A34 Comet - Rubicon Models
John
I'm taking a break from 50 year old kits I built as a kid, so when this showed up in Rubicon Models UK's webstore the stars aligned.
I'm not really an armour modeller but I have a small collection of Rubicon's 1/56th scale kits because they offer a nice relaxing build and I like the size of the finished article.They're also very high quality products.
The first time I'd even heard of the Comet was when Matchbox released their 1/76th scale kit in the 1970s.  It's still not that well served in the modelling world so this new kit is especially welcome. So, what do you get?
A very high quality end-opening box:
Comet1
Rubicon provide comprehensive but generic decal sheets. The quality is usually good:
Comet3
2 sprues in ABS, rather than polystyrene:
Comet4
Comet5
Very high quality instructions:
Comet2
More shortly.
John
21 hours ago, Courageous said:
Odd scale but a nice subject, so, crack on.
Stuart
There's actually a large number of military vehicle kits out there in this scale, but only a few are in the scale modelling mainstream - Italeri manufacture for Bolt Action and box these kits themselves too.
Anyway, to work. The turret shows some of the innovative engineering often found in Rubicon kits:
Comet11
Meanwhile the running gear gets some paint thrown at it. This is a first undercoating:
Comet10
There's some very nice detail here. The colour used here is:
Comet6
...part of a batch bought from Jamie's stand at the Perth show a couple of years ago.  Fantastic stuff.
I also bought the Rubicon Commonwealth Tank Crew set. I didn't realise at the time that the kit came with a commander figure, so now it can have a loader too.
Comet8
John
The inner road wheels are connected by a spacer, which I trimmed off and added the wheels individually:
Comet13
The completed running rear looks quite good. The tracks are a bit simplified but by the time there's a bit of weathering on them they'll be fine:
Comet16
By some process that mystifies me, I managed to lose part A26. I've replaced it with some EMA ABS sheet. I'll add the prise bar later:
Comet14
John
The front and rear skirts don't have big contact areas so the heavy weaponry was brought out:
Comet17
Fit at the rear of the hull is OK but needs a bit of persuasion - more heavy weaponry deployed:
Comet18
Most of the basic construction done and the basic markings for the Fife and Forfar Yeomanry applied:
Comet19
Comet20 Comet21
Next steps are tidying up the paintwork and starting some basic weathering.
More soon.
John
A bit of weathering, in this case well thinned Humbrol 94 Brown Yellow:
Comet24
The Commander's vane sight is a cage-shaped contraption to the front of his cupola. The kit supplies it as a solid part, so a bit of careful painting will be called for:
Comet23
I cut off both the overscale Besa muzzles. I'll replace them with turned brass 1/48th scale parts, which will still be a bit too big but should look finer:
Comet25
Next job is to tidy up the finish of the tracks.
John
