Pastor Rich Posted May 18, 2021 Share Posted May 18, 2021 MOJO 1 Link to comment Share on other sites More sharing options...
woody37 Posted May 18, 2021 Share Posted May 18, 2021 I struggle making biplanes from kits and here you are building them from scratch! Incredible and a pleasure to follow 2 Link to comment Share on other sites More sharing options...
KMS Posted May 18, 2021 Share Posted May 18, 2021 Work is very inspiring. ... delicious. Thank you. 1 Link to comment Share on other sites More sharing options...
tonyot Posted May 18, 2021 Share Posted May 18, 2021 Awesome doesn`t even cover it,...... I`ve really enjoyed catching up with this project and as usual it looks like a real aeroplane! Cheers Tony 1 Link to comment Share on other sites More sharing options...
airscale Posted June 1, 2021 Author Share Posted June 1, 2021 Hi again everyone I cracked on with the upper wing - same format as the lower wing in using very thin plastic card, embossed with a ballpoint to simulate the ribs / catenary and then carefully using impact adhesive to fix the skins to the wing structure.. ..the tips were again a problem as the plastic doesn't like the compound curves, but I think I sorted it out in the end.. ..by the time I took this pic, both wings and the middle section were skinned, primed and sorted. I made the whole wing so I could cut the ailerons out and they would conform properly - here I am using a printed part of my wing plan to match the aileron to the mini forward spar underneath the skin.. ..the ailerons were cut out with sharp blades, mini saw blade and a few cuts with a slitting disc.. the profile is different on the top to the bottom, but I had no drawings so all I knew was the outlines.. ..with the ailerons removed some of the structural details can be added - there are two teardrop shaped recessed into the wing that make space for big balance weights sticking out of the front of the ailerons - these were made by plunge moulding the recesses and letting them into the bottom wing skin... ..here insulating tape is used to protect the embossed rib detail while I fill and fair in the recesses.. ..once the structural bits were done it was time for rib tapes, many, many rib tapes.. ..as before, the tapes and any linen patches are made from decal film - there is a lot of it... ..the circular hole on the lower surfaces is where there is a disc shaped bellcrank to control the aileron ..with everything done, it was time for paint - alclad white aluminium.. ..the rib tapes are quite subtle and I think worth the hours of work.. ..another look at the underside and the details.. ..the ailerons were also completed - an interesting detail top right is a small glass inspection window which seems to have a white notice with red writing inside it - made that using an airscale decal ..the internal shape where it meets the wing will be all wrong, but this can't be seen so it is what it is.. ..complete topside - the gaps between the sections is fine - in fact I would say mine is tighter than the real one ..and the underside.. ..probably get all the markings on the wing topside next.. I am NOT looking forward to that... TTFN Peter 31 1 Link to comment Share on other sites More sharing options...
bigbadbadge Posted June 1, 2021 Share Posted June 1, 2021 The wing tapes do look absolutely lovely and very subtle, the wing looks absolutely stunning and another piece of great work. Chris 1 Link to comment Share on other sites More sharing options...
tonyot Posted June 1, 2021 Share Posted June 1, 2021 Brilliant! 1 Link to comment Share on other sites More sharing options...
k5054nz Posted June 1, 2021 Share Posted June 1, 2021 It's so nice to see "fabric-covered" model parts with no visible weave, they look amazing! 1 Link to comment Share on other sites More sharing options...
cngaero Posted June 2, 2021 Share Posted June 2, 2021 I never cease to be amazed by your updates. Those wings are works of art, just like everything else that you've produced. Good luck with the wing markings. You're nearly there now. 1 Link to comment Share on other sites More sharing options...
Bandsaw Steve Posted June 2, 2021 Share Posted June 2, 2021 Decals for surface tapes! Genius! Consider that stolen. 1 1 Link to comment Share on other sites More sharing options...
RichieW Posted June 2, 2021 Share Posted June 2, 2021 Love the decal rib tapes, they should be very subtle. After masking and painting them on my current build I wish I'd done the same. Much less laborious, a lot neater too! Richie 1 Link to comment Share on other sites More sharing options...
airscale Posted June 2, 2021 Author Share Posted June 2, 2021 thanks chaps just a quick one to say wing painting is done without issue thank goodness used radu's masks for the roundels and then started to lay out the top wing squadron marks - i also had some round blanks to cover the roundels in the masks I made, the rest was tamiya tape.. ..getting there.. ..mixed up a match to the fuselage paint & airbrushed.. ..and job done ..lots more details on the wing still to go, but I am so relieved that is out of the way.. TTFN Peter 28 Link to comment Share on other sites More sharing options...
fightersweep Posted June 2, 2021 Share Posted June 2, 2021 OH........MY........GOD! That is absolutely gorgeous. Masterclass/Jedi category modelling right here. So good I have to remind myself it's a model and not a real Fury restoration. 1 Link to comment Share on other sites More sharing options...
bigbadbadge Posted June 2, 2021 Share Posted June 2, 2021 That top wing is absolutely gorgeous what a fantastic job, the markings look ace. Chris 1 Link to comment Share on other sites More sharing options...
dogsbody Posted June 2, 2021 Share Posted June 2, 2021 Wow! I feel such neanderthal-ish knuckle-dragger when I see work like this. Is this what the people felt when the watched Michelangelo paint The Sistine Chapel ceiling? Chris 1 1 Link to comment Share on other sites More sharing options...
cngaero Posted June 3, 2021 Share Posted June 3, 2021 Outstanding work Peter. I've probably asked before, but have you ever considered doing a "How To" video or videos covering some of your scratch building techniques? Pretty please!!!! 1 Link to comment Share on other sites More sharing options...
Marklo Posted June 3, 2021 Share Posted June 3, 2021 (edited) 9 hours ago, cngaero said: I've probably asked before, but have you ever considered doing a "How To" video or videos covering some of your scratch building techniques? Pretty please!!!! He’s on Patreon Which is subscription based. Would love to join myself but SWMBO would kill me for such a frivolous use of funds, seeing as how my Apple Music subscription had to go, sigh. Edited June 3, 2021 by Marklo 1 1 Link to comment Share on other sites More sharing options...
airscale Posted June 13, 2021 Author Share Posted June 13, 2021 hello again thanks all for your kind comments On 6/3/2021 at 11:23 AM, cngaero said: Outstanding work Peter. I've probably asked before, but have you ever considered doing a "How To" video or videos covering some of your scratch building techniques? Pretty please!!!! I did have a Patreon page for about a year which had lots of videos about how I do things, but I closed it as it simply took too much time in production and gave me less building time - I will see if I can unrestrict the videos as the page should still be there things have been hotting up in complexity in trying to fit the upper wing.. ..first they needed completing, so these access hatches were added - not sure what they are for.. ..also all the bracing wire mounts & doped patches were added to the underside.. ..the ailerons had the mass balance weights and the control horns added.. ..and the disc cam drives & control arm and were fully mounted in a neutral position.. ..with the wings complete, I wanted to get to mounting the centre section - to do that all the stuff under the upper wings on top of the fuselage like aldis sight needed fabricating, including the windshield.. ..this was quite tricky as the frame sits on a wooden former that is a neat fit to the fuselage.... I did this by covering the fuselage in aluminuim plumbers tape (like bare metal foil) and CA'd a rough frame to it so I could build up the shape with P38 filler and still be able to break it away later as none of it, including the CA really sticks to the foil.. ..that was refined and the glazing added - very carefully - I hate doing transparencies as I have a track recordn of screwing them up.. ..the aldis sight and gunsight parts were made and added to the upper fuselage.. ..also the cabane struts, which I have to say was probably the hardest and most frustrating bit of modelling I have ever done - they look simple sat here in the pics, but this is days of work to get them right so the orientation of the upper wing is correct in 3 axis ..the centre section fits on posts in each strut and will be a real challenge to actually glue in place as I need about 12 hands to locate everything.. ..there are also multiple rigging wires so things are starting to get exponentially harder TTFN Peter 27 1 Link to comment Share on other sites More sharing options...
(ex)Sgtrafman Posted June 13, 2021 Share Posted June 13, 2021 Ace! Am I showing my age? 1 Link to comment Share on other sites More sharing options...
shortCummins Posted June 13, 2021 Share Posted June 13, 2021 its hard to believe that this isn't the real thing simply wonderful rgds John(shortCummins) Link to comment Share on other sites More sharing options...
bigbadbadge Posted June 13, 2021 Share Posted June 13, 2021 Looks absolutely stunning, great work 9 minutes ago, shortCummins said: its hard to believe that this isn't the real thing simply wonderful rgds John(shortCummins) Take images on on photo back drop and it would be nigh on impossible to tell I reckon. Great work Chris 1 Link to comment Share on other sites More sharing options...
elanman Posted June 13, 2021 Share Posted June 13, 2021 Superb, really superb. Link to comment Share on other sites More sharing options...
RichieW Posted June 13, 2021 Share Posted June 13, 2021 Wonderful update, all that time setting up the cabanes i think will pay you back handsomely when you come to mount the top wing. Great use the aluminium tape. Have noted that one down. Richie Link to comment Share on other sites More sharing options...
cngaero Posted June 13, 2021 Share Posted June 13, 2021 (edited) 12 hours ago, airscale said: hello again thanks all for your kind comments I did have a Patreon page for about a year which had lots of videos about how I do things, but I closed it as it simply took too much time in production and gave me less building time - I will see if I can unrestrict the videos as the page should still be there things have been hotting up in complexity in trying to fit the upper wing.. ..first they needed completing, so these access hatches were added - not sure what they are for.. ..also all the bracing wire mounts & doped patches were added to the underside.. ..the ailerons had the mass balance weights and the control horns added.. ..and the disc cam drives & control arm and were fully mounted in a neutral position.. ..with the wings complete, I wanted to get to mounting the centre section - to do that all the stuff under the upper wings on top of the fuselage like aldis sight needed fabricating, including the windshield.. ..this was quite tricky as the frame sits on a wooden former that is a neat fit to the fuselage.... I did this by covering the fuselage in aluminuim plumbers tape (like bare metal foil) and CA'd a rough frame to it so I could build up the shape with P38 filler and still be able to break it away later as none of it, including the CA really sticks to the foil.. ..that was refined and the glazing added - very carefully - I hate doing transparencies as I have a track recordn of screwing them up.. ..the aldis sight and gunsight parts were made and added to the upper fuselage.. ..also the cabane struts, which I have to say was probably the hardest and most frustrating bit of modelling I have ever done - they look simple sat here in the pics, but this is days of work to get them right so the orientation of the upper wing is correct in 3 axis ..the centre section fits on posts in each strut and will be a real challenge to actually glue in place as I need about 12 hands to locate everything.. ..there are also multiple rigging wires so things are starting to get exponentially harder TTFN Peter This just gets better with every update. Good luck with the rigging when the time comes. As to your next project, forget my earlier suggestions. Whilst gazing lovingly at the last two photos, it hit me. Seeing that you have my share of fine modelling skills, what about a model that would certainly be be your magnum opus in 1/18th scale, the Handley Page HP 42 airliner? Just think of all that lovely interior detail, Jupiter engines, fabric wings and all that corrugated litho plate? I'm drooling just at the thought of it. Seriously though Peter, your Fury is absolutely amazing. Definitely your best to date............ Until the HP 42 that is. "Quickly Nurse, he's off again. Let's get him back to the ward". Edited June 13, 2021 by cngaero 2 Link to comment Share on other sites More sharing options...
Putty Animal Posted June 14, 2021 Share Posted June 14, 2021 Master of your craft Sir! Link to comment Share on other sites More sharing options...
