1Coroner 108 Posted November 29, 2020 Author Share Posted November 29, 2020 Hi Paul .... Thanks for the heads-up. I haven't looked closely at the front of the bonnet yet. But I do plan on adding all the inner panels, so I'll probably hack away at the headlamps as well. Link to post Share on other sites
1Coroner 108 Posted November 29, 2020 Author Share Posted November 29, 2020 Added more detail to the starter, fabricated the clutch slave cylinder and the oil pressure sender. Also the core blanking plate at the back of the block. 7 Link to post Share on other sites
1Coroner 108 Posted December 6, 2020 Author Share Posted December 6, 2020 Once I got all the diagonal subframe stringers placed, it became obvious that the kit did not accurately model the underbody plates (which are removable in the real car, but I will keep them fixed). 3 Link to post Share on other sites
1Coroner 108 Posted December 12, 2020 Author Share Posted December 12, 2020 Added the radiator fan motor bracket, the rear engine mount bracket and a bracket on the right firewall that actually isn't used for anything on the USA spec cars. Painted the aluminum parts of the engine. Sump fins turned out pretty convincing. 3 Link to post Share on other sites
Brandy 13,318 Posted December 12, 2020 Share Posted December 12, 2020 Just found this and very impressive it is so far! I can totally relate to modelling your own car as I owned a 1972 MGB in the 90's and recently picked up a kit to model it. The closest I got to an E-Type was a test drive of a '66 roadster which I really wanted back in '85. Needless to say I never got it.... Still yearning..... Ian Link to post Share on other sites
1Coroner 108 Posted December 13, 2020 Author Share Posted December 13, 2020 Just about done with subframe and bulkhead modelling. Next a color coat and then start adding things like brake booster and vacuum cannister. 2 Link to post Share on other sites
ElectricLightAndy 337 Posted December 13, 2020 Share Posted December 13, 2020 Wow, you are clearly a wizard. This is looking fantastic, I have a 1/16 XJS that I want to make into a replica of my own car one day, but I highly doubt it'll be this good! Andy Link to post Share on other sites
Vesa Jussila 621 Posted December 13, 2020 Share Posted December 13, 2020 Excellent work in details. Link to post Share on other sites
Paul H 332 Posted December 13, 2020 Share Posted December 13, 2020 That front subframe looks really accurate and realistic - I hope I can get mine to look even half as good when I get around to working on it again... Link to post Share on other sites
1Coroner 108 Posted December 13, 2020 Author Share Posted December 13, 2020 Thanks for the feedback and encouragement guys! Brandy, are you going to start a thread with your MGB build? Link to post Share on other sites
1Coroner 108 Posted December 16, 2020 Author Share Posted December 16, 2020 The e-type has a cylindrical cannister called a reservac mounted on the left kick panel that store manifold vacuum so you can get two or three boosted brake applications even if the engine dies. It is only accessible from underneath, hence the D-shaped opening in the under panel. Not included in the kit, so I had to make one from wood and plastic. 4 Link to post Share on other sites
1Coroner 108 Posted December 17, 2020 Author Share Posted December 17, 2020 Made the brake booster and master cylinder. And, happily, the end of the cylinder ends up just over the subframe diagonal where it is anchored with a small bracket (not made yet). 4 Link to post Share on other sites
1Coroner 108 Posted December 24, 2020 Author Share Posted December 24, 2020 First color coat and added the brake booster/master cylinder, reservac and screen wiper motor. I painted the brake booster brass, then a light mist of gold and a mist of aluminum. Made a pretty reasonable cad plating. 8 Link to post Share on other sites
Pouln 681 Posted December 24, 2020 Share Posted December 24, 2020 Very nicely done. Lovely details added. Link to post Share on other sites
Paul H 332 Posted December 24, 2020 Share Posted December 24, 2020 With the right background, that would pass for the build up of a real E Type front subframe! Link to post Share on other sites
1Coroner 108 Posted December 26, 2020 Author Share Posted December 26, 2020 Added the pedal boxes, brake and clutch cylinders, brake reaction valve and the blanking plates for the opposite toe box. Next up; scratch-build the radiator fan motor and heater valve. 7 Link to post Share on other sites
1Coroner 108 Posted December 30, 2020 Author Share Posted December 30, 2020 Heavily modified the heater box. Temporarily fitted it and the heater water valve to the bulkhead. The slot in the bottom of the box is part of the air diversion system when not needed in the cabin. 5 Link to post Share on other sites
1Coroner 108 Posted January 4 Author Share Posted January 4 Made the radiator fan motor and fan blade. Yes, it really is that primitive .. no twist or camber. More like a lawn mower blade than a fan. Made the torsion bars and installed. The lower suspension a-arms in the kit actually do have the torsion bar hole, but the bars were not included in the kit. Installed my improved steering rack and improved sway bar. The kit has the dampers installed upside down, so I fixed that. I am not planning on having working front suspension so I glued a lot of the joints. 4 Link to post Share on other sites
1Coroner 108 Posted January 6 Author Share Posted January 6 Made the steering column and mounted the battery and heater box. Next will be the hoses that run from the bulkhead to the heater valve and heater box. I'm going to experiment with shrink-tube over solder. 1 Link to post Share on other sites
1Coroner 108 Posted January 18 Author Share Posted January 18 So I experimented with shrink-tube over solder for the small heater hoses and it did not work very well. Unless the shrink-tube is very close to the same diameter as the solder, it tends to get wrinkles. But what it did lead me to discover is that the next larger size of solder is a VERY good method of making hoses with tight right-angle bends. It does not kink but makes a beautiful full-radius curve. Painted with a coat of black Vallejo it makes a very convincing hose. I am now experimenting with the best way to make the hose clamps. More to come .... Meanwhile I had purchased a Molotow chrome pen which I was going to use on the cylinder head dome nuts, but I wasn't sure how I would get access to some of the sides. Instead, I disassembled the pen and dumped the contents into a old Testors bottle and painted the dome nuts with a small brush. The photo does not do it justice. The results are FABULOUS! My Panther with a Jaguar engine is parked in my heated garage about ten feet from my modeling workbench and when I open the hood to compare the real thing with the model they are indistinguishable. Very pleased with how it turned out. And you can airbrush the Molotow as well, which will come in handy later on. 5 Link to post Share on other sites
Pouln 681 Posted January 18 Share Posted January 18 Yes, molotow does work great with brushes. Even better when diluted a bit with IPA. That’s why I ordered the refill bottle together with my pen. Great stuff. Looking very nice on the cylinder head. Link to post Share on other sites
1Coroner 108 Posted Saturday at 11:51 PM Author Share Posted Saturday at 11:51 PM Fitted the heater hoses. Used Scotch metallic washi tape for the clamps. Next I'll try making the throttle linkage. 4 Link to post Share on other sites
