US Navy ALBAR 15 Universal Towbar (209032) 1:32 VideoAviation.com
The US Navy have to move aircraft around and for this they need towbars. The ALBAR 15 is known as the 15 as it is 15 feet long. The ALBAR is also designed for towing aircraft provided with fuselage and landing gear tow rings. The locking pins on the end of the tubes are also used to attach to the standard shipboard crash dollies to provide positive control while moving damaged aircraft supported with crash dollies.
The Kit
It arrives in videoaviation's standard clear clam-shell box with n insert showing the towbar. . Inside there are two bars. The parts consist of the main bars, the end with the wheels, and the top end to connect to the towing tractor. Decals are provided for two different versions.
Conclusion
If you're placing any of your models on a base, adding ancillary equipment is a great way of enhancing realism. Highly recommended.
Review sample courtesy of
