Work In Progress Posted January 2, 2021 Share Posted January 2, 2021 1 minute ago, brewerjerry said: Hi many thanks tried but the BM messenger says you cant receive messages cheers jerry huh! well I have been doing all week... maybe I need to delete some, stand by... Link to comment Share on other sites More sharing options...
Work In Progress Posted January 2, 2021 Share Posted January 2, 2021 4 minutes ago, brewerjerry said: says you cant receive messages Yep, inbox was oversize. Deleted some so try again now Link to comment Share on other sites More sharing options...
brewerjerry Posted January 2, 2021 Share Posted January 2, 2021 2 minutes ago, Work In Progress said: Yep, inbox was oversize. Deleted some so try again now Hi thanks message sent cheers jerry Link to comment Share on other sites More sharing options...
Parns Posted January 17, 2021 Share Posted January 17, 2021 On 10/28/2020 at 10:28 AM, Colin @ Freightdog Models said: I have a few of my Halifax upgrade sets left (but does not cover the 4 blade props), pm if of interest. Thanks, Colin Hello, I've sent you a PM about these. Would dearly like to get my mitts on a set suitable for the B.II Srs1. Link to comment Share on other sites More sharing options...
Parns Posted January 17, 2021 Share Posted January 17, 2021 On 1/1/2021 at 11:10 AM, elger said: The first option is getting your hands on an Aeroclub correction set. This includes injection molded replacement nacelles. But I believe this set is no longer available. The second option is using the Freightdog resin sets - which improve the look somewhat but don't reduce the size of the nacelles. Don't know about the availability of the set - might have sold out. Build 1 https://www.britmodeller.com/forums/index.php?/topic/234978739-z-nose-halifax-revell-mkv-freightdog-resin-update-parts-finished/&/topic/234978739-z-nose-halifax-revell-mkv-freightdog-resin-update-parts-decals-on/?p=1931711 Build 2 https://www.britmodeller.com/forums/index.php?/topic/235021965-halifax-b-mk-iiigrii-revell-172/page/16/ The third option is doing what Brett Green did, which using the Matchbox parts to improve the Revell nacelles. Someone here even used the Revell nacelle intake lips on the Matchbox parts if I recall correctly. Here's Brett Green's build: http://www.hyperscale.com/2012/galleries/halifaxbmkiiseries172bg_1.htm And this that build with completely reshaping the nacelle air intakes: The fourth option is to live with Revell's mistake. Thanks very much- have had a good look through, and my thoughts are that, in default of the Aeroclub set's availability, to use a replacement radiator in front of thinned-down nacelles. Link to comment Share on other sites More sharing options...
