Hasegawa X-29 What-if
From Wikipedia (link😞 ‘The Grumman X-29 was an American experimental aircraft that tested a forward-swept wing, canard control surfaces, and other novel aircraft technologies. The X-29 was developed by Grumman, and the two built were flown by NASA and the United States Air Force. The aerodynamic instability of the X-29's airframe required the use of computerized fly-by-wire control. Composite materials were used to control the aeroelastic divergent twisting experienced by forward-swept wings, and to reduce weight. The aircraft first flew in 1984, and two X-29s were flight tested through 1991. X-29 number two was maneuverable up to an angle of attack of about 25 degrees with a maximum angle of 67° reached in a momentary pitch-up maneuver.’
The Hasegawa X-29 is a great little kit of this unusual and striking aircraft: with good fit, nice detailing (including the complicated-looking canopy raising mechanism), and it goes together quickly to deliver a satisfying result.  Only two problems in my opinion: (1) the prototypes were painted gloss white and (2) the decals are a series of long stripes, which invite problems especially as Hasegawa decals are not always the best.  My solution, therefore, was a what-if scheme.  I’m not usually into WIFs but the extreme manoeuvrability suggested a potential ‘real world’ DACT (Adversary/Aggressor) application.  I had a set of Colorado F-5 decals, which included a gloss black scheme for ‘Red 23’ of VF-127 Cylons that looked like it would work on the X-29 and show off the unconventional airframe nicely.
To ‘operationalise’ my X-29 into a production F-29A, I raided the spares box.  A Hobbyboss F-5E donated its instrument panel, centreline pylon and fuel tank, wing pylons, arrestor hook, RWR antennae on the nose and tail, navigation lights and gunsight.  I added an airbrake under the rear fuselage, removed the bulge ahead of the MLG bay, and cut the main gear doors into two part … because I thought the single doors on the X-29 spoiled the smooth lines – my model, my rules 😉 The missile rails came from a Hasegawa F-16 and the antennae under the forward fuselage from a Wolfpack set.  The AIM-9L acquisition round is Eduard Brassin and the ACMI pod is built up from a Hasegawa AIM-9E and some metal rod.
Just a bit of fun and I like the result.
resized_5fad7e65-9802-4828-8483-3fce4cca
resized_527b31e7-7226-4723-b5cf-63e155b3
resized_ae89c5cf-4570-4d82-aae4-e001d54e
resized_6b899eb4-ddd1-4711-83d8-24e3eab7
resized_0862452d-177a-4da7-9183-02420346
resized_02d438ac-cd12-4ee5-bfa0-eeae2e7e
resized_d229a148-0ffa-4d64-ba72-2d6be0ae
resized_f2a79775-de4a-414a-aa84-ad18a747
resized_0a7fe041-9cd2-4081-97bd-5f605411
resized_bfc9c035-db5a-4fe1-b130-0a12a57f
resized_d1313cc6-8dc7-4df2-a5bb-26b34af0
resized_49f82cdb-04ca-430d-8a37-dc1cc0e0
  • Like 27
4 hours ago, russ c said:
Great looking Aggressor `whiffer`, cool scheme
3 hours ago, SAT69 said:
Very imaginative model building!  Good looking aggressor scheme!
2 hours ago, Natter said:
Your model, your rules and a great result.
Thanks guys, much appreciated!
Outstanding work! :clap2:
I was at Grumman at the time these were flying, and they were a great subject of coffee break conversation in Plant 35. The fly-by-wire systems used both digital and analog systems, each triple-redundant. Also the F-5A is the best possible source for cockpit detail as they were the donor for the forward fuselages. The MLG were from the F-16
Thanks @dnl42! The X-29 is a really fascinating collection of parts and must have quite something to see flying.  Although the F-5A would of course be the best source of cockpit detail, I feel the Hobbyboss F-5E sacrificed its parts in a noble cause.
On 9/19/2020 at 6:57 PM, theplasticsurgeon said:
Great looking model,  I really like the black look.
I built this kit as Hasegawa intended in 1988.
And again in 2019 - using leftover F-16 decals.
I remember your build @theplasticsurgeon - really nice work and it was one of my inspirations for this build.  I think the X-29 makes a great canvas for all sorts of what-if schemes
