Julien Posted August 15, 2020 Share Posted August 15, 2020 A-26/B-26 Invader Brass Undercarriage (for ICM) 1:48 Aerocraft Models To the joy and surprise of modellers ICM recently gave started a new line in A-26/B-26 Invade kits. These are large and impressive kit and a bit weighty Ali at Aerocraft has thought of this and has been busy at work creating this set to replace the kit parts in tough brass to alleviate any concerns. The set arrives in an unassuming ziplok bag, with three parts inside, all made from brass. With two main gear legs and the nose leg. Preparation of the brass parts will involve removal of the casting gate with a file or a motor-tool at very low speed. The moulding marks on the top and bottom of the part should be similarly easy to remove using a small file with sanding sticks used to smooth it out once the task is complete. Conclusion This set not expensive by any stretch of the imagination, and guarantees resilient gear legs for years to come, providing you use either super-glue or epoxy to attach it to the plastic. Highly recommended. Review sample courtesy of Link to comment Share on other sites More sharing options...
