Mosquito camo schemes
Hi,
apologies in advance - since I have not really searched that hard but.. My question is - did Mosquitos ever use that "temperate" scheme (brown, green and whatever the underside is called) operationally?
The reason I ask is, I was pretty sure they never did, atleast not for very long or very much at all but this game War Thunder, maybe you know about it, has its Mk. VI with that scheme. Made me a bit curious.
I am not an expert, obviously, but I seem to recall from one of those modeller books on it, that it was "day fighter scheme" or variants there of plus Coastal Command schemes only. Well and then the night fighters..
From what I know, the very first bomber version (B.Mk.VI series 1) did appear in the Temperate Land Scheme of Dark Green, Dark Earth and Sky. These aircraft had the shorter rear engine nacelle fairings.
Cheers.. Dave.
Yes, South East Asia Command (SEAC) used Mosquito's that had been built in Nightfighter colours,  overall Medium Sea Grey with Dark Green disruptive pattern,  and had Dark Earth added on top when delivered.
Just now, Rabbit Leader said:
Mk.VI Fighter Bombers flown in SEAC by No. 45 Squadron, however they had Azure Blue undersides.
Any reason/proof why the had Azure Blue?  Other aircraft in European colour retained their Med Sea Grey undersides is all.
I'll put a @tonyot
The only colour image I know is the Mosquito on the right here,  a better image perhaps would show more
HTH
Looks like I may have quoted some incorrect information - apologies. A quick google search seems to show that many other modellers may have fallen for the same trap. I’ll remove the ‘Azure Blue’ text above, however it’s probably all a moot point as the OP clearly mentions Mk.IV’s so this discussion is essentially irrelevant.
Cheers.. Dave
the OP says VI (6) not  IV(4)
The War Thunder does have a DG/DE/Sky Mosquito  https://forum.warthunder.com/index.php?/topic/119983-mosquito-visual-model-errors/
also has this SEAC Mosquito I'd not seen before
0_0_0_0_307_222_csupload_52231120_large.
The undersides do look dark,  but then the whole picture does.
That’s two errors in less than one hour!! Clearly it’s been a long day, time to fall on my sword (aka Pineapple) and call it a night!
Cheers.. Dave
The presence of Azure on the undersurfaces of Mosquito Mk.VIs in SEA is supported by Paul Lucas in the relevant volume of the SAM Combat Colours series (Number 6, DH Mosquito Day and Night Fighter Service, 1941 to 1945).
Here he mentions the relevant AMOs and bases on these his opinion that Azure was used for the undersurfaces of these aircraft. At the same time he also mentions how it is not possible to state this without any doubt.
The same Lucas mentions the existence of a proposed scheme with the same colours for use on Mk.IVs, scheme that was approved for a very short time and then rejected in favour of the Day Fighter Scheme we usually associate with Mosquito bombers. The information is Number 5 of the series, covering PR and bomber use of the Mosquito. Again, he mentions that it is impossible to state with absolute certainty that such scheme was used, while at the same time proposing possible profiles showing the scheme
In the same volume the use of a more standard TLS is mentioned regarding the earliers Mosquito bombers.
Edited by Giorgio N
Cheers.. Dave
Nah no need for that! Makes me seem more clever after all! ;) I am usually the one doing stuff like that.
Thanks guys. Yeah I mean the Mk. VI as in 6. Great link Troy, not seen that one. And I did not know about those SEA ones, mostly think about the Coastal Command or others, so good point. But for Eauropean Mk. Vis, grey-green should be the scheme then, right?
If the WT "model" should be a SEA one, it has the wrong roundels anyways?
I'll put a @tonyot
HTH
Oh crikey!
I originally went along with the Azure Blue undersides and painted my model with these,.... but the more I`ve thought about it and looked at photos,..... they have to be Medium Sea Grey!
          Tony
In 1943 there was a rationalisation of Mosquito paint schemes,  they were to be finished either in PRU Blue (PR variants) or Night Intruder, overall Medium Sea Grey with Dark Green disruptive pattern on upper surfaces.
as seen in this factory shot
12838776694_5d0be5f91e_b.jpgFinal assembly of Mosquitos,  1943. by Etienne du Plessis, on Flickr
Any specific requirements were then done at MU (Maintenance Unit) or unit level,  so Coastal Command FB.VI's got repainted in to Extra Dark Sea Grey over Sky.
15474365966_9b744d18a7_c.jpgMosquito FB.VI, 1944. by Etienne du Plessis, on Flickr
A few FB.VI's got bomber colours,  which had Ocean Grey and Dark Green uppers, these are B.IV from 1943, but show the colour
8035084867_3374ace3b0_b.jpgMosquito B mk V's       1943. by Etienne du Plessis, on Flickr
More period Mosquito colour here.
Flickr Search
There is a useful, but limited monograph to Mosquito fighters in NW Europe
De%20Havilland%20Mosquito%206%20(01)-960
here
https://boxartden.com/reference/gallery/index.php/Modeling-References/Camoflage-Markings/06-De-Havilland-Mosquito
Very good for what it covers, and has details of the factory camo pattern and marking positions and sizes applicable to other versions.
Interesting, though given Mosquito's were reasonably late in arrival in SEAC (late 44?)  and the SEAC standard then was to add Dark Earth seems a lot more repainting.
Though this image, I did notice that the roundel centres, presumably 'India White',(a mix of 5 parts White to 1 part Roundel Blue as pure White was too bright)  look a very similar tone to the rear of the nacelle in direct sunlight.   A thought occurs, if this has Azure Blue undersides,  perhaps the roundel centres are as well?
I've seen very few SEAC Mosquito photos in camo,  as they then switched to overall aluminium dope, this also shows India White roundel centres
49643083246_03056db6a4_b.jpgSEAC Mosquito, 1945. by Etienne du Plessis, on Flickr
Also, just noticed, the wing slipper tank looks blue,  bit green for Azure Blue, but WW2 colour can be funny.... leftover slipper tank in Azure Blue?
HTH
Some BOAC (Civilian operated) Mosquito IVs also appeared in the temperate scheme of Dark Earth, Dark Green, and Sky
There is a surviving chunk
http://ww2f.com/threads/unique-boac-mosquito-relic-emerges.44424/
"It's the starboard underwing fuel tank cover which fitted between the engine nacelle and fuselage. One can clearly see the underlying sky blue colour, overpainted in early 1944 with Light Night Black. At the same time, the codes were overpainted from Black to light grey. The identifying National Colours of red/white/blue are still clear."
do read the link for full details..... I was used as a shed door for years!!!!!!
That I actually did know. :) I live very close to where some of them flew (Stockholm).
Thanks again Troy, very helpful.
Hi,
Not exactly Temperate Scheme though very similar - The early locally made Mosquitos for the RAAF were painted in Foliage Green, Earth Brown and Sky Blue scheme -
http://grubbyfingersshop.com/index.php?main_page=product_info&cPath=5_49&products_id=277
I don't think this scheme was used operationally though - most were in all Silver or the later Grey/Green scheme.
Michael
