. Here we have a number but not all blocks that are destined for the forecastle, bridge, promenade and boat decks. These blocks are made from 6mm balsa and when cut to shape, the outer faces will be faced with plastic. Stuart 9 Link to comment Share on other sites More sharing options...
Courageous Posted February 5 Author Share Posted February 5 Update time. Bridge deck with its lower cabins fitted amidships. Forecastle and its lower compartments also fitted. With these structures fitted, I can now turn my attention to the hull; midships should be straight forward, bow section a little more tricky as it requires some shaping but hopefully I should do with only plastic sheet, aft section below the poop will require effort . Ignore the caping hole in the deck, had a little accident but fortunately the cabin structure will hide it. Looking aft towards Poop. Looking forward from Poop. Looking aft from forecastle. Looking forward to forecastle. Stuart 9 Link to comment Share on other sites More sharing options...
Andreas.R Posted February 6 Share Posted February 6 On 2/2/2022 at 12:54 AM, ArnoldAmbrose said: Gidday, there are other sizes too. 4030 is 1mm thick with grooves 0.75mm apart, 4040 is 1mm thick with grooves 1mm apart. There may be other sizes too but I use the first I mentioned (2025) because of the narrow gap between grooves. Plus other formats are available, such as siding. This represents corrugated building sheeting I think. I used it for the deck of HMS York before I discovered V-groove. If your LMS has an Evergreen stand it might be worth checking it out. HTH. Regards, Jeff. I also used Evergreen v-groove for my 1/400 scale Heller kits. The deck from the Heller kits are like the "raised panel lines" found on old aircraft kits, and are looking painted not very good. Regards Andreas 1 Link to comment Share on other sites More sharing options...
Courageous Posted February 7 Author Share Posted February 7 So far, so good. Hull sides going on. Stuart 6 Link to comment Share on other sites More sharing options...
beefy66 Posted February 7 Share Posted February 7 Cracking stuff there Stuart with the decking. Stay Safe beefy 1 Link to comment Share on other sites More sharing options...
Iceman 29 Posted February 7 Share Posted February 7 We're getting to the heart of the story! Great hull! 1 Link to comment Share on other sites More sharing options...
robgizlu Posted February 8 Share Posted February 8 Love that decking and indeed the whole look - I've got scruffier wood furniture in my house than that deck Rob 1 Link to comment Share on other sites More sharing options...
Adm Lord De Univers Posted February 8 Share Posted February 8 8 hours ago, robgizlu said: I've got scruffier wood furniture in my house Better get holystoning then Rob. David 3 Link to comment Share on other sites More sharing options...
