Hello
Last week I received directly from the factory a couple of 1/72 AZUR FRROM B-10 Export.
Actually these are the first two boxes from this manufacturer with
FR0043 B-10 Export WC/WAN > China Air Force and Argentine Navy
FR0042 B-10 Export WH-2/WAA > Dutch East Indies and Argentine Army
I am starting cutting the first sprues next weekend but here are the instruction sheets and the transfers.
Patrick
Edited by VG 33
  • Like 13
I have the old Williams Bros B-10 in my stash, and have been waiting for these new kits to be released. Looking forward to hearing your opinion on them.
- Bill
  • 1 month later...
Hello
After a couple of months building something else I am back on these export B-10.
Here is what I made last weekend with everything inside the fuselage and the masking tape on the clear parts which is very time consuming.
By the way, I am confused with the color inside the fuselage as in the instruction sheet it is written that it may have been green instead of aluminium for the export B-10s. Anybody has the answer?
Patrick
  • Like 15
On 28/09/2020 at 22:09, VG 33 said:
Hello
Patrick
The export planes were built after the US aircraft industry had changed over to using chromated primers. Hence the opinion they may have been green. But I am not aware of any photos of the export machines available to prove this. Unlike the many photos showing the silver US Army cockpits....
Thank you for this beginning of explanation Roger.
So far I have found in Air Enthusiast No 22 a picture of the rear cockpit of a WH-3 just before delivery. Those were the last produced for the NEIAF and the side panels are clear and bright, so I suppose covered in aluminium lacquer. I am going for this.
For the Argentinian Navy, a friend of mine told me that inside it was a light color. But on the other hand it seems that the Argentinian Air Force aircraft were green as is the current "B-10" showed at the USAF Museum. This one is actually an Argentinian Air Force Martin 139 in USAC colors. But on black and white pictures a green could be "light". Still looking for... but soon I have to take a stand.
Patrick
  • 4 weeks later...
Hello
Some progresses this week.  I completed inside with some bits for the ammunition boxes of the NEIAF. I added a couple of boxes for the radio Xmtr and Rec apparatuses.
By the way after an advice from South America I chose aluminium as the overall inside colour of the Argentinian Navy Martin 139.
Cheers.
Patrick
I think that would be the correct interior color. The B-10 that is on display at the Air Force Museum was donated by Argentina, but was restored here where I live at Kelly  by reservists, so I wouldn't use its interior colors as representative of an original combat aircraft. My real interest is in the Martin Model 166 versions built for the NEI with uprated R-1820 engines, a deeper forward fuelage, different wing taper, and a continuous canopy....hoping Azur will do that version, but it's doubtful. Liking what I see in your WIP, though as the interior of the Azur kit looks to be much more comprehensive than the old Williams Bros. kit. Thanks for sharing your work and review of the kit!
Mike
@Corsairfoxfouruncle Thanks for the heads-up, Dennis!
  • 1 month later...
Hello
Once again after a long time building other kits I am back with some progress on this couple of kits.
Actually I spent time around the joints between both parts of the fuselage.
Patrick
26 minutes ago, RidgeRunner said:
Nice work, Patrick @VG 33. What is your panel line technique here? An oil wash prior to painting?
Martin
Actually I airbrushed black paint over the joints to scrutinize them. Especially close to the trailing edge as everything disappeared after sanding.
Patrick
Great work! Watching your process is such a joy. I am planning to get onr if those B-10s too.
I dont know  why but this plane reminds me captain memo's submarine :)
  • 1 month later...
Hello
After a long hiatus I am back on building and here is where I am.
B-10 Export WAN Argentine Navy
B-10 Export WH-2 Dutch East Indies
As you can see the joints between wings and fuselage was not perfect and I had to fill and sand. Anyway now the bonds are strong with Tamiya and cyanoacrylate glues.
Next step will be the engines and the transparencies.
Cheers.
Patrick
Hello
Some progress now at a faster pace.
I added some spark plug wires to each cylinder.
And I painted these engines.
Next I cut the Tamiya tape along the transparencies for the main paint job.
I paint the rudder and the stabilizers in white for the Argentinian Martin.
Finally the NEI aircraft saw some white and orange paints in order to prepare the triangle insignia.
To be continued...
Patrick
Edited by VG 33
  • Like 12
Mike
Mike, I am sorry to likely disappoint you, I am also interesting in that variant so I directly e-mail them. The answer was negative, namely so far they did not considered doing this variant... They old me that it is practically a new project with new fuselage, wings, engines and canopies... So we can only do a scratch conversion and I am thinking about it (having WB standard Martin B 10 on shelf).
Patrick - I will follow your build with interest, looks very promising!
Regards
J-W
  • Sad 1
I was afraid of that, JWM, as it would pretty much need to have new tooling for the wings and fuselage,  in addition to props, engines, and cowlings, and after I examined how the B-10 kit was sprued when I got mine earlier this week, it was pretty obvious that the molds weren't engineered for that version being a possibility. Separate sprue for the outer wings and fuselage would have worked, with the continuous greenhouse being on the clear sprue, ala Eduard kits, and the other detail parts being on their own sprue, but it's not a well-known variant, nor was it used by any other service, but doggone it, it's a handsome brute, and like you, I will probably use my Williams Brothers kit for a conversion; the old 1/72 Revell B-17F Memphis Belle looks like it has perfect R-1820 cowlings and props- just need to do the intakes, oil coolers and exhausts; I reckon I can piece the kit greenhouses together and/or use them to make a master to vacuform a new one.  Have to research photos and drawings to see how to modify the nose, but it looks like it is deeper at the bottom from the nose to where it meets the bomb bay. When/if I start, I will be sure to let you know! ( I ALWAYS get hot to do a model for which there is either no kit or no good references/drawings...is this a great hobby or what?) Looks like I will have to go Moa on it to make the conversion!
Mike
Azur/Frrom is to be commended, however, for their new-tool kit- it is so much better than the old, but still workable Williams Brothers release.
Edited by 72modeler
corrected spelling
I think the Academy B17 has double set of engines and props.
I will appreciate! The ony drawings I have for this variant is that from that page
https://kw.jonkerweb.net/index.php?option=com_content&view=article&id=603:glenn-martin-b10-139-166-uk&catid=92&lang=en&showall=1&limitstart=&Itemid=554
and thet poor one
GLENN-MARTIN-139-WH3-B-10-AIRCRAFT-MAINT
Maybe it is enough for 1/72 conversion? Do you have better drawings?
Just some more paint this evening.
First inside color for the transparencies and it is Duralumin.
And the light blue of the Argentinian flag on the tail. The closest I have found is Gunze H45.
To be continued...
Patrick
  • Like 12
Hello
I am progressing on the paint job.
For the NEIAF the mask of the rudder was the trickiest to create so that the black band was as regular as possible.
Thanks to my Silhouette cutting machine I could try and test.
Next came the black paint around and the border masks.
And the Argentinian one.
To be continued...
Patrick
  • Like 11
  • 2 months later...
Hello
After some months and a Mirage IIIB I am back to these bombers.
First I cut the wing leading edge to make the integrated landing lights as was the case for the WH-2 and the WAN.
I made some plexiglass blocks with a silver dot for the lights
and glued them into the leading edge
and later sanded flush to the edge.
Next I made the missing small window on the starboard side of the fuselage using the same process as above.
I modified the propellers according pictures
And now both kits are ready to be painted. The handling bars are made of copper wires.
To be continued...
Patrick
Nice work, the scratch additions and insignia painting are great!
Hello
I have finished the painting job on both aircraft with a gloss varnish over.
First WH-2
and WAN
Next stage will be the transfers.
Patrick
  • Like 9
