Heinkel He 111 E-3, Invasion on Poland, September 1939, Roden 1/72
Hi
It is my first build (of planned four) done within STGB Heinkel He 111. Model presents variant E-3, kit by Roden, scheme almost from box (V4+BH instead of V4+AB).
Machine was from I./KG 1 Hindenburg, used in invasion on Poland in September 1939. It is exactly 81 years ago...
50291149466_30da729bb7_b.jpg50291149666_dcae4c584f_b.jpg50290474878_e55aec7163_b.jpg50290475118_e68ef0dc14_b.jpg
Comments welcome
Regards
Jerzy-Wojtek
  • Like 52
I’ve read that this is a very difficult build, but you’ve made a very good job of it !
Wulfman
As Wulfman said, this kit has a reputation for poor fit and other challenges. That's why mine is still in my stash. What was your experience with it?
Very nice work on what is, based on what I read above, a very difficult build. May I ask what scale that is?
Wulfman
Thank you! There are indeed problems with fit...
All parts inside are two large - simply during design it looks like the thickness of elements like fuselage or wings was neglected. As result all inner parts are about 2 mm too large in each direction... So there is some work with downsizing inner parts. When you do this the work goes on ....
1 hour ago, IanC said:
A rare bird. Nicely done.
Thank you :)
20 minutes ago, VG 33 said:
Congratulations Jerzy for this Roden not so easy kit.
Patrick
Patrick, many thanks! it is not easy kit indeed, but if you are aware that all inner parts are simply too large, you can overcame problems.
19 minutes ago, woody37 said:
Great result, this kit has a reputation all of it's own.
Thnak you. Surely this is not Tamiqawa quality of fit...
Thank you, the scale is 1/72 (in topic quoted.. :) )
Regards
Jerzy-Wojtek
Wow! Nice legacy Heinkel! From what I have read, it would be easier to get a big block of balsa and carve away everything that doesn't look like an He-111E. You have really done something to make the kit actually look like the real airplane. One reason why mine has been sitting on the shelf gathering dust for many years- but the early Heinkels are such neat-looking bombers, especially in the three-color splinter scheme! Well done!
Mike
Congratulations for completing this kit as I know it is a monster of ill fitting parts (I have one as the foundation of my shelf of doom!).
Duncan B
Nice to see one of those finished so well. I've always liked the early He111s because they look so different to the later versions. I have one of those Roden kits in my stash but for all the same reasons mentioned above by others, I've never had the guts to tackle it.
I was going to ask how the kit was, but reading all the other comments answered that question😬.
However, you did an outstanding job on the build, and the paintwork is superb😀.
Mark
Very nicely done, you don't often see that version
Mike
Thank you, Indeed one can tell that there is a difference in fit between Roden and Hasegawa kit... ;)
On 8/31/2020 at 11:36 PM, GrzeM said:
Very well done!!!
Thank you, appreciated!
On 9/1/2020 at 8:29 AM, Vinnie said:
Nicely beaten into shape, Jerzy and well done with that splinter scheme.👍
Thank you!
Duncan B
Thank you. Do not give up! Maybe you can still do it.
Thank you. In fact I think that the Roden kit is not that bad as it is fame! The next one (G-3) which I am doing one will be maybe even more different from typical H or P variant.
Mark
Many thanks!  I like the early Luftwaffe camo, it is challenging a bit but result can be ok. I am planning at least next two more airplanes (this time from SCW, He 70 and Ju 86 D) in such scheme. They are rather close to top of stash...
Thank you! in this STGB i am going to do a kind of review of He-111 variants. Besides this E-3 there will be G-3, H-3 or H-4 and Z...
Regards
J-W
A very fine job!
I've always been fascinated with how these early versions had a conventional cockpit and nose; developing later into the forward "glass house" we're used to seeing in later campaigns.
I've no doubt you wrestled with the build process, but it certainly turned out extremely well!
Congratulations. A very well done model. The internal structures (particularly the bomb-bay) are difficult to fit, the fuselage halves don't close without effort, the gaps between wings and fuselage are huge, and the canopies fit "more or less" (I built one of these Roden He-111s once...). Epic.
Congrats Jerzy !! very good looking Heinkel !!
Rarely seen and that is beauty !!
Well done my friend !!
Sincerely.
CC
On 9/2/2020 at 4:54 PM, Mig88 said:
Lovely job on that difficult kit!
Miguel
On 9/2/2020 at 11:36 PM, RMCS said:
Lovley
Miguel and RMCS - many thanks, apprecieted :)
On 9/3/2020 at 4:23 AM, kapam said:
A very fine job!
Thank you :) . The build is a bit challenging indeed, but troubles are predictable after first shock :) - problem is with all inside parts over sized by a thickness of fuselage or wing plastic. So when you realize, that all inside parts must be diminishing it goes well then. The fuselage-wing assembly needs some "rehearsal" and careful and appropriate use of file and small amount of filler then...
On 9/3/2020 at 7:42 AM, Corsairfoxfouruncle said:
Beautiful Stunning and Impressive ! :worthy: ... This is my favorite version and you have done it justice.
On 9/3/2020 at 11:50 AM, MickE said:
Looks great well done! 🏆
Corsairfoxfouruncle and MickE - many thanks, you are very kind!
17 hours ago, Orso said:
I am impressed. You don't see it built very often and having tried to build the 111C I understand why.
Mant thanks! Indeed, not too often they are on RFI, but they appears. Dont give up, still you can do this :)
Sincerely.
CC
CC - many thanks. I appreciate your comment, mate.
Best regards
Jerzy-Wojtek
