44 minutes ago, Moa said:
Far from being an engineer
Au conraire mon ami, you are definitely an engineer of the plastic.
32 minutes ago, Dave Swindell said:
They serve two purposes
Thanks for that, Dave, clear as a bell now.
Dennis
27 minutes ago, johndon said:
Nice work on the bells
Thanks, John.
Dennis
38 minutes ago, Moa said:
Hi Dave
Does that mean that they are not actually rings, but a sort of coiled duct?
No, they're rings. If you think of the rocket bell being the wing surface radiator of a Schneider racer rolled spanwise into a cone, the rings are the coolant headers supplying the coolant to the tiny channels in the radiator.
The whole of the rocket bell is double walled and cooled by fuel between the walls. it's known as regenerative cooling (link warning, it contains references to German rockets that go bang).
  • Thanks 2
Thanks, Dave, great piece of knowledge shared, appreciated.
  • 3 weeks later...
Landing gear and bay doors mostly done. Nothing special just a few extra bits to busy them up a little.  A spot of CA or cement will secure them in their bays.  The door hinges are bits of fuse wire flattened out a little.   The gear and doors can be added at the very last so as not to worry about snapping anything off.  Couple of things I would do a little differently but these will do for this one.
Thanks for looking in.
Dennis
resized_2257307b-4bb8-4606-820c-10f960c2
