The next Italian kit pulled from the stash is this.
resized_15545c65-fd64-46b2-b751-57bf31ad
Initially designed as an anti aircraft gun, like the Flak88 it was also used as an anti tank weapon.
This is is a simple kit comprising of a single sprue of not many pieces. The plastic is softish, not quite as soft as the old Airfix polythene figures, and it does sand, albeit it needing a fair bit of heft. And it is crisply detailed but I do worry about whether solvent will glue it together.
resized_2f010978-7a0d-4d45-a849-409ad814
And another sprue with 8 crew. Same plastic and it's just as well it sands as there are seams and moulding pips aplenty.
resized_fe41c554-37ff-449a-9a44-2d3434e8
Simple instructions on the back of the box, although the painting details for the figures are nice.
resized_e8b1b0dd-77d3-42fc-b379-ecc830a4
It shouldnt take take long to build but it'll be good practice for another Italeri dragged from the stash.
resized_022b5b76-39c4-4e3d-ab45-5f15a733
  • Like 13
Interesting subject 825. A nice addition to the Italian contingent.
This looks cool, also like the fact it comes with ‘servants’ I thought luxury’s were only saved for officers in the WW2 Italian army!
Rob
Thanks @Ozzy and @SoftScience it's fairly straightforward and fun to see it coming together so quickly. After a little while we are here. First the base assembled
resized_919c920c-0f77-4ee9-9424-eceae2a0
and the gun
resized_57a1b2c7-a119-4376-8bff-df77f864
then the seats and mount
resized_f97d6487-722d-4cea-b270-914ce64a
resized_a59c4ed5-2fdd-4409-ac0e-8ef5c986
Put them all together and we have a cannone
resized_9b5df798-14f0-4e54-a767-46f9ed99
Now with a coat of paint on.
resized_575c1a7a-a4dc-44be-8b39-e61d6448
Shows that a little bit of cleaning up is needed.
Rob
It's not only the Italians Rob, I've got a Pak 40 which has servants too. Here are the Italian servants cleaned up and painted.
resized_af15308b-39c8-4554-b95b-80837197
3 hours ago, Ozzy said:
Coming along nicely, fantastic figure painting.
Thanks Ozzy.
Ive cleaned up the seams, put some more paint on and dry brushed the base plate with Gunmetal. I've put the two seated crew on but they were not the willing servants and kept falling off. They're also impervious to solvent so I'll probably have to break out the cyano.
Almost done though.
resized_86058683-3a67-47e7-b054-c65e4ab2
The plastic on the crew is quite soft and the paint has tended to rub off with handling. I'll put a coat of Kleer on and see if that helps. Once dried I'll touch the paint up, it's mainly the rifles and hands, then seal again with some matt varnish.
Good morning 825
Congratulations that really looks good, great detail moulded into the parts as well.
Makes a pleasant change getting figure painting info as well.
Cheers Pat
On 10/2/2020 at 9:23 AM, JOCKNEY said:
Good morning 825
Cheers Pat
Thanks Pat. It was a bit frustrating to re-do some of the figure painting but a coat of Kleer before touching up and a a coat of matt varnish afterwards has done the trick. I also managed to glue the two seated crew with Gator Grip. You can see how the paint rubbed off here.
resized_48652745-491f-412a-969e-c35ea12e
All tidied up and effectively finished.
resized_01b8951d-b70e-48cc-83af-694f551b
