1/48 Revell Tornado ADV 36° Stormo, Gioia del Colle, Aeronautica Militaire.
Better late than never, and thanks to the twin miracles of horrendous weather at sea and Amazon Prime I made it!
I have decided on the Italian Airforce scheme for the Tornado ADV in my Mark 1 Dozen sheet.
What better way to 'enjoy' this time of year than by thinking of sunnier climes!
Lots of info here:
https://theaviationist.com/2009/03/30/a-day-in-the-life-of-the-36-stormo-of-gioia-del-colle/
Should help me turn this:
resized_3f1f2e37-5144-47d1-b627-c69f03ce
Into this:
5a030e4e-7a72-4848-a1af-741c43d21688.jpe
Credit for the photo to the Aviationist blog liked above.
Nice to see an Italian F.3 getting some coverage (even if it isn't a JASDF scheme) and hopefully you've enough time remaining to investigate the alternative build methods many have adopted. Welcome along :)
In the spirit of OOB building here is the cockpit using the kit decals.
resized_91bfb9b6-a1a5-4592-a7a1-9ee5ae3c
And I have started by following the 'Nathan' Technique.
resized_dc7a39eb-45f2-4e67-a979-1fe13ace
Very neat & fuss free so far...
resized_8f2e53cf-ec28-4b34-9a9c-3ac6cb91
Normally my builds of this kit have ended up like this, then sliding the nose on:
resized_6c6a714c-9603-4f15-b37c-614df0de
So it will be interesting to see how this improves on that.
I will however be using my pylon technique:
resized_6535f0b5-caec-409c-a6fc-a8f9550d
Slice the pylon 'bit inside the wing' off.
Then sand excess away:
resized_246f3a45-a870-4e84-920d-ddef101e
resized_088996a2-569f-4790-826b-f7722e2d
And finally add to top of pylon, giving a good positive location for the Pylon.
resized_6f60e4b1-7c5f-491f-8c54-32d82a2c
This technique is very good.  So far it has sorted out all of my normal fit issues.
resized_bdff6c03-78dc-4411-9bd2-6cd5ed5b
So researching 'my' Tornado F.3 it turns out she was built in 1990-1991.  Build number at Warton was 859/AS130/3418 and taken on charge as ZG735.
1991 - 1994? as CO 5 Squadron RAF
1994? - 1997 as AZ 56 Squadron RAF
1997 - 2004 as 36-10 MM7232 Aeronautica Militaire
2004 Struck off charge at RAF St Athan and sadly scrapped.
If anyone know any more of flew in her or worked on her I'd be interested to hear about it.
66bd98c1-ec11-4bcd-b67f-d99a0d42cee0.jpe
579e475e-afee-440a-a78a-3f2c943e1f21.jpe
3500d72b-e906-4e4e-9dde-99e49a32acfa.jpe
7957867e-c41d-4e9e-97c1-b7f25ab5eb2a.jpe
adb374c1-b425-4304-83a8-af3f028934cd.jpe
  • Sad 1
Good progress and nice to see the particular subject's history.
Where we are tonight.  Flaps built, wings built, fuselage together tomorrow!
resized_846f0e67-2910-4bc7-a844-deb1994c
Looking great , I like the idea with the pylon mounting , I will use that in my next Tonka build ( a GR1 - anniversary schemes are great but wrap around camo is the best ;) )
Some real progress.  I should have taken a picture of the 'collars' that go above & below the engine (parts R222 & R223) which I do my own thing with.
I build the Stabilators and insert the stub parts before they go on the airframe.
I then attach the stabs to the airframe and glue them in their intended position along their whole length. before adding R222 & R223.
Then I put R223 on first.  This is because it is the top part and needs to fit best.
This then allows any sanding or finessing to happen to part R222 and this hides all of the seams and joints and any ill fitting underneath.
I then added my 'Euro' nose weight.
resized_45b3167f-36ec-4265-a467-c659e7e0
I love how 2 Euro Cents fits perfectly!
I've also added my intakes.
I have a trick for these as well.  I cut off the horizontal tab as shown:
resized_317feab5-c025-459e-bbb9-0736b363
Next the intake ramps get fitted, I have posed mine in the down position which is incorrect but hides my unpainted intakes.
I then fit the outer part and this allows me to do any sanding etc etc on the inside not the out side to get a fit.
resized_f9f90f6f-6684-4ca2-8f54-a10740f5
The outside then fits nicely.
resized_08c315cc-f2d6-4b4f-8e69-12352379
Lovely short shot there!  You can see the dimple which corresponds to the horizontal tab on the other side.
And lastly I can fit the first step of the intake ramp as a separate part, this will need a little filler but at least it central and not off to one side.
resized_ea82388f-c02e-4d7e-bd8c-1f5a5f9b
Filler & sanding stick ahoy!
Happy so far.
Looks like a Tornado!
resized_59ea1291-f203-4b01-b621-0002c8c2
Flaps 'n' Slats.
Did a dry fit and they clear the stores too.  Phew!
resized_ff8d4d63-7920-4e8f-a676-4f665602
resized_06d7574a-308a-4934-849e-045e460f
Nice flaps!
I am currently thinking what to do with the wings on my F.3 as well now- all out?...the IDS has kind of working wings / stores....
Righty ho!
got back ashore again 10 days ago, then the wife had a week off work, so now I’m back at the bench!
Updates to come.
resized_9a0fa3a4-2614-483e-807b-f81cf662
My first nod to aftermarket, Pavla resin seats, with 1/2 the casting block left on to ensure they are the right height, well the brave Italian cavalieri dell'aria will need to see out!
Apologies to paint purists.
laid down a base coat of Halfords Ford Polar Grey.  Will decal & then weather this & hopefully achieve the grubby look of an Italian in service Tornado!
resized_f7178f77-c964-4531-a264-d8a7f615
