Hewy Posted September 30, 2020 Share Posted September 30, 2020 Looks great so far, its only when you see someone like tom for comparison up close that it becomes apparent just what big old units they were, you'll need to clear some shelf space for this Link to comment Share on other sites More sharing options...
trickyrich Posted September 30, 2020 Author Share Posted September 30, 2020 you're not wrong! I seem to have this urge now to jump up to the next scale....not too sure what will follow the F-16I and Viggen....maybe something from WWII. Link to comment Share on other sites More sharing options...
Triet Cam Posted October 4, 2020 Share Posted October 4, 2020 It's great to see this build back on track again!. Great looking pit you did there. 1 Link to comment Share on other sites More sharing options...
trickyrich Posted October 5, 2020 Author Share Posted October 5, 2020 Thanks. Things are winding up with the chopper so I should be able to start spending more time on her. Link to comment Share on other sites More sharing options...
SoftScience Posted October 6, 2020 Share Posted October 6, 2020 I really wish you would stop making 1/32 look so much fun. Collecting them is not a viable option Not a viable option Not a viable option Not a viable option Not a viable option A viable option Viable option . . . 4 Link to comment Share on other sites More sharing options...
trickyrich Posted October 6, 2020 Author Share Posted October 6, 2020 hahah....resistance s futile!!!! Though in this case very expensive! Plus it's all about to get worse as I have pretty much finished the Blackhawk (thank god/satan/you fav deity) so I can get back to this baby! In the meantime can I post you to this........ .....https://www.ebay.com/itm/Trumpeter-1-32-02254-A-1J-AD-7-Skyraider-model-kit/153980808136?hash=item23d9f8abc8:g:gFsAAOSw~6Be8aEj ....it even has free shipping! 1 Link to comment Share on other sites More sharing options...
SoftScience Posted October 6, 2020 Share Posted October 6, 2020 I want to, but it would chew up so much shelf space. Link to comment Share on other sites More sharing options...
trickyrich Posted October 6, 2020 Author Share Posted October 6, 2020 I have an easy fix for that!!! Build a bigger shelf!!! Just think how amazing a 1/32nd monster will look amongst all the wee planes! 2 Link to comment Share on other sites More sharing options...
wimbledon99 Posted October 7, 2020 Share Posted October 7, 2020 I'm going to have a go at a 1:32 Beaufighter for the Interceptor GB but it's not going on a shelf if completed. I still have a couple of hooks in the ceiling of my office where my 1/6 RC P47 used to hang 3 Link to comment Share on other sites More sharing options...
trickyrich Posted October 7, 2020 Author Share Posted October 7, 2020 there we go.....the rot has set in...pretty soon you'll need to add structural supports to take the weight of all the others that will follow! 3 Link to comment Share on other sites More sharing options...
trickyrich Posted October 16, 2020 Author Share Posted October 16, 2020 Ok this update is a bit late…..I actually forgot to do it last Monday!!! Ok lots and lots done on her on the last 2 days off….again as usual this will not be in order work was done… Ok these beauties showed up….. I have chosen which one to use....... ......along with these form Daco…….. …and these big Napalm pods, not sure who I got them from. I still need to find some small 250lb or WP bombs. The wings are now altogether, the joins ended up being quite good, just one minor miss-match on the leading edge of one….prob my fault, but a simple fix. On the inner wing sections there were these “knobs” sticking out, no reference as to what they are. References say that these were indicators to tell the pilot whether the wing fold mechanism was locked or not. The instruction makes no mention of this of course, for the locked down position these pins would not be exposed. Ok no more stuffing around, time to sort out the fuselage issues!! After even more test fitting the plan was to brace the indies of the fuselage to keep it all nice a straight, then clamp the outside against the lower insert. To help this I added small taps the fuselage inserts to also help with alignment. So with this all in place some clamps/tape and CA cement off we go! These are the bits used after the event. The joins ended up being really good, there was some work required to clean them up. The rear join is wear the main issues are and as mention in other posts the only proper way to have corrected this would have been to split the fuselage, which in reality isn’t an option. So to fix this the gaps were filled with plastic and then everything carefully reprofiled to hide the issue! After quite a bit of work its all done! It turned out even better than I hoped. Everything is nice a smooth and it’s now hard to tell there was ever an issues in the first place. While I was at it I sorted out the issues with the fat trailing edge of the rudder. Compared to the before photo it’s now exactly how it should look like. Though we should forget that I’ve managed to re-glue the trim actuator back to front!!! Ok time for some test fitting of the wings, I needed to add some braces/wideners to the fuselage and as a result All the gaps have gone! Nose join isn’t that bad at all. The rear needs some minor work but an easy fix. …and a final look at how she’ll look altogether, I won’t say how scary it was to cut out the resin canopy!!!! There are no replacements if you stuff this up!!! Finally the IP is done….looks pretty good, I just need to add more clear varnish to the gauges to make the “glass’. Only a short break next week, but should have most of it together at the end of it. 8 Link to comment Share on other sites More sharing options...
wimbledon99 Posted October 16, 2020 Share Posted October 16, 2020 That's some serious modelling, Rich!! Kudos 1 1 Link to comment Share on other sites More sharing options...
modelling minion Posted October 16, 2020 Share Posted October 16, 2020 Excellent work Rich, really good to see your Spad back underway. You did a great job on sorting out the fit issues at the rear end, I really think that the way you have sorted it was the best way to do it and you have kept all the details. I bet cutting that canopy was a very nerve wracking experience, you have pulled it off though and the pic of everything mocked together shows how great this will look when it all comes together. 1 Link to comment Share on other sites More sharing options...
trickyrich Posted October 16, 2020 Author Share Posted October 16, 2020 actually the sides are almost completely straight/flat going back to the tail which is great as that's how they're meant to be. Cutting the flash off the canopy was truly terrifying, but the nice thing is they fit perfectly. The complete rear section needs to be tinted clear blue, that will be interesting to do! I'm seriously hanging out to get back to this build, as mentioned I hoping to get a lot done this break.......along with the Tornado. 2 Link to comment Share on other sites More sharing options...
modelling minion Posted October 16, 2020 Share Posted October 16, 2020 Have you found ant decent pics of how the rear cockpit was fitted out? I know they came in various configurations and that in most cases for the USAF and VNAF everything was taken out but finding clear info is a bit difficult. Link to comment Share on other sites More sharing options...
helios16v Posted October 16, 2020 Share Posted October 16, 2020 4 hours ago, trickyrich said: The complete rear section needs to be tinted clear blue, that will be interesting to do! Thinned down Tamiya clear blue. Worked a treat on my Cobra. 1 Link to comment Share on other sites More sharing options...
Triet Cam Posted October 16, 2020 Share Posted October 16, 2020 11 hours ago, trickyrich said: Excellent. It looks like a lot of progress made! May I make a couple suggestion? The round tube, the oil drain, doesn't exist there on the E. Neither are the rectangular armor plates with 4 bolts. Link to comment Share on other sites More sharing options...
trickyrich Posted October 16, 2020 Author Share Posted October 16, 2020 9 hours ago, modelling minion said: Have you found ant decent pics of how the rear cockpit was fitted out? I know they came in various configurations and that in most cases for the USAF and VNAF everything was taken out but finding clear info is a bit difficult. I'll probably leave it pretty much empty, as you they were mostly empty and I don't have any photos or info showing stuff fitted other than those demo ones showing what stuff that could be fitted. 1 hour ago, Triet Cam said: Excellent. It looks like a lot of progress made! May I make a couple suggestion? The round tube, the oil drain, doesn't exist there on the E. Neither are the rectangular armor plates with 4 bolts. Thanks for that, I haven't really start to check what is different on the kit supplied parts. Which 4 bolt plates do you mean? Those on the wings? Will have to go and chase up some photos.....or a good walkaround! 1 Link to comment Share on other sites More sharing options...
Triet Cam Posted October 17, 2020 Share Posted October 17, 2020 (edited) 6 hours ago, trickyrich said: Thanks for that, I haven't really start to check what is different on the kit supplied parts. Which 4 bolt plates do you mean? Those on the wings? Will have to go and chase up some photos.....or a good walkaround! I think they were armor plates added in to protect the pilots from small arms from the ground. They were installed on the H, but for some reason were left off the E versions. Here's a VNAF A-1E in 1970. Here's my shoe horn version I did in 1/48, using the Matchbox body and the A-1H Monogram wings. Edited October 17, 2020 by Triet Cam 2 1 Link to comment Share on other sites More sharing options...
trickyrich Posted October 17, 2020 Author Share Posted October 17, 2020 Arrr I see, thanks for that ....and here I was trying to be careful not the damage that detail! ...and a great detail shot to show how clean they were as well! 1 Link to comment Share on other sites More sharing options...
trickyrich Posted October 20, 2020 Author Share Posted October 20, 2020 Ok I bit late in updating this one, been really busy on her plus a couple of other things… …….. one of which I’m now the proud owner of a 1/48th Collect-Aire F2H-3/4 Banshee!!! These are pretty much non-existent, so to be able to find one at a get price!!! I pretty much now have all my VF-31 aircraft in 1/48th! ……… plus, my AMK F-14D & 1/32th Academy AH-1Z “Viper” were waiting for me too! ..now back the subject…..lots done. As was pointed out to me these aircraft didn’t have the armoured plates fitted. So after spending quite some time going over all the stuff I could find and noticed that all the moulded ones needed to be removed, so I ended up removing them all…... and not the easiest of tasks either, as it would require panel re-scribing as well It’s all pretty smooth now, I managed to save/recover a lot of detail, just need to add rivets. I won’t get too excited or carried way here as it’s underneath and not seen, plus it’ll be covered in oil! The front and rear wing joins are going to be a lot better than I first expected they’ll be, a nice surprise! The underside speed brake looks like it’ll fit nicely as well. It was time to start fitted the cockpit…… some extra wiring was added to the front of the consoles as there is a bit of a gap between them and the IP. Plus some wires were added to the indicator on the top of the IP. Unfortunately the front canopy wouldn't fit at all unless the IP was mounted too low. The Gunsight was the issue. I fitted it per instructions but it sits too high. Back to references and it appears that 1/2 of it actually sat under the IP shield not above like it is here......so out with the saw and that was sorted! The rear fairing for the canopy was added, again not the easiest to fit….not help by the fact I managed to fit it slightly out ….. …. As can be seen by my additions. The test fitting of the canopy was a bit scary because it’s made of resin so a wee bit fragile…… I’ve had to do a few wee mods after this test fitting to get ot all sitting right. The cockpit tub was then fitted, I added some bracing underneath for support plus added those lower fuselage supports/wideners..... ops no photo! The elevators were fitted, no real dramas here. The engine…….. I had to do a bit of work here with getting it to sit correctly. The new cowling is actually a bit longer (and correct) to the kit one. Plus, you need to leave the entire carburettor off to get it to fit. So, with the engine in place the prop would not clear the front of the cowling at all! So, I made a mounting plate for the engine to properly mount to and a whole pile of shims to help set it in the correct position. When I first saw the AM blades, I thought there may have been a moulding fault the indentation at the back of the prop and them being soooo wide. But after more careful researching they are correct. The blades had this unusual indentation on the back of the trailing edge. I’m surprised Trumpeter got the blade shape sooo wrong (well not really!). So getting closer……… I’m almost ready to put the wings on. She’ such a big aircraft, all the more so with 5’5” Tom Cruise beside her! I’m still really happy with the progress, still lots to do but I’m over the hump almost. Will put her aside for a couple of days and get back to the Tornado. 8 Link to comment Share on other sites More sharing options...
Triet Cam Posted October 21, 2020 Share Posted October 21, 2020 Totally slick looking Spad. I think the German guy is lost in direction though. 1 Link to comment Share on other sites More sharing options...
modelling minion Posted October 21, 2020 Share Posted October 21, 2020 That is great progress Rich, some really nice work. Sounds like the Australian post system has been busy and that you should have enough plastic/resin to keep you happy for a while. 1 Link to comment Share on other sites More sharing options...
trickyrich Posted October 21, 2020 Author Share Posted October 21, 2020 3 hours ago, modelling minion said: Sounds like the Australian post system has been busy and that you should have enough plastic/resin to keep you happy for a while. thre's no such thing as enough for me! 1 Link to comment Share on other sites More sharing options...
Triet Cam Posted October 21, 2020 Share Posted October 21, 2020 What a big monster that thing is. I built the 1/32 ZM single seater and this one makes it look puny. No wonder the pilots used to call it fat face. 2 1 Link to comment Share on other sites More sharing options...
