DaveJL Posted October 13, 2020 Author Share Posted October 13, 2020 18 hours ago, Collin said: USN ROCKEYE MK-20 series are white. Never saw, carried, or dropped one that wasn’t a white body, with either blue or yellow stripes. Cheers Collin Thanks Collin. I'd never seen a non white USN example myself. Link to comment Share on other sites More sharing options...
PeterB Posted October 13, 2020 Share Posted October 13, 2020 Well I said I was likely to be wrong - the film clip I remember must have shown practice bombs to demonstrate the coating - makes sense I guess as it was during a peacetime deployment I imagine Pete Link to comment Share on other sites More sharing options...
Collin Posted October 13, 2020 Share Posted October 13, 2020 4 hours ago, PeterB said: Well I said I was likely to be wrong - the film clip I remember must have shown practice bombs to demonstrate the coating - makes sense I guess as it was during a peacetime deployment I imagine Pete All ROCKEYE are white....the MK 7 outer canister is white with either yellow or blue bands to denote if the cluster munitions inside are either live or inert and if the weapon is thermally protected. I've dropped thermally protected (TP) and non-TP ROCKEYE...both with inert and live munitions inside, outside canister has always white. Peacetime/wartime isn't a factor. Below...on this BUFF...first yellow stripe means the munition is thermally coated, the second blue stripe means the munitions inside the canister are inert (some even have blue "X"'s....see below). TP coated weapon, inert munitions inside. This is a leaflet CBU...because of the big BLUE 'X" on the side. Those are to denote that it's a leaflet munition Below...this A-7 is carrying TP-coated ROCKEYE with live munitions inside (Gulf War 1). Typically shore-based aircraft will use non-TP CBU's...hence only the single stripe. See below links for an example of both. https://catalog.archives.gov/id/6366880 https://catalog.archives.gov/id/6437868 Now I have seen MK-20/CBU-99/CBU-100 rounds in solid blue or natural dark metal...but these are static ground training units used for practice loading or looking pretty next to aircraft parked for display. Examples: Below is from the Aviation Ordnance manual: A yellow band around the forward end of the cargo section indicates the explosive content of the weapon.The Mk 7 Mods 3, 4, and 6 bomb dispensers have the Mk 339 Mod 1 fuze, which provides the pilot within-flight selection of the fuze function time. The Mk 7 Mod 4 bomb dispenser differs from the Mk 7 Mod 3 by modifying the dispenser and giving interface capabilities with a wider range of military aircraft. The Mk 7 Mod 6 bomb dispenser is the same as the Mk 7 Mod 3 except that the outside of the Mod 6 cargo section is coated with a thermal protective coating and has an additional yellow band around the forward end of the cargo section. The addition of the thermal coating increases the overall weight of the Mod 6 to 505 pounds. Cheers Collin 1 Link to comment Share on other sites More sharing options...
Enzo the Magnificent Posted October 13, 2020 Share Posted October 13, 2020 On 09/10/2020 at 22:35, trickyrich said: gee that's a mass of bombs.......actually what do you call a lot of bombs? A "dump" of bombs. Link to comment Share on other sites More sharing options...
Enzo the Magnificent Posted October 13, 2020 Share Posted October 13, 2020 On 09/10/2020 at 23:25, PeterB said: I must admit I am a little surprised that the Mk 20 Rockeye II variant of the Mk 7 dispenser was so popular in Vietnam as the bomblets were primarily anti - armour as I understand it and the VC were a bit light on tanks until late in the war I believe. The SUU-30 series of anti personnel CB's would seem to make more sense. Believe me, anti-armour weapons make an awful mess of... well... everything! Link to comment Share on other sites More sharing options...
PeterB Posted October 13, 2020 Share Posted October 13, 2020 (edited) I stand corrected on both counts - mea culpa😳. Pete Edited October 13, 2020 by PeterB Link to comment Share on other sites More sharing options...
trickyrich Posted October 13, 2020 Share Posted October 13, 2020 3 hours ago, Collin said: All ROCKEYE are white....the MK 7 outer canister is white with either yellow or blue bands to denote if the cluster munitions inside are either live or inert and if the weapon is thermally protected. I've dropped thermally protected (TP) and non-TP ROCKEYE...both with inert and live munitions inside, outside canister has always white. Peacetime/wartime isn't a factor. Below...on this BUFF...first yellow stripe means the munition is thermally coated, the second blue stripe means the munitions inside the canister are inert (some even have blue "X"'s....see below). TP coated weapon, inert munitions inside. This is a leaflet CBU...because of the big BLUE 'X" on the side. Those are to denote that it's a leaflet munition Below...this A-7 is carrying TP-coated ROCKEYE with live munitions inside (Gulf War 1). Typically shore-based aircraft will use non-TP CBU's...hence only the single stripe. See below links for an example of both. https://catalog.archives.gov/id/6366880 https://catalog.archives.gov/id/6437868 Now I have seen MK-20/CBU-99/CBU-100 rounds in solid blue or natural dark metal...but these are static ground training units used for practice loading or looking pretty next to aircraft parked for display. Examples: Below is from the Aviation Ordnance manual: A yellow band around the forward end of the cargo section indicates the explosive content of the weapon.The Mk 7 Mods 3, 4, and 6 bomb dispensers have the Mk 339 Mod 1 fuze, which provides the pilot within-flight selection of the fuze function time. The Mk 7 Mod 4 bomb dispenser differs from the Mk 7 Mod 3 by modifying the dispenser and giving interface capabilities with a wider range of military aircraft. The Mk 7 Mod 6 bomb dispenser is the same as the Mk 7 Mod 3 except that the outside of the Mod 6 cargo section is coated with a thermal protective coating and has an additional yellow band around the forward end of the cargo section. The addition of the thermal coating increases the overall weight of the Mod 6 to 505 pounds. Cheers Collin Thanks for all that great info!!! That final picture with that poor old A-10 is quite sad! Gee Dave she's coming along really nicely, the finish in those weapons and pylons is awesome. I've been trying to get some of that Flory Wash for ages, it always seems to be out of stock on the site.........plus I can't seem to find it down here! Link to comment Share on other sites More sharing options...
DaveJL Posted October 16, 2020 Author Share Posted October 16, 2020 @Collin thanks for all the info and great pictures!! On 10/13/2020 at 9:57 PM, PeterB said: I stand corrected on both counts - mea culpa😳. Pete I've been there many times mate On 10/13/2020 at 7:57 PM, Enzo Matrix said: A "dump" of bombs. That works pretty well! I suppose 'dump' is a rather another name for the term I had in my head! 🤐 On 10/13/2020 at 10:57 PM, trickyrich said: Thanks for all that great info!!! That final picture with that poor old A-10 is quite sad! Gee Dave she's coming along really nicely, the finish in those weapons and pylons is awesome. I've been trying to get some of that Flory Wash for ages, it always seems to be out of stock on the site.........plus I can't seem to find it down here! Thanks Rich. There's 9 bottles of the dark wash Available on the Flory website at the minute. Back to the kit and due to the unique shapes and colour locations, I had to break the painting down into more stages that normal. So after the primer, I sprayed the frame of the windscreen in MRP Light Gull Grey and then masked this off. Then the pre shading was done. The nose was sprayed black and given a light coat of gloss to protect the paint from the masking tape that will be going on. I also painted the leading edges of the wings (Tamiya XF-57 'Buff' looked a good match for this) and masked up. I'll also need to mask off the black on the intake lips. Wings and stabilisers also had the leading edges painted and masked before a pre-shade: Refuelling probe done: Canopy was sprayed, weathered and given flat coat before the plethora of internal parts were added (10 in total): I'm hoping to get the initial coats of white down next week. Cheers and take care Dave 6 Link to comment Share on other sites More sharing options...
modelling minion Posted October 16, 2020 Share Posted October 16, 2020 That looks great Dave, with the top colours on she is going to be fantastic. The canopy is really good, a very neat masking job. Link to comment Share on other sites More sharing options...
DaveJL Posted October 16, 2020 Author Share Posted October 16, 2020 14 minutes ago, modelling minion said: That looks great Dave, with the top colours on she is going to be fantastic. The canopy is really good, a very neat masking job. Thanks mate. The New Ware mask set is very good. 1 Link to comment Share on other sites More sharing options...
trickyrich Posted October 16, 2020 Share Posted October 16, 2020 now this is starting to get exciting!! Link to comment Share on other sites More sharing options...
DaveJL Posted October 17, 2020 Author Share Posted October 17, 2020 13 hours ago, trickyrich said: now this is starting to get exciting!! Thanks mate! Will be glad when the painting is completed! Link to comment Share on other sites More sharing options...
DaveJL Posted November 1, 2020 Author Share Posted November 1, 2020 Back to the bench after a bit of a hiatus. Masked the nose up and sprayed all the necessary areas in Tamiya XF-2. Some detailing added to the landing gear bays. Wings: Stabilisers were glossed (these are all white, top and bottom) and given a Flory panel wash: More masking now - upper flaps on the wings, then the demarcation areas between the white and Gull Grey, not forgetting the intake splitter plates. Hoping to progress that midweek. Stay safe, Dave 4 Link to comment Share on other sites More sharing options...
modelling minion Posted November 1, 2020 Share Posted November 1, 2020 That is nice paint work Dave, really smooth. The wash on the stabilisers has done a great job of highlighting the recessed details on them. Link to comment Share on other sites More sharing options...
DaveJL Posted November 1, 2020 Author Share Posted November 1, 2020 29 minutes ago, modelling minion said: That is nice paint work Dave, really smooth. The wash on the stabilisers has done a great job of highlighting the recessed details on them. Thanks mate! 1 Link to comment Share on other sites More sharing options...
Hewy Posted November 3, 2020 Share Posted November 3, 2020 Looks very promising dave👍 Link to comment Share on other sites More sharing options...
ziggyfoos Posted November 4, 2020 Share Posted November 4, 2020 (edited) On 10/16/2020 at 2:11 PM, DaveJL said: ... I also painted the leading edges of the wings (Tamiya XF-57 'Buff' looked a good match for this) and masked up. I'll also need to mask off the black on the intake lips. ... Dave excellent progress so far. If it matters, the wing, tail, and pylon leading edges on early A-6s (like many other USN aircraft in that period) were Corogard, an aluminum grey color. The tan/brown tape on the leading edges came about later (70/80s). Here's a detail pic from their 1965 Indy cruise that you're doing: Edited November 4, 2020 by ziggyfoos 1 Link to comment Share on other sites More sharing options...
DaveJL Posted November 4, 2020 Author Share Posted November 4, 2020 On 11/3/2020 at 6:42 AM, Hewy said: Looks very promising dave👍 Thanks mate! 3 hours ago, ziggyfoos said: Dave excellent progress so far. If it matters, the wing, tail, and pylon leading edges on early A-6s (like many other USN aircraft in that period) were Corogard, an aluminum grey color. The tan/brown tape on the leading edges came about later (70/80s). Here's a detail pic from their 1965 Indy cruise that you're doing: That's what I get for relying on the Hobbyboss painting sheet! Thanks for the info, I'm about to re-mask and correct the leading edges in aluminium. Cheers Dave Link to comment Share on other sites More sharing options...
DaveJL Posted November 4, 2020 Author Share Posted November 4, 2020 Good progress over the past 2 days. Gull grey on in a few light coats, masking off, various small areas detailed and the leading edges corrected as pointed out above. Quite happy with how it's looking. Just need to paint the airbrakes on the fuselage metallic steel then I'm hoping to get the gloss coat on tomorrow. More soon. Dave 2 Link to comment Share on other sites More sharing options...
modelling minion Posted November 4, 2020 Share Posted November 4, 2020 That looks really great Dave, the pre-shading has worked very well and given a nice variation to the tone. Very neat job on the corogard, re-doing something like that and getting it neat is never an easy task but you have done it really well. Link to comment Share on other sites More sharing options...
DaveJL Posted November 4, 2020 Author Share Posted November 4, 2020 2 minutes ago, modelling minion said: That looks really great Dave, the pre-shading has worked very well and given a nice variation to the tone. Very neat job on the corogard, re-doing something like that and getting it neat is never an easy task but you have done it really well. Thanks mate. The leading edges were simple enough to fix, using the MRP colours helps as they dry so quickly to a good strong finish. They're not 100% as I've left a gap from the edge of the slats to stall strip on the inner most leading edge as per the Furball diagram but the picture above would suggest that's not correct. But I'm happy to leave it as is! 1 Link to comment Share on other sites More sharing options...
coneheadff Posted November 4, 2020 Share Posted November 4, 2020 Looking great Dave!! Link to comment Share on other sites More sharing options...
DaveJL Posted November 4, 2020 Author Share Posted November 4, 2020 1 hour ago, coneheadff said: Looking great Dave!! Thanks Alex! I've also just remembered I need to mask and spray the walkways Link to comment Share on other sites More sharing options...
DaveJL Posted November 5, 2020 Author Share Posted November 5, 2020 Walkways masked up and sprayed MRP Dark Gull Grey, followed by the airbrakes in Tamiya X10 Gun Metal. Once dry, a few light coats of Alclad gloss went on. Should have the decals on tomorrow. Dave 3 Link to comment Share on other sites More sharing options...
modelling minion Posted November 5, 2020 Share Posted November 5, 2020 That is some neat masking Dave, very nice. Looking forward to seeing the decals start to go on. Link to comment Share on other sites More sharing options...
