Ta-Daa! Only 11 years in the making, I started this in 2009 (When HL brought out the Panzer III) and got disillusioned 6 months later when they produced the StuG. The recent lockdown prompted me to revisit all the half-finished models, and this was the oldest.
It's based on the HL Panzer. All the superstructure forward of the engine cover was removed, and the StuG crew compartment, gun and schurzen scratchbuilt. I also gutted the interior, stiffening the hull sideplates with 3mm styrene for full metal suspension and tracks, and fitting an aluminium plate in the front to take Mato metal gearboxes. It also has the Asiatam recoil system and the new fan powered smoker. Due to it's vintage it is still running the TK-13 main board. I also fitted a bigger speaker, moved the battery to the inside of the hull and added a charging port under one of the rear engine hatches. The left hand main engine hatch is hinged with access to volume control, off/on and smoke on/off. It's very crowded inside the hull!  I also added some aftermarket (tiger) parts that were suitable, reskinned the mudguards and hinged the ends. Lots of clips and brackets were fabricated from brass, the MG shield is completely made from brass.
Basic hull layout
IMG_3368
Gun location and recoil
IMG_3384
Switch panel
IMG_3382
With all the bits and pieces on it (and the lack of Zimmerit) it dates to about May 1943 production. It will get weathered slightly, I just need to find some muddy puddles.
IMG_3511
IMG_3509
IMG_3506
IMG_3505
IMG_3502
IMG_3523
IMG_3522
IMG_3518
Hope you like it!
Thanks guys. I will do a video, but I'm a bit busy moving house, so it may be a while...
Sign in to follow this
