LCM 3 Diorama Completed
longshanks
In the interests of some light entertainment I dug this out
P1110356
P1110353
Now there have been some excellent builds of this craft so I thought I'd go with a twist
Found these pics on Alamy. Great if you're looking for references
HNRR96
HNRR92
HNRR95
P1110358
No arguments on it being over weathered...
Stay safe
Kev
  • Like 12
  • Haha 4
That's the way I'm thinking at this moment.
Not sure if it's going to be possible to take a plastic kit to this state. The problem of course is the thickness of the plastic
:hmmm:
Re canning I see two possibilities. A la beefy I.e. a stiff talking to with a dremel. Or build a frame on top and skim the surface with foil. A method I  saw sometime ago in a Tamiya mag.
Then there's is the problem of the inner skin and exposed frames.
Might need to do some experiments
Stay safe
Kev
Don't know if this is any use Kev, but here are some pictures I took a few years ago of the landing craft that is preserved (sort of, not very well) just outside Calais in the D day museum there.  The rust patterns may assist, I have larger copies if they may help
landing craft
Steve
:hmmm:
Stay safe
Kev
I think I remember that article not sure if I still have the magazine will try and dig it out.
building a skeleton and covering would be best I think but then I would love to see what you do with that  :wicked:
Stay Safe
beefy
Kev, You could try it with 0.1 mm aluminium, I've used it a lot.  Easier than foil as its stiff and it cuts with a knife.  You can frame with the same material and it will provide slight curvature between the frames, not expensive
https://modelshop.co.uk/Shop/Raw-Materials/Metal/Item/Aluminium-sheet/ITM1055
Just a thought
Steve
Thanks for the ref pics Steve, always helpful.
You read my mind.... that's what I was intending. Not sure what thicknesses it is at the moment. Interesting to see the do different thicknesses'
:hmmm:   :analintruder:  :wink:
A long shot, I don't suppose anyone has any pics/drawings of the frame construction  of the LCM
Stay safe
Kev
This is all I could find of the LCM(3), not really frame details I'm afraid (from Design of British Warships Vol 3) but having a scale drawing might help as a start
LCM
Steve
WOW John some cracking stuff in that link that has just reminded me I have something from that museum in New Orleans a gift from my daughter about 15 years ago now when she did a leadership summer at camp america
The pacific was not a nice place to be at that time  :poppy: and we must never forget.
beefy
3 hours ago, Steve D said:
means the plating is 3/8ths
Thanks for that. Confirms my guess at 10mm thick.
I've scaled it to 1/76 and it fits nicely on a A4 so if you would like a pdf, at the right size, just ask
Yes Please. I'll PM you my email address.
2 hours ago, JohnWS said:
Here's a link to a website describing Higgins Industries WWII war effort.
Cheers John. Loads of interesting stuff on there......
Whilst were on plating ,the conning position was armoured with 6mm High Tensile Steel. My question would this be less prone to rusting than the material used for sides etc
Stay safe and avoid Humans
Kev
Been doing some experimentation on the Canning
1. Dremel, Tamiya glue & Mr Surfacer 500
P1110361
2.  Frame 0.4 x 0.75mm overlaid with 0.05 foil
P1110360
Frame layout this one 0.25 x 0.5mm. Used on no's 3,4 & 5
P1110359
1.
P1110362
2.
P1110363
Right to left
3. .25 x .5mm frame and foil
4. .25 x .5mm frame and kitchen foil
5. .25 x .5mm frame and 0.1mm plastic card
P1110364
P1110365
P1110366
At this moment I think I'm favouring developing no 3.
Any got any thoughts??
Stay safe and avoid numpties
Kev
  • Like 10
No 3 is good and certainly better than 4 I think, but I do like 5 as well.
Looking back at the original rusting reference pic, you could even mix methods to obtain a good result.
All very creative I must say!
Terry
Kev,
Nice work on preparing the samples.  Looking at the following photo, I'm thinking a combination of #3 & #5 - #5 for the sides & ramp and #3 where the most damage is at the midsection and near the bow.
Thanks for asking.
John
I would go a mix of 5# and 4# because 3# had to many burs showing on the outside unlike the damaged areas of your photos that show the metal curving in over
Just my 2 pennies worth
Stay Safe
beefy
This is a most fascinating project, which I shall, of course support with my customary vigour. It kind of reminds me of an idea I have been toying with for some time now. It occurs to me that many of these craft and Higgins Boats must have been sold off after the war for civillian use and something along these lines might make an interesting project.
Martian 👽
Hi Folks
Thanks for your thoughts/inputs much appreciated
I'm currently working on the Mk2, trying to incorporate the various ideas and framing.
One decision I have made. It will not be an exact replica of the above pics, not unless I can figure out how to work with lace.
It's a wonder some parts are still standing :shrug:
Kev
Yes, the burrs are inconsistent with a corroded plate. This looks like plastic sheet. Perhaps if you tried a wire wheel on that Al sheet you showed earlier? If the foil is thin enough, you might be able to abrade the material away.
