A-20G/H/K/J Havoc/Boston Mk.IV/V Resin Upgrades (4726 & 4727 for Special Hobby) 1:72
1:72 CMK by Special Hobby
These two sets are to upgrade the detail to Special Hobby’s 1:72 kit, with modular upgrades that require minimum alteration to the kit parts.  Both sets arrive in the yellow-themed blister pack with card backing and instructions supporting the resin and Photo-Etch (PE) parts from harm, with a further acrylic sheet provided to prevent denting of the PE parts by the resin jostling during transport.
Interior Set (4726)
This set includes 10 resin parts, a small fret of PE and a slip of pre-printed acetate sheet.  In preparation for insertion, the fuselage sides should be sanded or scraped thin to accommodate the sidewall detail parts, which is best done before main assembly.  The cockpit is made up on a stepped two-part platform, with instrument panel and PE/Acetate sandwich applied to the front, PE rudder pedals, resin and PE control column, pilot seat with PE belts and a dinghy pack to the rear.  The kit front bulkhead and nose gear bay are attached, then with the aforementioned sidewall details pre-fitted, and an insert to the sides of the dinghy bay added, the new cockpit can be fitted between the fuselage halves, with a small PE sight added to the windscreen hoop.
Gun Turret (7427)
This set increases the level of detail in the fuselage under the mid-upper gun turret, as well as replacing the kit guns with new more detailed resin parts.  Again, the fuselage where the bay will be placed needs scraping thin to accommodate the bay, which is made up from an L-profile floor, two large side parts with another two small parts adding length and detail.  The turret itself is augmented with the guns, plus turret base and curved part over the top.  The kit’s glazing is utilised to close-in the new detail.
Conclusion
The devil’s in the detail, and at 1:72 these sets will make quite a difference to the finished model, begging to be shown off.
Highly recommended.
Review sample courtesy of
