Andwil Posted August 29, 2020 Share Posted August 29, 2020 This is what I will be building for this group build: Decals look like they’re cactus, but not worry as I’ll be using these, along with some other goodies: I won’t be starting this just yet as I want to finish my Harrier GR3 in the Helicopter, Autogyro & STOVL GB first. AW 10 Link to comment Share on other sites More sharing options...
Corsairfoxfouruncle Posted September 1, 2020 Share Posted September 1, 2020 Is this a Treble one Tornado ? If so mind if I follow ? Im sort of a fan of 111 Squadron. Link to comment Share on other sites More sharing options...
Andwil Posted September 1, 2020 Author Share Posted September 1, 2020 2 hours ago, Corsairfoxfouruncle said: Is this a Treble one Tornado ? If so mind if I follow ? Im sort of a fan of 111 Squadron. Welcome aboard Dennis, yes it’s 111 Sqd. Actually made a start on it today. As I had the airbrush set up to prime my Harrier, I fixed in the cockpit tub and nose wheel bay into the bottom fuselage half and shot some primer on to the internals, seats and IPs. Thanks for looking. AW 5 Link to comment Share on other sites More sharing options...
Anatol Pigwa Posted September 1, 2020 Share Posted September 1, 2020 4 hours ago, Andwil said: Welcome aboard Dennis, yes it’s 111 Sqd. Actually made a start on it today. As I had the airbrush set up to prime my Harrier, I fixed in the cockpit tub and nose wheel bay into the bottom fuselage half and shot some primer on to the internals, seats and IPs. Thanks for looking. AW You are aware though, that the GB starts on Saturday? Careful, or you breach the 25% rule I will follow your build closely, as I intend to build the same kit, albeit with OIB decals, as I cannot get any striking special livery fir the ADV 1 Link to comment Share on other sites More sharing options...
Andwil Posted September 1, 2020 Author Share Posted September 1, 2020 57 minutes ago, Marcin Kaminski said: 25% rule Whoops, my mistake, for some reason I thought it started on 29 August. Don’t know where I got that from. Now I know where “Remember remember the 5th of September” comes into it. Still, well below 25%! AW 1 3 Link to comment Share on other sites More sharing options...
Christer A Posted September 3, 2020 Share Posted September 3, 2020 You're not alone in having done a false start....😇 Link to comment Share on other sites More sharing options...
Colin W Posted September 3, 2020 Share Posted September 3, 2020 I think you are still below 25% but no extra prize for being first in the Gallery. Good to see an F3 joining the frey, expacially 111 sqn Colin W 1 1 Link to comment Share on other sites More sharing options...
Andwil Posted September 23, 2020 Author Share Posted September 23, 2020 After my false start due to having some primer in the airbrush to use and with my Harrier now finished I have made a proper start on the Tornado, making up a few sub assemblies and attending to a plethora of pins in inconvenient places such as inside undercarriage doors, adjacent to missile fins and, unbelievably, three on the inside of each wheel. Dry fit shows there will be filler. AW 6 Link to comment Share on other sites More sharing options...
Andwil Posted September 26, 2020 Author Share Posted September 26, 2020 Trenches under the wings filled with Mr Dissolved Putty Because a large part of the fin will be covered by a decal, the ILS antennae have been removed, to be reattached after the decals. A few scratches to be polished out. The early fit twin blade aerials are removed from the spine and replaced with a GPS aerial made from a thin slice of Evergreen rod. Thanks for looking. AW 6 Link to comment Share on other sites More sharing options...
Jabba Posted September 28, 2020 Share Posted September 28, 2020 A good restart. 1 Link to comment Share on other sites More sharing options...
Andwil Posted October 2, 2020 Author Share Posted October 2, 2020 This week over the course of several relatively short sessions I have managed to prime and get some paint on various parts including the wings and tail planes top and bottom as these would be a bit tricky to paint after assembly. I still have to paint the sweep area of the wings in a darker grey. Cockpit, seats and instrument panels. The kit items are not accurate and I don’t like the very bright decals provided so I have painted them light grey with a dry brushing of black to suggest switches etc. The screens are black with a drop of clear for a glassy effect. The seats and cockpit sides are meant to be dark admiralty grey, a colour I have not been able to source, so I mixed my own from neutral grey with a drop of dark blue, quite pleased with result. a Looks a bit rough, but this is many times life size. Still have to paint the buckles. Thanks for looking. AW 5 Link to comment Share on other sites More sharing options...
Andwil Posted October 5, 2020 Author Share Posted October 5, 2020 Yesterday I got the dark grey on the sweep area of the wings. I’m not concerned with the small masking error as this part is hidden within the fuselage. Which enabled me today to fit the wings using the hot screwdriver method on the hinge pins and close up the fuselage. The fuselage was a bit tricky, there are only two locating pins, one in the extreme nose and one in the tail between the jet pipes. There is a lot of flex along the joint. I used Tamiya thin and started from the back, gluing one section at a time. Thanks for looking. AW 8 Link to comment Share on other sites More sharing options...
Col. Posted October 5, 2020 Share Posted October 5, 2020 Looks to be coming together nicely for you AW 1 Link to comment Share on other sites More sharing options...
Andwil Posted October 7, 2020 Author Share Posted October 7, 2020 Finished off the assembly of the major parts today. The PJ Productions seats look a little on the small side and I had to pack some scrap plastic card under them to raise them to the right hight: Intakes, fin and canopy attached: The fit of the components was so so and there are some nasty seams and a step to rub down, I’m not expecting to get a very good result out of this kit. Thanks for looking. AW 3 1 Link to comment Share on other sites More sharing options...
Jabba Posted October 10, 2020 Share Posted October 10, 2020 good progress, pity about the seam step, but I am sure that you will resolve this. See what you mean about the size of the seats. Link to comment Share on other sites More sharing options...
Andwil Posted October 11, 2020 Author Share Posted October 11, 2020 13 hours ago, Jabba said: good progress, pity about the seam step, but I am sure that you will resolve this. See what you mean about the size of the seats. Thanks Jabba. A couple of sessions with sanding sticks, various grades sandpaper and a micro mesh polishing have hopefully addressed the problem, primer will reveal how well! The Revell kit omits the flare launchers under the rear fuselage so these were scratched from plastic card and attached: Wings and tail planes masked off and ready for primer: Thanks for looking. AW 7 Link to comment Share on other sites More sharing options...
Andwil Posted October 15, 2020 Author Share Posted October 15, 2020 I got a coat of primer on today, but it showed that the horrible seam along the fuselage join is still there, so more sanding is required. I will persevere with this build, but to be honest my heart isn’t really in it and I think it will be destined for the back of the cabinet. AW 2 Link to comment Share on other sites More sharing options...
Andwil Posted October 17, 2020 Author Share Posted October 17, 2020 (edited) I have managed to get the recalcitrant seam into a condition I can live with and today got the Light Aircraft Grey on the underside: I can feel some mojo returning. AW Edited October 17, 2020 by Andwil 3 Link to comment Share on other sites More sharing options...
Andwil Posted October 18, 2020 Author Share Posted October 18, 2020 Light Grey masked off and the Barley Grey sprayed: A little bit of bleeding and overspray to touch up. AW 7 Link to comment Share on other sites More sharing options...
Jabba Posted October 19, 2020 Share Posted October 19, 2020 Coming along very well. 1 Link to comment Share on other sites More sharing options...
Dermo245 Posted October 19, 2020 Share Posted October 19, 2020 Nice work 👍 Link to comment Share on other sites More sharing options...
RJ-WobblyHands Posted October 19, 2020 Share Posted October 19, 2020 Its Looking Good - you are winning the building battle vs another Revell Kit Link to comment Share on other sites More sharing options...
Andwil Posted October 20, 2020 Author Share Posted October 20, 2020 On 10/19/2020 at 4:36 PM, Jabba said: Coming along very well. 10 hours ago, Dermo245 said: Nice work 👍 9 hours ago, RJ-WobblyHands said: Its Looking Good - you are winning the building battle vs another Revell Kit Thanks for the encouragement fellas, it’s helping stay positive! The Radome painted medium sea grey and the tail fin and spine sprayed with Tamiya gloss black. And masking off: The bright patch on the underside is a reflection from my desk lamp. I have left the tailplanes masked as next I have to mask for the thrust reversers and the natural metal panel on the fin. Thanks for looking. AW 5 Link to comment Share on other sites More sharing options...
Andwil Posted October 21, 2020 Author Share Posted October 21, 2020 Thrust reversers, panel on fin and the panel around the cannon port were masked off and sprayed dark aluminium: Apologies for the blurry photo, I was holding the model with one hand and my phone in the other. I had a slight set back when removing the masking, I broke the starboard tailplane off and had to re glue it. Things under wings: Tanks Sidewinders Skyflashes. Thanks for looking. AW 2 Link to comment Share on other sites More sharing options...
Colin W Posted October 21, 2020 Share Posted October 21, 2020 Shes looking great now. I'm glad you persevered after you wern't happy with the inital finish Colin Link to comment Share on other sites More sharing options...
