Revell 1/72nd Type VIIc U-Boat U-552
I am about to start my 2nd 72nd boat this year, in fact my second ever. I'll be building U-552 in its early fit.
And for extras, i have a couple of sets from eduard. A PE set and resin 88mm deck gun.
A White Ensign set includes some PE parts and a template to correct some of the flood drain holes. And from Schatton-Modellbau a radio antenn and metal barrel for the 2cm Flak.
G-Factor propellers and another Schatton set, metal periscopes.
And finally, a wooden deck from Nautilus Models which includes resin hatches.
I also have some waterline decals and a fabric flag from AMP.
  • Like 9
Thanks guys.
Rob, i've had quite a bit of variety this year. Only thing missing is some German armour.
  • 3 weeks later...
Finally time for an update on the U-Boat. I spent the first 2 weeks just working on the port side hull. It was just all drilling and sanding and filling. I am useing the Wolf Pack article by Dougie Martindale and Wink Grise that i downloaded from AMP a few years ago. These guys develope the U-Bras set now sold by WEM that corrects many of the errors on the Revell kit. The artcile also gives good detail on the flood holes on the U-552 along with other Tupe VII's.
So, starting the the front, i cut out the cheack piece and replaced that with the U-Brass part. Also the row of small round holes along the top of the hull were filled and re-drilled. The Revell ones are to big and to far forward. Also filled the 3 holes at the front of the hull as these are to bag and the pattern is wrong. But i have just noticed i still need to finish re-drilling these.
Then the forward portion of the free flooding vents. Over the whole boat, i need to fill 7 holes, drill 11 new ones and alter 2. Also filled and re-drilled the curved line of vents which drain water away from the deck gun.
In the middle, the central drainage area, the recess running along the top of the saddle tanks, was cut out and ribs added. The brass part above can either be used as a template or replace the kit area, again, some holes needed filling.
And the rear free flooing vents alng with the 3 vents above the saddle tank. These had to be done twice as i messed up first time. I have left the exhaust as i am not sure if i should drill that or just paint it in. If its drilled, it will need somthing behind it so you can't see straight through.
The holes on the underside can be corrected with a set from Model Brass. But this is pricey and i would not need the vast majority of it. So i just drilled them out and re-shapped with a round needle file. You can see where i over did the sanding and went right through. But fortunatly that will be covered by base of the propeller shaft.
And the ones at the front.
And the whole part.
One thing i learnt is that was easier to thin the plastic before drilling out the vents. I still need to do a little clean up on some of the holes. On the inside, i addd some styrene sheet to replicate the saddle tank extending into the hull. Once the hull halves are together and the ''pressure hull'' fitted, i will tidy that up.
Now i just have to repeat the whole process on the starboard side.
After 2 weeks of that, i decided i need a break so moved onto the tower. The top and bottom halves are together with the external PE added from the Eduard set. I plan to prime and paint the inside befor ethen fitting this out and getting it all together.
The 2 periscopes were put together including the metal parts.
The Nautilus wood deck is based exactly on the Revell one, including errors. This includes the hole for the UZO sight. This should be in the middle, but Revell places it over the the left side.So on my piece i cut out the correct area, fortunatly the base of the UZO covers most of the area where the incorrect hole is.
And 4 more bit of AM arrived, 3D printed parts from Shapeways. Left to right, turnbuckles which i ahve kept in their little box, insulators for the antenna wire's, UZO base and sight and anchor.
Thats all for now. I plan on spending this week finishing off the tower and working on the deck gun. Then at the wekend i will start on the starboard side of the hull.
You are going all the way with these... Following with interest. Will you also add some canning to the surfaces while you are at it?
Edited by Silenoz
Thanks Silenoz. Ye, i plan on giving it a go. Never done anything like that before so going to take it gently. But i will wait until the hull halves are together.
  • 1 month later...
Been a few weeks but finally got an update. In my last one i said that i was almost ready to primer the tower. I then made the mistake of checking my referances again and realised it needed some fixing.
Unfortunatly photo's of the inside of towers are tricky to find. It seems that Revell mat have based theirs on U-995 which is on display at ladoe. But this is a late style tower. At the top front of the tower was a shelf which went full width and stuck out to far. This was chopped in half and sanded back. The Eduard PE set has a compass face which goes on this shelf, but that should be on a frame which i will have to build. At the bottom of the tower was another shelf which went right round the sides. Oddly this is where Revell place the voice pipe and compass repeater, almost at floor level. I trimmed this leaveing just a step on either side and built up the front and then put the voice pipe onto the higher shelf. I still have a bit of work to do, including the fitting for the crew to attach their saftey harness to.
I then spent over 2 weeks working on the starboard side of the hull.
I sanded through to far at the rear, so i need to repair that area.
The centre is done.
At the front i still need to fit the new parts around the torpedo doors.
So, after 8 weeks, i'm going to put this to one side to build a couple of aircraft and an armour kit before the year is out. Will be back to this soon.
