AliGauld Posted August 6, 2020 Share Posted August 6, 2020 Hi There, This was started at the same time as the Typhoon and has continued a bit longer being worked on whilst doing my Buccaneer. Three kits in one really. The Trolley and the Arado were little gems that were a joy to build but the Salamander was , well, a pig. Nothing on it fitted where it was supposed to but I think we got there. This has also been built for the wee man as he really likes a bit of whiffery. Primed with UMP Grey Primer Painted with Colourcoats RLM 02, RLM76, Vallejo RLM 66, RLM 81, RLM 82, Xtreme Metals Aluminium, Burnt Metal and Tamiya Rubber Black. Final Coat was Windsor and Newton Satin Varnish. Some Eduard Lufwaffe Seatbelts and Albion Alloy tubing were also used. Disaster struck just as I was ready to take some photos and the box tipped and knocked the engine cover and the loop aerial off. The aerial went the way of most things that hit the floor so I used a piece of Stainless Steel vaping wire bent around a small screwdriver to try and replicate it.. As always, Thanks for looking. Cheers, Alistair 21 Link to comment Share on other sites More sharing options...
Wulfman Posted August 6, 2020 Share Posted August 6, 2020 Very nice build and finish, can’t help thinking that the set-up would be a bit tricky to handle ! Wulfman 1 Link to comment Share on other sites More sharing options...
AliGauld Posted August 6, 2020 Author Share Posted August 6, 2020 25 minutes ago, Wulfman said: Very nice build and finish, can’t help thinking that the set-up would be a bit tricky to handle ! Wulfman Thanks very much. It doesn't look to be the most stable take off platform at all. Cheers, Alistair Link to comment Share on other sites More sharing options...
SAT69 Posted August 6, 2020 Share Posted August 6, 2020 Very nicely built. I've never seen that combination before and know nothing about it. Was the real thing something projected to be built or was it actually built and flown? 1 Link to comment Share on other sites More sharing options...
dogsbody Posted August 6, 2020 Share Posted August 6, 2020 Nice! I've got one of those kits in the stash. Never had the guts to try to build it. Yours looks great. Chris 1 Link to comment Share on other sites More sharing options...
72modeler Posted August 6, 2020 Share Posted August 6, 2020 That you were able to get all the bits of the He-162 to fit together is a testament to your modeling skills! That is one pig of a kit! Very nice job on all three components! DML definitely stood for "Do Me Later" back in the day! Mike 1 Link to comment Share on other sites More sharing options...
AliGauld Posted August 6, 2020 Author Share Posted August 6, 2020 4 hours ago, SAT69 said: Very nicely built. I've never seen that combination before and know nothing about it. Was the real thing something projected to be built or was it actually built and flown? Thanks very much. I think it was just a paper project but I'm not an expert. 3 hours ago, dogsbody said: Nice! I've got one of those kits in the stash. Never had the guts to try to build it. Yours looks great. Chris Thanks very much. It's a bit of a trial for the He-162 but nothing filler can't fix. 2 hours ago, 72modeler said: That you were able to get all the bits of the He-162 to fit together is a testament to your modeling skills! That is one pig of a kit! Very nice job on all three components! DML definitely stood for "Do Me Later" back in the day! Mike Thanks so much. The 162 was a complete pig to try and fit together and i did use a lot more filler than I thought I would need but as for skills, I prefer "I got Lucky". Cheers, Alistair 1 Link to comment Share on other sites More sharing options...
RMCS Posted August 6, 2020 Share Posted August 6, 2020 Lovley 1 Link to comment Share on other sites More sharing options...
AliGauld Posted August 6, 2020 Author Share Posted August 6, 2020 Just now, RMCS said: Lovley Thanks very much Cheers, Alistair Link to comment Share on other sites More sharing options...
ArmouredSprue Posted August 7, 2020 Share Posted August 7, 2020 I do have this kit on stash and it's good to see it's build-able. Cheers Link to comment Share on other sites More sharing options...
AliGauld Posted August 7, 2020 Author Share Posted August 7, 2020 6 hours ago, ArmouredSprue said: I do have this kit on stash and it's good to see it's build-able. Cheers Hi There, Yes with a bit of care, patience and better planning than I managed it goes together. I would download the Revell reboxing instructions from Scalemates, they are a little clearer and more comprehensive. Cheers, Alistair 1 Link to comment Share on other sites More sharing options...
ArmouredSprue Posted August 11, 2020 Share Posted August 11, 2020 On 8/7/2020 at 5:32 PM, AliGauld said: Hi There, Yes with a bit of care, patience and better planning than I managed it goes together. I would download the Revell reboxing instructions from Scalemates, they are a little clearer and more comprehensive. Cheers, Alistair Good tip! Thanks 1 Link to comment Share on other sites More sharing options...
