Christer A Posted August 29, 2020 Share Posted August 29, 2020 This little GB is guilty of a lot of things. Initially I had plans of joining up with just this with some decals from this set since I wasn't that much "into" Tornados but then Eduard released their Desert Babe boxing which _I just had to have. So then the plan changed.... But after a lot of chat with @Aigoreabout what kind of AM stuff to add to that one something strange happened. The German Tornado came back on track, since who cannot like a green mean machine? Yes, the Norm-83 wraparound colors does really scream Cold War doesn't it? But a mean looking machine must also have mean looking weapons. Enter the MW-1 dispenser pod. https://de.wikipedia.org/wiki/MW-1 Hundreds, even thousands of bomblets and mines to be dropped on top of Warzaw Pact troops, armour, runways, ships and other military targets. Naturally, there was no MW-1 available (let's not mention the Hobbyboss version) so I had no choice but to make my own. See here how that went Since the little project really kicked my brain into Luft-88 mode (or what do you call Cold War in West Germany nowadays) there was no turning back. This needs to be built, it needs to have a MW-1 under the belly and it must be loaded over the cockpit sills with resin and other stuff. So, a hopefully @trickyrich approved amount of candy is here. First the big parts: And then some of the smaller stuff: I also have a sets of those fabled wing seals from Shaun of the Tornado SIG coming, and I might still need to get a Brassin BOZ-pod and some HaHen-walkway decals, but other than that I think I've got everything that I need. Let's get this show started! 9 Link to comment Share on other sites More sharing options...
exdraken Posted August 29, 2020 Share Posted August 29, 2020 Oh wow! You are up to something here! Do I need to change plan now? Because my resin assortment is mimimalistic when compared to yours.... Which Swuadron is 45+85? Link to comment Share on other sites More sharing options...
Christer A Posted August 29, 2020 Author Share Posted August 29, 2020 1 hour ago, exdraken said: Oh wow! You are up to something here! Do I need to change plan now? Because my resin assortment is mimimalistic when compared to yours.... Which Swuadron is 45+85? This is probably not possible to finish within the alloted time unless another Covid short term lay-off happens, but we'll see. No need to change your plan! More Norm-83 to the People. This is the B variant of that Scheme. The decals in the Mark 1 set is for 45+85 when it was used by AG 51 as a recon bird in the eraly 2000:s. At that date I think it should be a modernized cockpit (ASSTA), but I'll try to backdate it to late 80s instead. I'm just hoping that they'd were tasked to use a MW-1 att that time... 1 Link to comment Share on other sites More sharing options...
Colin W Posted September 3, 2020 Share Posted September 3, 2020 Wow thats a serious amount of resin. The undercarriage on the Revell kit is stronger than the Italeri version but you might be challenging it! Good luck and looking forward to the final pictures. Colin W Link to comment Share on other sites More sharing options...
Christer A Posted September 4, 2020 Author Share Posted September 4, 2020 Thanks Colin! The landing gear is hollow of a sorts so there is a possibility to add a strengthening pin, but since it doesn't bend out to the wheel axle it think it's not worth the effort. I'll take my chances with the plastic It just happened that I made a false start during the last few weeks in starting to cut and clean up the resin bits. 😇 I must say that the main wheel bays looks magnificent and are a great leap compared to Revells very basic attempt: The nose gear bay has a huge cast plug that needs to be removed. That wouldn't be so bad except for the fact that the cockpit floor goes on top of it, so one need to carve away alot of resin. Well, I do have a motor tool for this (battery powered Dremel) so it want quite swiftly to grind it down. Too swiftly! Ooops! Well, it looks a bit worse on the outside compared to the inside. Once it's installed in the fuselage and painted/weathered I'm sure it will not be seen. I hope. However, the Revell plastic has some interesting features where the nose gear bay goes. Those two long cones to the rear must go to fit this the resin, that's for sure. I see that the plastic has cutout for them, but I can't understand why? Oh well, I don't need to worry about them on this build. 5 Link to comment Share on other sites More sharing options...
Christer A Posted September 7, 2020 Author Share Posted September 7, 2020 The main wheel bays were painted with FS 36622 by Gunze after I read somewhere over that the Tornado SIG that this is the color of the bays and normal access areas and not white. Some old red decal stripe was also added, just to spice it up a bit. Then one needs to get this lump of resin into the fuelage. First one needs to cut off all supports and struts that Revell provides. Then, the air intake/wing box stiffener/major construction element needs to be attacked. It has four bulkheads, two for each side of the wheel bay and one in front and one at the rear. The rear bay wall was deleted and I decided to thin down the front one, just to help with guiding the resin part. Aires wheel bay is flat, but it must also use the grooves as locators, but with a reasonable amount of force it would be possible to install it. At least the dry runs were promising, and no gaps were present so I decided to press on, and CA-glues the bays to the bottom part. Then I though about the side walls. There could be a quite tricky join from the back stretching rearwards and I didn't want to add huge amounts of filler there to cover it so they were installed to, almost without gaps! If I had been more careful in sanding away the injector marks, then it would have been almost a Tamiya fit! Let's hope the primer helps a bit here! After all this I finally attached the intakes with some brutish clamping action. The rear bulkhead isn't glued in yet. It seems that it would be prudent to do that after the top lid comes into place, since there are slight differences in width there. So far so good! Now I just hope that the resin wing seals arrives so I can start having fun with the wing. 6 Link to comment Share on other sites More sharing options...
Jabba Posted September 7, 2020 Share Posted September 7, 2020 A lot of work to get those U/C bays to fit, but well worth it. 1 Link to comment Share on other sites More sharing options...
Christer A Posted September 7, 2020 Author Share Posted September 7, 2020 Thanks Jabba. I'm thinking of leaving the air brakes open, just because I'll close the wings. Some rivets and slight details were added and then I hit it with some primer. It is however very clear that one also needs to do more, like adding those holes in the little trench and redo all pipes and wires. But that's the fun part, right? Here's a picture for reference: https://b-domke.de/AviationImages/Tornado/2994.html 2 Link to comment Share on other sites More sharing options...
Christer A Posted September 10, 2020 Author Share Posted September 10, 2020 Here's yet another episode in "How to not do it" I was going to prepare the Aires cockpit tub for placing it into the fuselage. On the outside of the tub there were a helpful scribed line that gave a nice stepped profile so I followed that one: To this part the front cockpit floor is then added which in this set actually is a resin copy of the Revell kit part! Ok, so joining this to the bottom och the resin tub and then check how it looks towards the Aires resin nose gear well. But wait! There are gaps in the cockpit sidewalls!?!?? But I did cut no deeper than the scribed line? It turns out that there was another line ON THE INSIDE OF THE TUB that I should've followed. Thanks for that Aires! Oh well, I'll fill the gaps with some plastic strips then. I still don't have a clue how the fit towards the bay is... 2 Link to comment Share on other sites More sharing options...
Marlin Posted September 10, 2020 Share Posted September 10, 2020 Oh bummer. But thanks for the headsup on this Christer. Hopefully you can fix this. /Bosse 1 Link to comment Share on other sites More sharing options...
Jabba Posted September 10, 2020 Share Posted September 10, 2020 How wonderful on Aires to put the line that you are meant to follow on the inside of the part when you cut on the outside. Hope that all goes well on the fix that you intend to do. 1 Link to comment Share on other sites More sharing options...
helios16v Posted September 11, 2020 Share Posted September 11, 2020 Between you & @exdraken, I'm not sure whether to curse or thank you guys. I've now got some decals & MW-1 dispensers en-route for future projects. So guess we'll have to go with my brain/heart thank you, whilst my wallet curses you. Looking forward to the progress. 1 2 Link to comment Share on other sites More sharing options...
Christer A Posted September 14, 2020 Author Share Posted September 14, 2020 On 10/09/2020 at 07:13, Marlin said: Oh bummer. But thanks for the headsup on this Christer. Hopefully you can fix this. /Bosse Thanks Bosse! The fix is mended, filled and sanded, but how it will look after a coat of primer is a different topic! On 10/09/2020 at 08:11, Jabba said: How wonderful on Aires to put the line that you are meant to follow on the inside of the part when you cut on the outside. Hope that all goes well on the fix that you intend to do. That's not the only sneaky thing that Aires pulled with this cockpit! As @exdraken pointed out they've mixed up the early and ASSTA 2 cockpits too! The etched front panels for the early set contains two square MFD:s where the original layout only had some round CRT or similar. I wonder if one would succeed in trying to buy the etched fret and film from the ASSTA 2 set separately? On 11/09/2020 at 16:59, helios16v said: Between you & @exdraken, I'm not sure whether to curse or thank you guys. I've now got some decals & MW-1 dispensers en-route for future projects. So guess we'll have to go with my brain/heart thank you, whilst my wallet curses you. Looking forward to the progress. Well, one just aims to please 😇 I didn't take the time to empty the camera but I still hove some photos that I haven't shown yet. The small guide vanes in the bleed air slit from the air intakes were added like this Hardly possible to see in naked plastic, even worse once I paint it in RAL 7012 which the Norm 83 painted machines use. Form RAL 7012 I use Tamiya XF-77 which might feel a but too dark but I hope it will turn out ok. The mighty fin itself was also handled: I'll aim for not attaching the rudder for a while, since it could save some masking for later paintjobs. The front and rear Radar warning antennas left some gaps, but this could be easily dealt with PPP and a wet cotton bud. Too bad that the air intake at the rot was damaged though: In itself if should not pose to big of a problem, as long as I keep the opening the correct shade and don't knock off the antenna! 5 Link to comment Share on other sites More sharing options...
Christer A Posted September 15, 2020 Author Share Posted September 15, 2020 It appears that one has to show off the weapon load, and who am I to argue? I plan to use the normal BOZ-pod (made by SAAB actually, that was new to me!) and the standard tanks, with a pair of sidewinders and a Cerberus III ECM-pod that Luftwaffe uses. The centerpiece will be the rather big lump of MW-1 dispenser pod. Fun fact: If Bosse (or @Marlin) gets around to it to his second kit, he'll use the first 3D printed MW-1 that I made. My MW-1 dispenser will be the first that Aerocraft made after I handed over the project to them, and @exdraken us using the Aerocraft production MW-1. On the other hand, those Sidewinders looks nothing at all like AIM-9L/M so those will be replace with Eduard Braassin examples, as will the BOZ-pod. Thos tanks though. Ouch! They have raised panellines which is of no particular problem as such, but the lines are of varying heights between left and right parts, and almost disappears over the joint line! And this is before I have sanded them. The Cerberus pod looks fine though! I also managed to snag a couple of resin wing seals from the Tornado SIG Nice! I probably need to adapt them a bit since I'll go for a different wing sweep but that'll come later on. Next topic is the airbrakes: I have a cunning plan! 6 Link to comment Share on other sites More sharing options...
Christer A Posted September 16, 2020 Author Share Posted September 16, 2020 Those wings were a complicated mess to get in place! Revell wants you to have the option of not only swinging wings ( 😇 ) but also to have the pylons move at the same time. This is done with a long flimsy rod and some tricky studs that are to be located correctly. The destructions also calls for you to do this while the bottom wing is hanging on the pivot. This is very delicate and the least amount of wobble immediately makes the studs pop out. While holding all this in place, you're to attach the top piece with your other hand and then glue it together somehow. I guess one should hold the TETC bottle with a foot, and then apply glue holding a brush between your teeth? Crazy stuff! Next time I'll plonk it down on the cutting mat instead and glue it the normal way, just making sure that the steering rod and studs are floating correctly. In the end I was able to glue it together, and everything swings as it should! I just had to test it though, and the locking T was installed to make sure that all things are at the correct position. So that means that one can swing the wings! The cutting mat is a 30º which the leading edge is following precisely. Not really the wanted 25º! Luftwaffe parks them at 45º though in order to fit into their HAS, so I don't have to bother about it though ! Then I tried to put the lid on, and it seems that the alternate building sequence delivers. Dry fit is very promising at least. Quickly i pulled everything apart again to finish off the wings. At 45º sweep the flaps can't be down, and it looks kind of strange to have deployed the slats and spoliers in that case, so with a heavy heart I'll close it all up. All those nice details, and I won't use them. Such a shame. Whenever I do my Eduard Desert babe I'll leave everything hanging though! Also, when finishing of the flaps: Cut off the little rod between the panels, and sand off the bottom row of steering pins, otherwise it won't fit in the wing... 7 Link to comment Share on other sites More sharing options...
Christer A Posted September 16, 2020 Author Share Posted September 16, 2020 Hmmm, maybe one should cut away the wells part here And replace it with something 3D printed, like this? Just toying around so far 😉 2 Link to comment Share on other sites More sharing options...
exdraken Posted September 16, 2020 Share Posted September 16, 2020 Nice and complicated... Revell has its top dificulty level at 5... this one would be 5++, or simply 10 regarding the wing angle, I thing it is measured mid wing, at a spare, not on the leading edge... Link to comment Share on other sites More sharing options...
Christer A Posted September 17, 2020 Author Share Posted September 17, 2020 This is very much the opposite of Tamiya F-14:s that's for sure! According to Wikipedia, the wing sweep angle is measured as a line that goes through 25% of the wing chord of the normal part of the wing, so all LERX and similar stuff can be ignored. If I go all scientific I can off course mark up this line, and use that as my guide when securing the wing 1 Link to comment Share on other sites More sharing options...
Jabba Posted September 17, 2020 Share Posted September 17, 2020 Wow those wings and their operating system seem to be more complicated than they should be and to be honest having looked at the instructions it is an area I am not looking forward to. I know that you are placing yours at a certain degree of sweep, but most people will either have them fully our or fully in. You are progressing very well. 1 Link to comment Share on other sites More sharing options...
Colin W Posted September 17, 2020 Share Posted September 17, 2020 Thanks for the advance warning of the wing mechanism. Something to look forward to but worthwhile to know to follow the instructions. I like the guide vanes in the intakes as well. Very neat. Colin Link to comment Share on other sites More sharing options...
Christer A Posted September 17, 2020 Author Share Posted September 17, 2020 Thanks guys! The wing seal really stops all wing movement so if you choose the 25 degree version you cannot sweep back any more. I can't really figure out how Revell could've done differently to allow for a synchronized wing/pylon movement though, but it should lead to all pylons being properly aligned automatically regardless of sweep angle. 1 Link to comment Share on other sites More sharing options...
trickyrich Posted September 18, 2020 Share Posted September 18, 2020 there's some lovely work going on here...I almost wish I had one of these 1/48th beasts. Oh dear guys....Aires Cockpits surely we all know by now they're going to cause heartache!!! Woe be the modeler that think fitting Aires resin cockpits/wheel wells will be a simple and painless task! 😊 1 Link to comment Share on other sites More sharing options...
Col. Posted September 19, 2020 Share Posted September 19, 2020 Tidy work so far and what a weapon load choice 1 Link to comment Share on other sites More sharing options...
exdraken Posted September 19, 2020 Share Posted September 19, 2020 Wing-sweep and pylon angle alignment: Academy also does it on the F-111....looks more sturdy, bit is also not durable... Do NOT move it often, or it will break... The good thing about the design is that you can have slats/flaps deployed, any wing position, and a swing funtion of course not all at the same time, and at a cost... 1 Link to comment Share on other sites More sharing options...
Christer A Posted September 21, 2020 Author Share Posted September 21, 2020 Thanks guys! I'm having a hard time to actually get some free time to work on the Lizard-Tonka, but it's not so strange when considering this: Yeah, that's a scale house drawing... The Wife and I decided to finally get this ball rolling after toying with the idea for the last 9 years or so. The economic situation has not made it possible before, but during the summer an opportunity arose and the need was strong enough to persuade the wallet that this is what should do. So we have written a contract for a small piece of land, located around 2km away from present apartment which has some impact on commute time (it goes up) but the kids can stay in the same school at least. Currently everything is just in the planning stages, but even so there are huge amounts of decisions to make! We're using a house supplier that builds wooden houses, but are able fully customize everything if need be. The basic model looks like this https://www.varbergshus.se/vara-hus/bosmart/solviken-traditionell But this will not be the case for us It'll be mirrored, the roof will be red tiles (a requirement from the planning office in the city) the walls will be black (NATO black or Night, still not decided) with a green door and no mullions in front of the windows. There will also be a shed that's supposed to be extended to a car-port later on, but I will not be located outside of the house for all my modelling needs. Instead, I'm allowed to use a walk-in closet marked KLK on this drawing: Very brief glossary: Kök = Kitchen Klädvård = laundry Bad = main bathroom WC/D = Small bathroom, this will have black/white checkered floor with green tiles! Sovrum = bedroom Allrum = general room, but this will be used as the TV-room Vardagsrum = living room When all of this can be done? No exact dates have been communicated yet, but a reasonable guess is to have the foundation poured sometime in late February and the house will be completed early autumn 2021. This Thursday the goal is to lock down basically all details in the kitchen, bathrooms, doors, windows, handles and so on. Everything except for the floor and wallpaper which we will do ourselves. Whew! This takes a lot of energy... On the Tonka front, I added some greeblies to the airbrake bays and sent it away to my buddy with the printer If it looks good and is possible to install with some effort, I'll make a mirror of it for the other side. I'm quite sure that someone will show the they look very different and a mirror is completely the wrong way to go 😎 I also tested if I can assemble the nose into the rear fuselage without steps or gaps. Seems to work all right with most resin in place. Next step will be to fine tune everything to ensure a snug fit. I see a lot of Dremel-action in the near future. 10 Link to comment Share on other sites More sharing options...
