Silenoz Posted August 25, 2020 Share Posted August 25, 2020 The Karakurt class of ship's (also known as Project 22800) is the (for now) latest class of stealth corvettes for the Russian navy. They are meant to be more seaworthy then the Buyan-M-class which were designed for the littoral zone. With the hostillities in Ukraine, ssome larger projects were halted/pauzed and this is a cheap alternative for the Admiral Grigorovich class frigates... These ships are armed with 8 vertical launchers for Oniks/Calibr anti-ship cruise missiles, a 100mm A-190 dual purpose gun, 2 AK-630 CIWS (first two ships), Pantsir M CIWS or Palash/Palma CIWS. First hulls were laid down in 2015 and were commisioned in december 2018 and october 2019. 14 More ships are being constructed or launched allready. The kit: and the parts: early hull: Late hull: Various parts: PE, decals and barrels: Detailing seems to be nice and crisp, but looking at the Combrig version of this ship, I would recommend the latter, a lot more detail is added, but I suppose that it will also add to the difficulty of building it... Not my first ship I'm busy construction, but the railings were always a bit of a halting point, So on with that bullet, an appointment with the dentist has been made just in case... Progress: For the railings I worked with some kind of PVA-glue, gators grip, later on to be reinforced with thin CA: The small cages are for the liferafts... found it more easy to solder these into place then to glue these... less fuzz Also found out that applying a bit of solder to the bends makes them stronger, at least less vulnerable to break. I'm aloso trying to thicken the PE-parts that need some body: Same with these reinforcements to the sides, the supports are separate parts (luckily they provide too much off these) and I've found it more easy to solder these then to glue... just a matter of habbit I suppose... Till next one... 3 Link to comment Share on other sites More sharing options...
ArnoldAmbrose Posted August 25, 2020 Share Posted August 25, 2020 Gidday, these ships are out of my era of ship models a little, I'm mainly into WW2 vintage, but they look quite sturdy workmanlike vessels which I think I could get to like. Regards, Jeff. 1 Link to comment Share on other sites More sharing options...
Silenoz Posted August 27, 2020 Author Share Posted August 27, 2020 (edited) Thx, don't think I'm up to rigging etc yet, but these are "easy" ones to learn a few tricks. And I do love the clean lines of these modern ships... Elsewhere I was asked for the size: 96mm long and 16mm wide... Some progress: Most has been fitted, with exception for the parts I think I won't be able to reach for painting: The main mast was nerve wrecking: 8 pieces on a few mm's All attached with the tiniest amounts of PVA The result so far: Most railings weren't etched that wel (some burrs were visible) so I had to scrape most of them with the tip of a scalpel blade... Edited August 27, 2020 by Silenoz 4 Link to comment Share on other sites More sharing options...
Silenoz Posted August 29, 2020 Author Share Posted August 29, 2020 Meanwhile the first one is in it's basecolor. These modern ships have beautiful lines, but on the other hand, are mostly pretty dull in colors... Dependent of where these are stationed, they have a darker or paler grey shade. On the other hand.. (maybe for the second kit included...) So I've choosen the darker shade for this one Looks pretty rough enlarged like this... On to paint the few details... 4 Link to comment Share on other sites More sharing options...
ArnoldAmbrose Posted August 29, 2020 Share Posted August 29, 2020 Gidday Silenoz, yeah, close up photos can be very unforgiving, but the model still looks good. I enjoy seeing personal additions to a kit. Regards, Jeff. 3 Link to comment Share on other sites More sharing options...
Silenoz Posted August 30, 2020 Author Share Posted August 30, 2020 Yesterday was a rainy day, and little on my hands, so a lot of modelling time...: An oversized picture of the Palash CIWS. In reality it looks more like this: the 100mm gun: The rest of the ship, just in need of a few touch-ups and an attempt to add some rigging and for size: 3 Link to comment Share on other sites More sharing options...
Silenoz Posted September 1, 2020 Author Share Posted September 1, 2020 Decals on, worked perfect on one side(according to me at last...) on the other side, they slightly moved while using decalsetting... darn .... but I will leave it as it is... and so the rigging... for the first time, must admit it gave me some fear. First attempt with streched sprue. Made these as thin as I could, then cut some sections at length and glued these... Then checked with some friends for their opinion, which was unanimous... nope, not good... Next up, I've checked what I had at hand and found some rigging wire from Ushi I once bought and forgot about it... and so small dabbs of CA and on with it (easier said then done...) with the last sections, the CA stuck to everything, except the wires... so some small touch-ups will be needed to the hull from removing the excess glue.. PFFFFFF..... My hat of to the guys that rigg complete ships in this scale... will take more practice than this I suppose 2 Link to comment Share on other sites More sharing options...
