1/72 Academy P38 F5B Lightning GR 1/33 Belfort Borgho Corsica August 1944
Good evening
 For my first build in this Gb I will convert the 1/72 Academy P38J Lightning into an F5B I will represent of of the aircraft of Groupe de Reconnaissance 1/33 Belfort based at Borgho airfield Corsica in August 1944
The  box art
The sprues
I have an old Contact Resin set wich comprises a new resin nose and 3 wheels
And a decals sheet
I have these add ons but I am not sure to use all of them
Some reading
See you next Saturday for the start of the build
Patrice
  • Like 12
Welcome to your GB Patrice 😀, I do like the P-38 so looking forward to this build.
Good morning Ozzy
Thank you I will do my best with this build ..
Best Regards
Patrice
I am quite interested in Corsica based stuff, and Sardinia too
2 hours ago, Planebuilder62 said:
Lucky man having an Academy P-38. I built one recently and it went together very well. They are impossible to finf anywhere these days.
Good luck and happy building Patrice.
regards Toby
Good morning Toby
Thank you for your support
Maybe you can try here
https://www.scalemates.com/kits/academy-2209-p-38j-lightning-pacific-theater--103277
Best Regards
Patrice
Good evening
I managed to start my build today , I cut off the nose where I will place the nose resine part
 200913062717663164.jpgres
After a few dry test fitting I realised that I will have to use some filler when I will place this resin part
I also startd to prepare the cockpit  I placed the Eduard instrument panel  and some small PE parts on the side walls
Patrice
15 hours ago, John Masters said:
Looks good so far.  Is that St. Ex on the cover of the book?  I think was his group, yes?
Good afternoon John
Yes It is St Ex on the cover , he was killed on 31 July 1944 flying the aircraft serial 268223...
Patrice
Good evening
 Yesterday I glued the belts on the seat
And today I placed the seat , the stick and side walls
Patrice
Looking forward to this. The Little Prince was one of my kids’ favourite books. And I love a P-38! The Academy kit is reputed to be a good kit, so I hope it works for you.
Regards,
Adrian
Regards,
Adrian
Good morning Adrain
Thank you for your comment , I enjoyed reading The Little Prince too when I was a kid ...
I have already built several Academy kits and indeed it is a very beautiful kit and the best at this scale ..
Best Regards
Patrice
Good evening
Today I placed the ''cockpit assembly" between the wings
And I also started to prepare the booms
Patrice
Good evening
 Today after some sanding and filling I placed the resin nose
Then I placed the booms on the wings
Patrice
That looks great. I don't suppose that is "vert pomme" you have used?
The whole plane is coming together beautifully.
Good evening Tony
I used Humbrol 226 Interior Green but as the photo is taken with a flash the result looks a little too green ..
Best Regards
Patrice
1 hour ago, TEMPESTMK5 said:
Good evening Tony
Best Regards
Patrice
Thanks. This "pomme vert" referred to by Heller in their instructions is a bit vague. I'm going with Humbrol 78, same as pretty much every interior I've ever done...
Good morning Patrice. Hope you don't mind me following along but the combination of a reconnaissance aircraft and French marking is too nice to resist :wub:
Good afternoon Col
 Welcome aboard and thank you for your interest ...
Best Regards
Patrice
Good evening
I realized that I had forgotten to put some weight , so today I worked to repair this omission and succeeded in putting a little lead in the engine nacelles and the nose I hope that this will be enough. I also added a few pieces here and there ..
Patrice
Looks to be taking shape nicely for you Patrice and a good save fitting the weight.
Good morning Col
Thank you for your comment and support
Best Regards
Patrice
