Julien Posted October 12, 2020 Share Posted October 12, 2020 F-5A Recon Lightning Conversion Set (4399 for Tamiya) 1:48 CMK by Special Hobby The Lockheed P-38 Lightning was a fast aircraft, and when stripped of unnecessary weight and combat equipment it was faster still. Lockheed developed the F-4 as a reconnaissance airframe with a new nose to house the cameras where the guns had been, plus the necessary controls and avionics to perform the task. The F-5A was a P-38G conversion, with 181 airframes made. The Set This set arrives in one of CMK’s yellow card boxes, with six grey resin parts on four casting blocks, seven clear resin parts for the camera windows, a sheet of decals and even some masks for the camera windows. The two largest parts make up the new nose, which entails cutting a small section from the two fuselage nacelle parts, which are shown on the accompanying instructions. Before gluing the new nose in place, the window apertures should be de-flashed and the crystal-clear resin windows glued in place, then the nose cone added. Later in the build a small antenna is fitted to a pit on the upper nose behind the faired over gun troughs. Inside the cockpit is a new more rounded control yoke, and an instrument to fit inside the centre cockpit. Another yoke is included on the casting block, but this is unused. Markings There were only 20 of the type made, with two on the decal sheet. F-5A 4213965 "Shark", 12th PRS, Florennes, Belgium 1944 F-5A, Groupe de Reconnaissance 11/33 "Saviie" , white 80 maned Jeane, Sardinia 1944 The decals are well-printed with good register, sharpness and colour density, and you will need to complete the decals with the kit supplied stencils, as this set includes only the national markings and individualisations. Conclusion An interesting set that will fill a gap in the market that will either be missed by Tamiya, or arrive sometime before the heat-death of the universe knowing their glacial release schedule. Highly recommended. Review sample courtesy of 1 1 Link to comment Share on other sites More sharing options...
