HMS Duncan and Admiral Gorshkov in the Channel
Thought I'd take a break from aircraft modelling and while rummaging through a stash box, found these warship models I picked up earlier this year while ordering wargame parts for a diorama. I was planning to make something for the Anything But Injection GB of @Mjwomack so this would be my entry for this year.
They are from GHQ, their 1/2400 Harpoon wargame series. Whitemetal with very simple assembly (in fact Gorshkov came as a single piece) but surprisingly good detail and even a sprue of helicopters each. Base here is just a quick test on some watercolour paper, I will probably try and do a slightly larger version of this to represent a Channel escort operation - they usually have a bit more distance between them.
Work today was to prep up both ships with Vallejo primer, then painted Duncan. I used Light Ghost Grey and a mix of Med Sea Grey on the hull and Neutral Grey for the decks. Seems similar to the photos of the ship - although the greys do look completely different in every photograph.
Some details in white and black. Need to raid the decal stash for numbers and flight deck details.
And complete. Pretty happy with this one, the GHQ ships are lovely and I'll probably have a look at a carrier group next. The sea worked better than I expected, maybe overdid the wake a bit - I'll assume that the Russian sailors were testing the British crew by speeding up.
