FPDPenguin Posted August 5, 2020 Share Posted August 5, 2020 (edited) I recently saw a good friend who is also an excellent modeler. Whenever I see him he always gifts me old models and things. Amongst the box of stuff he gave me was a partially started kit. He has a habit of using the rudder to open and close things such as bomb bay doors or canopies. This particular kit he told me, he ended up giving up on because of the way the canopy pivots open. So I've no hope in getting it to work. Below is a picture of what he'd already done to the seat I then noticed the air brakes have been modified. Looking closer there is a mechanism inside the fuselage. (I've taped it in place) Turns out this is to control the air brake doors, as can be seen on the under side. I've no idea where to start to get this mechanism to work. But I'll sure have a go. I will have to call him and see if he remembers what he was going to do. In the mean time I've started with the usual stuff. I've put the wings together and filled them Looking at after market cockpit sets I decided just to add some bits to the standard cockpit, just to add a little interest. I also removed the brass work my friend had added. (sorry) I've got another 2 projects on the go at the same time as this. But couldn't resist it since its already been started. I'll get some paint on it tomorrow hopefully. 🐧 Edited August 5, 2020 by FPDPenguin Remove duplicate picture 5 Link to comment Share on other sites More sharing options...
Night Owl Posted August 5, 2020 Share Posted August 5, 2020 Wow thats ambitious detailing making moving parts, soldering tubing is an aquired skill it will be very interesting to see how the parts function alot of dry fitting and testing for sure. I guess you could continue on trying to get all the flaps ect to move that would be impressive. Looking to the RC planes for how they rig control surfaces might give you an insight into making yours work at smaller scale. 1 Link to comment Share on other sites More sharing options...
FPDPenguin Posted August 5, 2020 Author Share Posted August 5, 2020 I'm actually a pewtersmith by trade, so soldering tiny bits isn't that much of a challenge to me. It's actually designing the mechanism that I'll fall foul on. Would be a shame to scrap his idea totally. But it will only be hanging from the ceiling in my sons room. Link to comment Share on other sites More sharing options...
FPDPenguin Posted August 6, 2020 Author Share Posted August 6, 2020 The little man had his first injections today, so he's a little grumpy. Got him off to sleep and managed a bit of painting. Here's the office Dry fitted it secured with tape. There were so many photos of different cockpit arrangements so I sort of winged it. (ducks from the purists) I'll do front nose gear bay next and seal up the front section ready for filling and sanding. 🐧 10 Link to comment Share on other sites More sharing options...
Triet Cam Posted August 6, 2020 Share Posted August 6, 2020 I dont know what pewtersmith do, but that is one fantastic looking cockpit you just did. WOW! 1 Link to comment Share on other sites More sharing options...
Night Owl Posted August 7, 2020 Share Posted August 7, 2020 I'll be following your progress so please post as time permits. Nice detailing behind the seat was that the kit or your doing? 1 Link to comment Share on other sites More sharing options...
FPDPenguin Posted August 7, 2020 Author Share Posted August 7, 2020 9 hours ago, Night Owl said: I'll be following your progress so please post as time permits. Nice detailing behind the seat was that the kit or your doing? It was just some bits I added. Probably in accurate. I just looked at some pics of after market stuff and took some artistic licences 😂 Link to comment Share on other sites More sharing options...
Biggles87 Posted August 9, 2020 Share Posted August 9, 2020 That’s a well painted cockpit. I remember this as being a very nice kit with excellent cockpit detail supplied except for the throttle handles which are a little simplified. If you have ( or can obtain ) the Detail and Scale volume on the F-5 you will see what I mean. looking forward to more. John 1 Link to comment Share on other sites More sharing options...
FPDPenguin Posted August 9, 2020 Author Share Posted August 9, 2020 24 minutes ago, Biggles87 said: That’s a well painted cockpit. I remember this as being a very nice kit with excellent cockpit detail supplied except for the throttle handles which are a little simplified. If you have ( or can obtain ) the Detail and Scale volume on the F-5 you will see what I mean. looking forward to more. John I had noticed that, but as it will spend most of its time hanging from my sons bedroom ceiling, it shouldn't be a problem. It is a shame though, as you rightly say, the rest of the cockpit has some lovely detail. Thanks for looking 🐧 Link to comment Share on other sites More sharing options...
FPDPenguin Posted August 14, 2020 Author Share Posted August 14, 2020 Had a bit of time on this earlier. Mostly fettling and sanding the filling. Ive also now built the nose gear and sealed up the front section. I had to carefully prise the seat out so I had at least a little hope in masking off the cockpit. I'll upload pics when I've sanded it and gave it a lick of primer. I did look at assembling the main landing gear, but it's straight forward and can go on at a later date. 🐧 Link to comment Share on other sites More sharing options...
FPDPenguin Posted August 15, 2020 Author Share Posted August 15, 2020 Removed the flimsy barrel, replaced it with metal. When I sealed up the front half the part above the canopy wouldn't close up properly, so with a bit of persuading and a tad of card it stayed sealed. There's some work to be done on the seams. Not to bad, but some parts will need filling. I've created a hinge for the upper door to the gun bay, this is mostly to keep it in place when the outer paint goes on. I suppose I'll have to look into making the bottom door move now. 🙄 I did some light sanding, gave it a shot of primer which has shown how awful I am at sanding. So I moved onto the gun bay for now. The next problem I've got is the ammo belt doesn't quite reach the gun. 😒 So that's where I am at the moment. 🐧 3 Link to comment Share on other sites More sharing options...
FPDPenguin Posted August 15, 2020 Author Share Posted August 15, 2020 Here's the ammo belt. With a little heat and bending, trial fitting I got it in place. Added a bit of colour and dirt of course. I'll add some hoses to the nose gear and get that painted. Also assemble the fuel tank(s)? Not decided on the load out. I have noticed that my mate must have pinched the side winders out of the kit. So I'm going to have to scratch build them. 🐧 6 Link to comment Share on other sites More sharing options...
FPDPenguin Posted August 15, 2020 Author Share Posted August 15, 2020 The kit instructions say to paint the ammo box white. But looking deeper on the Internet, which I should have done first. Its not white! It's silver. 🙄 Also at the bottom right there's also a grid/mesh and an ejection port. Guess I'll have to dry brush a bit of silver on and see if I can add a bit of photo etch or thin card. Doesn't seem to be much love for this kit on here. I'll save posting my drivel and only update when I've done anything major. 🐧 2 Link to comment Share on other sites More sharing options...
FPDPenguin Posted August 22, 2020 Author Share Posted August 22, 2020 Did a little work on the nose gear. I used my new micro drill bits for this. Good job they're cheap, I snapped the 0.5mm one after 15 minutes 😂 luckily I can clamp the bit into the pin vice still, and I have spares. Don't hold out much hope for the 0.3mm ones 😂 I will do the same to the main gear, just a few hydraulic lines. Reference photos show a line that goes into the wheel hub, presumably for the brakes. It appears that my friend who had this kit before me had scavenged the sidewinders. So a quick bit of scratch building. Bit of sprue cut to length Fins added front and back. Also drilled the back out to make the nozzle. I've also decided to do something I've never done before. And that's rescribe an entire kit. I told my mate about this and he sent me his hasegawa templet tritool scribe set. I've had a quick look at this. And offered them up to the kit. It's going to be a long build this one! Guess I better get on with the Taube. I'm also thinking of starting a canberra with the aeroclub conversion kit he gave me for the italeri 1/72 canberra. 🐧 1 Link to comment Share on other sites More sharing options...
Biggles87 Posted August 25, 2020 Share Posted August 25, 2020 You’re rescribing a whole 1/32 kit! Rather you than me. Good Luck John 1 Link to comment Share on other sites More sharing options...
phildagreek Posted August 26, 2020 Share Posted August 26, 2020 This is all shaping up to be rather smart. Link to comment Share on other sites More sharing options...
FPDPenguin Posted August 26, 2020 Author Share Posted August 26, 2020 (edited) 17 hours ago, Biggles87 said: You’re rescribing a whole 1/32 kit! Rather you than me. Good Luck John Yes, I've realised just how crazy that is. But I've gone and started it now 😔 🐧 Edited August 26, 2020 by FPDPenguin Spelling 1 Link to comment Share on other sites More sharing options...
FPDPenguin Posted February 15, 2021 Author Share Posted February 15, 2021 Hey all, just bumping this up, I've scribed quite a few bits now. Need to do the main part of the fuselage. Which I'll get cracking in now after a lovely little pain free 109e build. I'll upload pics in a few hours. 🐧 Link to comment Share on other sites More sharing options...
malpaso Posted February 15, 2021 Share Posted February 15, 2021 Looking forward to seeing progress on this. I like the cockpit work. I have this kit in my stash, I rather like the lines of the F-5 and couldn't resist it for a tenner! I think I may choose something smaller for a first rescribing project though... 1 Link to comment Share on other sites More sharing options...
FPDPenguin Posted February 15, 2021 Author Share Posted February 15, 2021 1 hour ago, malpaso said: Looking forward to seeing progress on this. I like the cockpit work. I have this kit in my stash, I rather like the lines of the F-5 and couldn't resist it for a tenner! I think I may choose something smaller for a first rescribing project though... Yup I'm feeling the same now 😂 1 Link to comment Share on other sites More sharing options...
Marklo Posted February 15, 2021 Share Posted February 15, 2021 (edited) Brave man, I have a 1/72 heller me109k to do and I’m dreading it… Edited February 15, 2021 by Marklo 1 Link to comment Share on other sites More sharing options...
FPDPenguin Posted February 16, 2021 Author Share Posted February 16, 2021 The wings are all done. The tail is done. Most of the sub assemblies are compete and have a lick of paint on them. Just the fuselage to go. The underside is full of detail. I'm thinking I might omit the odd bit. Save my sanity. WHY DID I START THIS? Ive sealed the fuselage up. It actually makes it a bit easier to handle. Dry fitted everything to give me a look at what it's going to be. It's a big bird. So it's the fuselage to go then I can get it together. The fit of the wings is pretty bad, and the tail is on a wonk. So that will need sorting too.... 🐧 6 Link to comment Share on other sites More sharing options...
FPDPenguin Posted February 17, 2021 Author Share Posted February 17, 2021 Managed to crack the fuselage back into its respective pieces. Too much pressure and concentration. No harm done though. The underside is now scribed. Just the top half to go now. 🐧 1 Link to comment Share on other sites More sharing options...
Alan P Posted February 18, 2021 Share Posted February 18, 2021 This is one of the two Hasegawa kits I've ever made and really enjoyed it. You're doing an excellent job so far, cockpit looks brilliant. 1 Link to comment Share on other sites More sharing options...
2lefthands Posted February 18, 2021 Share Posted February 18, 2021 Looks fantastic, so far! 1 Link to comment Share on other sites More sharing options...
