1/18 Hawker Fury
airscale
mojo
noun
  informal
a quality that makes you successful and full of energy:
·        He's definitely lost his mojo.
·        He needs to get his mojo working if he's going to finish that model
Well, I lost mine over the last few months in a big way. For many reasons I just lost interest in my Fw190 and so it has been shelved for now. It's one of those inexplicable things, those that remember the 1/24 Tigercat maybe know I have form in this area ..
Instead, I have found a new source of mojo which has seen me back at the bench, enjoying my modelling which is what it is all about right?
This is new for me, I don’t think I have ever built a biplane, certainly not scratchbuilt so it will be a journey of discovery I hope to share
The Hawker Fury needs no introduction from me, all I can do is show you the picture that set me thinking and ultimately on this path…
..look at that beautiful form, the polished metal nose panels, the state of the art in it’s day. I don’t know yet which airframe I will model, but likely it will be a Tangmere bird as that was but a few miles from my childhood home.
I gained the confidence to take the plunge from John Alcorn’s books ‘Scratchbuilt’ where various masters show how they achieve the impossible in relation to fabric covered structures such as those shown below – if you don’t have the books, get them, they are superb..
Need fuselage stringers? A few methods are shown..
Wings? Just like the originals..
I started with the Westburg plans, four sheets sourced from a 1970’s RC Model magazine I found as a PDF that my printer scaled for me..
..these are widely acknowledged as the most accurate out there..
..and so onto building & making a start..
..the first element I thought would be a rigid structure that supports both the landing gear and the cabane struts atop the fuselage. This would need to be very strong and so was made of brass parts..
The very first of which is here – the main gear mount..
..then the transverse rods that link to the main gear trailing arms and the mounts for those mounted on the mainspar tube.. I used (badly) my new Proxxon mini milling machine for those..
..all the parts were made up over the plans and ultimately soldered together, including spigots for the cabane strut mounts..
..the firewall looking square is to add rigidity and the hole is the prop datum that will carry forwards into the nose..
..more of the fuselage framework was constructed of carbon fibre rod – this stuff is super stiff and easy to work with – I used an RC modeller trick in pinning the rods to a scaled plan to get everything lined up..
..soon I had both halves (at least the bits that can be seen) which will dovetail into the brass frontal assembly..
..the real airframe is bolted together with some quite rudimentary brackets – that’s good, I can do rudimentary..
..I should have made these from PE, but such was my renewed enthusiasm I made them by hand with the resultant rudimentary outcome..
..the structures were primed and painted with black MRP enamel and the assembly plates added..
..whilst I didn’t take any construction pictures, I did make up the seat based on the few pictures I have (that’s a problem I will come onto later..)
…essentially I drew parts as templates and cut them from litho, annealing & shaping them and bordering with fine solder wire..
..to finish up for now, the work to date dry fitted together…
..now for the appeal – I have zero drawings apart from the plans, I have the one Mushroom book I could find and that is 80% about the Nimrod, not the Fury and about 5 cockpit pictures all from the same angle from the internet..
I have written to both operators of existing Furies in the hope they have drawings they can share, but if anyone out there knows of any good reference, please let me know – drop links in here or PM me perhaps
So that’s it – a change in direction, for me the main thing is being motivated to pull up to my bench and enjoy myself and that I am now doing :)
..hopefully this one will see a competition table in a few years
TTFN
Peter
  • Like 54
  • Thanks 3
'Tis a thing of beauty indeed. Welcome back, John, good to know you are back at the bench and ENJOYING YOURSELF.
Yep, that is what it's all about and what will keep me eagerly heading out to the garage over the Winter.
Good luck with your quest for knowledge. I'll be down at Dispersal, listening to the engine runs, but watching out for your posts.
Hello Peter,
Wonderful to see you commence another Epic build.
Having  followed your Tigercat build, I know this
one will be absolutely  STUPENDOUS!
SUPERB  start Peter.
Comfy hammock found! and following  with much enthusiasm!
9 minutes ago, HOUSTON said:
Hello Peter,
SUPERB  start Peter.
:worthy:
Evening folks :)
Thank you for all your kind comments – I will try and live up to them!
..got a little bit done since last time – added the seat height adjuster – an industrial sized lever indeed..
..also used this and one other photo to try and make up the control column assembly in which the control stick itself goes through a casting which is itself mounted on a rod going fore & aft..
..you can see the stick as the grey vertical rod in front of the seat, and the transverse black rod below it
..I made the parts from brass and these were just CA’d rather than soldered..
..and with the torque tubes for the aileron controls (I think..).. whatever it is it mounts to brackets on the fuselage side frames to secure the whole thing..
..for the control grip, I found a picture of a Fury one in the RAF archive, scaled it and traced it into coreldraw to get an idea of construction..
By this point I had added two small brass ferrules to a bit of thick wire and wrapped it in cotton.. I think it looks a bit overscale, but there were no better options I could think of..
..the final part has quite a few tiny bits, which I hope captures it..
..and in place – it still needs the cables from those two thumb controls..
..and that’s it – still struggling with references so just seeing what I can do while I wait to see if I can climb all over a real one
TTFN
Peter
  • Like 33
Great to see you back here @airscale and what a great subject you have chosen.
A couple of questions if I may:
What mark of
Proxxon mini milling machine are you using?and would you recommend it for this kind of work? I think there may be Very small milling machine in my future but I know nothing about them.
Also, do you have any tips on sticking bits of litho together (eg the seat). I’m very interested in litho but understand that it cannot be soldered without some very special gear or methods.
any thoughts appreciated.
Wow...
Model engineering indeed! It was a good idea to photograph the stick grip assembly with that enormous oversized dressmaker's pin, Peter, but I'm not entirely convinced by your definition of 'rudimentary' regarding all those homemade frame brackets!
All my own creations suddenly seem a bit naff - I'll definitely be following this epic build.
Jon
