Orso Posted October 30, 2020 Posted October 30, 2020 (edited) As this is the wrong scale for me as I want 1/600 for liners it might seem stupid to buy this kit when there are a 1/600 scale Titanic from Academy. But as I have a saw this kit is just what I need to build RMS Aquitania in 1/600. First I remove 10,3 mm from the hull. After the hull has been put together again more parts were removed. Now I have a hull that has the dimensions wanted. As Aquitania had four propellers while Titanic had three work has to be done to the stern. A piece of thick plastic card was cut and bent in to shape. Glued in to place gives a deeper rear. A piece of the bottom has been removed. The paper rudder is just there to help me at the next stage of the rebuild. Edited August 20, 2022 by Orso 11
ArnoldAmbrose Posted October 31, 2020 Posted October 31, 2020 7 hours ago, Orso said: As this is the wrong scale for me wanting 1/600 for lines it might seem stupid to buy this kit when there are a 1/600 scale Titanic from Academy. Gidday Orso, I don't think it is stupid at all. I think it depends on the quality of the kit that should be an important reason as to which kit to build. And there is only 5% difference in size between the two scales. I also like to build in 1/600 scale, all mine being Airfix, but I much preferred the Revell 1/570 Bismarck and Scharnhorst over Airfix's kits of those ships, so those are what I built, all OOB back then. I'm very interested in your modifications to the kit here, from three screws to four. Regards, Jeff.
PF Naughton Posted October 31, 2020 Posted October 31, 2020 Hi, This looks like an interesting build/conversion. Can't wait to see more 😁
Orso Posted October 31, 2020 Author Posted October 31, 2020 (edited) I don't understand why I get in to this mess. I have a similar project that has been sleeping for lots of years. That time it was a 1/800 scale Titanic that I started to convert in to a 1/600 scale MS Kungsholm. Well this one isn't t dead (yet) but it isn't to late for that. Now I need to get some Magic Sculp before I can continue. I wish that I had a complete Mauretania hull to take the stern from. It would probably heve been less work adapting it that this way. At least I have some details like the propeller shafts from Mauretania that I can use. Edited November 5, 2020 by Orso 4
ArnoldAmbrose Posted November 1, 2020 Posted November 1, 2020 6 hours ago, Orso said: It would probably heve been less work adapting it that this way. Ah, but the satisfaction of your creativity when it is done! Gidday Orso (or do you prefer Bjorn?) I'm still looking forward to seeing this build develop. If the Mauretania's prop shafts don't work out have you considered making your own from styrene rod? I tend to do this now because many of the kits I do have rather average shafts, either not round, have sprue gates in the middle etc. HTH. Regards, Jeff.
Orso Posted November 1, 2020 Author Posted November 1, 2020 (edited) Orso or Björn is both OK. Orso is Italian for bear which is the meaning of my name Björn. I use Orso on forums that don't allow me to register with the dots on the ö. I had a look at the Mauretania prop shaft. The rear ones has the right size for this build while the forward ones are to small. Building them will be the lesser problem of building the stern 😁 Among the leftovers of a Mauretania I found the vents. I don't think that there are enough but I will convert one kit into Lusitania and will need to make new vents on it. Then I have the vents from that kit to use here as well. Edited November 5, 2020 by Orso 4
Orso Posted November 5, 2020 Author Posted November 5, 2020 Maybe this will work. The shape is starting to get there. 5
fjaweijfopi4j48 Posted November 5, 2020 Posted November 5, 2020 A demanding job, but you are very talented modeler.
Orso Posted September 15, 2022 Author Posted September 15, 2022 I wonder why I get in to these things. Well. There have to be a first sometime and using this kind of sander on a plastic kit is a first to me. I was happy with the shape of the stern but then I started to cut out the deck from plastic card and realized that the hull was to wide. I added plastic to the inside of the hull so I would have some material to sand into and went for a very course paper with the sander and once again thought that I had the shape for the hull. But as it turned out I didn't add enough material. It got so thin that it split at the rear so I have to cut some of the deck away to be able to reinforce the hull. Everything looks horrible and will need lot of putty. 6
Bandsaw Steve Posted September 16, 2022 Posted September 16, 2022 GREAT to see this back here and active. 👍 A few months back I was going to start my own Aquitania for the ‘Big and British’ group build but for other reasons, that never happened so I’m very happy to see this here. Watching with interest!
Killingholme Posted September 17, 2022 Posted September 17, 2022 (edited) Great project. Love the Aquitania, although for me she was slightly lacking in looks compared to her contemporaries- I think the low forecastle and high after 'castle' somewhat unbalances her profile in my opinion. But no doubt an important ship and it is such a shame model manufacturers, even the resin kit makers have all but ignored these liners over the decades. You've certainly done a very good job of the complex hull form around the stern- it's so characteristic of those Cunarder greyhounds! Good luck with the project! Will Edited September 17, 2022 by Killingholme 1
Bertie McBoatface Posted September 18, 2022 Posted September 18, 2022 On 9/15/2022 at 4:00 PM, Orso said: using this kind of sander on a plastic kit is a first to me. For me it was the Airfix 1/72 Concorde. I wish you the best of luck with that stern. I wonder whether you should have carved a completely new hull from wood? It may have been easier.
Orso Posted September 18, 2022 Author Posted September 18, 2022 Yes it might have been easier but I find it mentally easier to start with something that I can use as a base for a conversion. Besides I am a plastic butcher. Me an wood ..........
Orso Posted October 28, 2022 Author Posted October 28, 2022 V When I removed the deck I discovered it wasn't a crack at all. It was just a large gap between the plastic strips but as it turned out I had to remove the deck anyway. I had been so focused on the shape of the hull that I totally forgot about the lower deck that I had to add. My little motor tool had to work hard to remove enough material inside the hull for a new deck to fit. Now I need to smooth everything out but everything went better than expected. 6
Bandsaw Steve Posted October 31, 2022 Posted October 31, 2022 Keep going mate. This ship is a favourite of mine! 👍
SallysDad Posted October 31, 2022 Posted October 31, 2022 This is a fascinating build. I am watching the magic you are doing with enjoyment.
bootneck Posted November 1, 2022 Posted November 1, 2022 Hello Björn, I have this book on the Aquitania and I could scan some pages for you, if you want. Cheers, Mike 1
Orso Posted November 10, 2022 Author Posted November 10, 2022 On 11/1/2022 at 11:29 AM, bootneck said: I have this book on the Aquitania and I could scan some pages for you, if you want. Sorry for the late reply. I needed to reach my books to see which one it was that I have. Yours is a different than mine so any pictures that show decks to be able to find out placement of doors and windows are welcome.
Orso Posted April 12, 2024 Author Posted April 12, 2024 I have restarted on the deck that I had forgot. But there is something that don't look right in my eyes. Maybe I figure it out or I'll just leave it like this. 6
MrGoldenV Posted May 21, 2024 Posted May 21, 2024 Really interesting to see your progress on this build, I've been planning to try my own version following your method. I have a book to recommend called "Aquitania" The Quadruple-Screw Turbine-Driven Cunard Liner, it has fantastic reference material including engineers plans from John Brown's shipyard. If you don't already have it that is. Looking forward to further updates, you're doing a grand job. 1
Orso Posted August 8, 2024 Author Posted August 8, 2024 I'm starting to regret this build. I was going to add the next deck when I noticed that the one I had finished was placed to high so it had to be removed and the hull modified to get the deck in place. It meant that the hull sides needed repairs. I decided to add plastic card and start all over with the opening. But nothing is probably visible when finished. I've decided on green and white. Doors will be painted but that is all. A stairwell has been started. I'm not sure if is visible or if I'm wasting time building it. 3
Orso Posted August 8, 2024 Author Posted August 8, 2024 The stair will go in the middle opening of the bulkhead. Leading to the next deck. I was planning of use etched stair/ladder but opted for an homemade stair that fit in the opening. I doesn't look to good but as I said, not much is visible. 5
Knb.1451 Posted August 10, 2024 Posted August 10, 2024 Well despite what's been a slog, she's looking good and it's a very impressive effort to turn a completely unrelated class of ship into Aquitainia.
Orso Posted August 10, 2024 Author Posted August 10, 2024 If I had known before I started how much work that is needed I might not have begun. Well I probably would have started it anyway. I think that the aft is the hardest part but there will be more problems ahead. I have now started on C-deck but I need to buy more plastic to continue with the build. I found some motor boats from the Airfix Warspite kit that I started to convert into the motor launches of Aquitania 3
