154 - Bell Airacobra P-39 - Ota oddball #finished#
Contestant numero 2:
The 1977 P-39 Airacobra kit.
This one has suffered a bit. The cockpit bits are missing, so a seat & floor will be scratched and modified instead.
The four blade prop is missing one blade.
y4mSgif443rVSTibftzbuFj8vi0ShRYj55QvSksX
A secondhand PE set may help here :)
 Accuracy-wise, it's not going to matter too much because this one will not exactly end up as a P-39Q/N as boxed.
I've chosen some oddball markings.
Some 19 USAAF Operation Torch P-39s from the 81th and 350th FGs didn't quite make the ferry distance, and were interned in Portugal and pressed into service with the Portuguese AAF.
y4m1gbZj5TxSqYUUCW5gFIgeD7OXZP9JpL6lOfmY
  • Like 10
  • alt-92 changed the title to 154 - Bell Airacobra P-39 - Ota oddball
Magic! I've been waiting for the P-39 to appear. Nice colour scheme choice too. Another build to follow and it's going to be fun trying to keep up with it all!
Steve
I like the Heller Airacobra, it was a big improvement upon what went before.  A great choice and I like your choice of markings too.
Good luck with this one.
Another Allied Heller classic kit and one that looks good when built. Now I didn’t know that this came with a Four blade prop, what version would that be for?
Cheers and welcome to this GB.. Dave
P-39Q
  • 4 weeks later...
While waiting for stuff to dry on the three other builds on the go, made a start with having a look what needs to be done for the P-39.
As said, all the cockpit bits apart from the instrument panel are missing.
Looking at the instructions, it's clear that the floor extends up to the nose and also forms the attachment point for the nose wheel.
So:
Floor cut & sanded to size, wheel well sideboards made.
Also need to build the back firewall up.
y4m9a-RgNqRX1naKrh-HY3z22mNdxq6wFcuKwggp
The scraps were used to fashion a basic seat - which still needs a bit of cleanup & mods.
y4mLGTEb2P_2F1SFq6M-4YXKWQaFkGfwVQs7TmUe
Found some PE meant for the Hase kit, and will use some of that to dress up the internals.
y4mmkRB7LhqNWYWglEJHFFRGtQa3ejTTDrlzR7Ns
Fun ensued.
  • 1 month later...
Update:
Added the cockpit flooring bits and primed with black.
y4mdrS6GJRWaDI4YuLotUV4yR2-H4dkp2UkKfdoV
IP blanked and PE stuck on, light drybrush and dots of klear to be added.
y4mVGBUe5NjPPXv1u2GmilinNJ4QmH8JjnE5WWjH
Oil and Radiator bits stuck on the bottom wing:
y4mvLIWmfDixFdoOENA31ZcjyNRqQMQzsmu4eqeE
Added around 10gr of lead pellets, interior splashed with bronze green and closed up the fuselage:
y4m0wNF82mJKCmAarOiRZU6MZClmCW521koCPdoq
The seat scratchbuild is almost ready to be put in, just the belts to be added (upper right) and the control column.
A look inside:
y4mKnSumB3AYcY8giCNzLkrjITp0dKb_sEUOtltg
It's quite interesting to read about the number of permutations and changes, and how many of these changes were based on Soviet feedback - even the P-63 ended up what it became with their input.
Cockpit complete (apart from the gunsight that needs to be scratched).
All the wingsy bits have been added, she's looking like a proper aircraft now :)
initial Olive Drab laid down..
y4mbCxrp-nnXIZY4-bkqbGkxoXRqGI1lh-RqF4-y
Oh, look. A stray fiber.
For USAAF OD 41, I tend to start off with a base layer of Vallejo US Loam, then pick multiple shades of Olive greens to break up the monotone colours somewhat.
I'm leaning towards a more bleached, tattered look with this one.
y4mxLhcFO5eYo_g6X0XtXKotMw4DXn_FKDx0FwEF
Masking the canopy and windscreen at the moment, to be continued.
  • 3 weeks later...
@JOCKNEY Slowly picking up the pace again, I'm one of those lucky sods who have had to keep working over the holiday season.
Due to lockdowns, the schools and nurseries were all closed down which means colleagues with kids can work less and us folks without spawn have to take up the slack.
Hi mate
Great to hear from you, ditto on the working during the holidays.
Mrs Jockney is a Parkinson's specialist but gets called up for covid duties at the local hospital.
I'm on call for the electric company, keeping the lights on, so alcohol free ! Its enough to give a Scotsman nightmares :weep:
Cheers Pat
Managed to do some fading & blotch template use, which gives a nice degraded effect to the OD.
And as usual, when you cover it with a clear coat to prepare for decals, it comes out way darker :D
it''ll be fine with a final matt coat...
y4m64wn91VvlAv-wYEvvoXUlusiPxM4NjQcsMe7A
The underside is bog-standard Neutral Grey.
y4mnKXuUsG0MF04eoVaf_sfuw_gDMlyKHRTRAC9U
  • 5 weeks later...
Because the original cockpit & nosegear bay parts were missing, the positioning on the nosegear is slightly off to what it's supposed to have in the box.
In order to camouflage that a bit, it's slightly offset in a turn.
The main gear struts have been shortened half a mm, drilled out and some albion alloy .5 rod inserted. That lower sit compensates a bit for the angle on the nose gear.
y4mXv-GYc99NA5BLZCZWx-WHEvO1TRUGef6AgwjV
The LF model decals are printed a bit like the newer Eduard decals. So: inks on top of the carrier film layer, without top coating.
That also means you have cut them off the sheet individually.
Despite that, they are thin enough and handle fine.
y4mdLZTlls6VEWlE0le3I9o2ci0gxTx8KI4yIX7F
The P-39 models used by the Portuguese are different from the P-39Q kit in that they don't use the underwing gun pods, but instead use the 4x wing mounted guns.
So, drilled out the offset holes and added the barrels - again AA tube.
y4mpiqZVA8M34_JHr5MkfQ-bLy6J6PBhPR3_Zid0
The LF decals were sealed in with a thin coat of HG floor coating (a product similar to Future)
So now, a bit of detailing, satin coat and light weathering to do.
Congratulation @alt-92
Looks really smart especially now with the decals on.
I can't remember the last time I saw a Portuguese aircraft so this is even better for it.
I wonder if my old mate Jaime @jrlx has been watching this ?
Cheers Pat
Very smart, and nice to see some different markings. It looks a good kit in the box, and seeing it built up like this confirms it. Great work!
Great job and nice to see a historic Portuguese Air Force aircraft being built!
Pat, thanks for calling my attention to this build. I haven't been very active in Britmodeller recently and didn't notice it. By the way, I built this kit as a kid. At the time it was very refined compared to most kits available. I still have the remains somewhere.
Jaime
  • alt-92 changed the title to 154 - Bell Airacobra P-39 - Ota oddball #finished#
Very well done! Congrats!
Jaime
