Warrior FV510 TES(H) AIFV 1/35 by Meng
Faraway
Made a start today.
Usual Meng high standard of part to part fit and detail.
And the new track link assembly is most excellent. Far better than the tracks I had to deal with on a couple of their WW1 tanks.
Jon.
p?i=403a4bc216c3283df51368da3f384c85
p?i=ce79cfbace9c9acb6bd25d49be12ffad
p?i=3afc64e3e682b00e23dd5b532e42cb16
p?i=1b36daaac8fe2c5d211d60b76ce21c78
4 hours ago, Bish said:
Will be following this. Out of interest, do you have a photo of the running gear on the right sid.
I can do one of the right, but it’s the same as the left. There’ll be more to see, as my build progresses. I’ll be painting it as I build, an certainly before the wheels go on.
Jon
Jon
Thanks. I'm just curious to see if they have the suspension the correct way round as the Academy kit i bilt a few months back didn't. Looking at how the wheel stations are lined up on either side, it does look like they have it right.
I like the track jig, loks like it will make things easier.
The track jig is brilliant, you'd never join the links without it. I hope the following photos are what you wanted.
Jon.
p?i=b1b708649f40e7b50cd8f1b6e25d0992
p?i=0979c31da46cf607eaa9c6291f646b0a
p?i=3c8dc320a8707859f924a17e0f5a1125
p?i=26b70b2986b67a559bd541ea44287d27
And because of they way they are fixed in the centre of the hull, they provide a simulated torsion type of suspension. Clever.
p?i=44c1c56706f7913bbf82185de674bb22
Thank you. Thats good news. I was so dissapointed when i saw the error on the Academy kit, bt there was nothing i could do about it. At least if i decide to bild a 510 i know that will be right.
Didn't do much over the weekend, so had a bit of a binge yesterday and today.
First the wheels and rollers, I'm so glad Meng included a round metal mask for the wheels, although I kept blowing it off with the airbrush. But at least it allowed me to paint the rubber and then use it to spray the camo colour.
Jon
p?i=c147f68f4a9dcfc11d91b0e2dc3f63cd
p?i=082294d4491cf2205fe65b1615c3b0a7
p?i=0fb7a6bcd60776b1d5a8a8f19fdcd8a7
Next the hull, before and after painting. Still lots of small parts to fit, but shouldn't take too long.
p?i=ecbae3a25d5ebf460260ba390ebf0be2
p?i=9a402920bae0a0a234fc682eedc82977
Then the beginnings of the turret.
p?i=ec728a218f0a74c1af0ea07d00510864
And finally the track, which I have to say when together far better than I thought it would. I will paint the rubber pads tomorrow, when the metallic grey has hardened off. A quick dry fit, just to be sure.
p?i=79d00c76369faab80bd6245fa78a48ac
p?i=e766feb813d3275fb4ecac8b67e21dc7p?i=39434e46f388752f2ffa9acd8e61c9ea
1 hour ago, ivan-o said:
Looking good👍
Are the tracks good enough to not bother with after market stuff?
Ivan
Ivan.
I have no idea about any aftermarket tracks.
The only comparisons I can make are against the plastic tracks on the Tamiya ‘Easy 8’ Sherman, which do look like plastic tracks. And the other three Meng kits I’ve built, the British MK.V, the Whippet and the French FT 17. The MK.V and Whippet had the same track links, which clipped together and were very easy to break and some were not very well moulded, the French FT 17 had a similar system just a different shape. None of these were, for me, much good, they didn’t fit the vehicle very well and I certainly would not be expecting them to actually work. But that was probably down to my lack of skill. The links on this Warrior are a bit more substantial and quite easy to assemble and do actually work, not that I tend to push my models about.
So, I guess my answer is, the tracks are good, once assembled and painted (to my eyes) they look like they should. Although I’ve yet to finally fit them to the vehicle, that will happen in the next day or so. I’ll post some piccy’s so you’ll see.
Jon
Good Morning.
A few little bits fitted to the body and few more still to fit. I finished painting the tracks, very glad there was a metal mask which stopped me getting black paint all over the previously painted metallic grey.
Jon.
p?i=c867ca8b0c6ddc07588230e5f52a7490
p?i=b900dd78eeec0960af4b92d0e0cffd0e
p?i=36110552ea303f0694a5b97a3b45485f
p?i=411d476b439716c4c76175c6cf8f0b63
p?i=62def46e4d72c78fec48d5609baeebef
p?i=42c840490e18a00a384e4e1b901dcfb4
p?i=bab6c80fb041846b89b364c11dc40bb9
p?i=ef3e49e3a1fa42f2dd8e4247f60e8d00
That's it for today.
Tracks fitted and suspension working. Bar armour attachments fitted to the side armour, then painted assembled and fitted to the body. Then the corners fitted.
And thats the body just about done. I will be starting on the turret next.
Jon
p?i=ef030780c2e07d8a802b8f5129884fce
p?i=c51d9b3a0a183d7e019fa180b76e8160
p?i=d386a59bfa41bb1d604757a5541ec4dd
p?i=1eadd9f9a2fc6ef0a3bd469ff3ddae3fp?i=3977f689a8fd125769123039a80edaf8
p?i=0962486094e7f27fd619d22a5edeef87
p?i=ecf9d8e8b30931313e61879c750fbef7
p?i=7a7d130e06cddeb1106b2a89d3b5ef74
p?i=3dfba4765ce1478885069b837f5875eb
p?i=ca2983f53871cab3dbfe100638774c2b
Thats coming on very nicely. The track looks to tigt in your first pic, but that might be because its not sitting on the drive sprocket teeth.
Its interesting that the kit includes features that are completly covered by the add on armour, such as the NBC filter dor and external fire extinguisher handle covers. This might indicate an un-armoured version in the future.
You're right, the track is tight. The destructions advised 79 links, which is what I used, I did try it with 80 links, but to be honest it didn't look much different. And anyway, with the bar armour fitted. who's to know 😚
Jon
Jon
I've made the meng whippet which was very enjoyable and well designed. I've a few more in the pile which I'm looking forward to.
Those fire extinguishers look very good indeed. Are they the kit ones?
Nicely done.  That colour is spot on.  If you want an idea for a diorama, I was waiting for a flight from PB5 in Afghanistan watching a couple of lads trying to launch a desert hawk drone.  Launch, nose dive. Launch, nose dive.  They eventually got it airborne to a massive cheers from myself and the others intrigued by their efforts for it to fly 30 meters and lodge itself in the bar armour on a Warrior.  All things considered they took the howls of laughter well.
Everything you see is ‘out of the box’. The only things I added were the aerials, probably not to scale, but what the heck.
Jon.
Edited by Faraway
I don’t have the skill to do a diorama, but I can see it. Laughing soldiers, embedded drone. Brilliant.
Jon
Jon.
The antenna's look about right. I use the carbon fibre rod from Accurate Armour which are aimed at British armour. They look about the same as yours.
