Old Viper Tester 5,866 Posted July 31, 2020 Share Posted July 31, 2020 (edited) F-16A, USAF s/n 80-0550, was allocated off the production line to the F-16 Combined Test Force, 6510th Test Wing, Air Force Flight Test Center at Edwards AFB as a stability and control, loads and flutter test airframe. I say flutter as one of the flight test disciplines, though in the '80s, the adage was that "the F-16 did not experience flutter" but, instead, limit cycle oscillations (LCO). So when you saw that wing tip vibrating away, it was the digital flight controls unable to keep up with the aerodynamic forces that were bending that wing - still looked like flutter to me. October 1982 - fitted with engineering mock-ups of the LANTIRN navigation and targeting pods testing aircraft flying qualities with the pods fitted and the airframe structural response. A lucky shot as we barrel rolled over him to set up for a test point. Gives a good view of the arrangement of load distribution straps and attachment fittings for the spin recovery parachute quadrapod. January 1983 - Continued LANTIRN pod effects testing. October 1983 - After being fitted with an F-16C vertical tail. February 1990 - Deeper pylons to accommodate AIM-7 Sparrows for testing compatibility with the F-16C configuration. January 1991 - Fitted with the spin recover parachute quadrapod Not '550 (she is in the background), but an image of the full spin recovery parachute apparatus. The red and blue canister contains the parachute and the deployment mortar. The parachute attachment harness comes out of a slot beneath the red canister section and attached to the quadrapod. The attachment fittings and straps on the fuselage distribute the forces from the deployed parachute so that the aft fuselage doesn't get ripped away when the chute yanks the tail up while the aircraft is falling through the air out of control. Thanks for looking, Sven Edited July 31, 2020 by Old Viper Tester Corrected "auto-correct" 10 3 Link to post Share on other sites
Red Dot 1,826 Posted August 1, 2020 Share Posted August 1, 2020 great photos and interesting notes, thanks Andy Link to post Share on other sites
giemme 19,844 Posted August 1, 2020 Share Posted August 1, 2020 Agreed, thanks for posting them 18 hours ago, Old Viper Tester said: October 1983 - After being fitted with an F-16C vertical tail. Apart from the obvious blade antenna fitted to the fin base, what other differences were between the two versions, please? Ciao 1 Link to post Share on other sites
Old Viper Tester 5,866 Posted August 4, 2020 Author Share Posted August 4, 2020 On 8/1/2020 at 11:12 AM, giemme said: what other differences were between the two versions, please? The only real external differences of the C/D series are: - the blade antenna, as you noted - the broader vertical tail base (or island) that the antenna is mounted on - the larger volume base was designed to house the Airborne Self-Protection Jammer, though later, the ASPJ was not purchase by the USAF. This different vertical tail is the primary identifier between A/B and CD. - the engine intakes were custom designed for the brand of engine installed - the original Normal Shock Inlet (NSI) for the Pratt & Whitney F100 series (Block25, most Block 30, and Blocks 32,42,52) or the Modular Common Inlet Duct (MCID) associated with the GE F110 series (late Block 30, Blocks 40, 50) . The ECS inlet above the sides of the MCID have angled intakes while the NSI has a vertical intake. - the engine exhaust nozzles themselves are visibly different as well - the F100 series exhaust nozzle is essentially straight, giving the exhaust a conic profile (common to all F-16A/B), the F110 exhaust nozzle has curved petals, giving the exhaust an ogive profile. Cheers, Sven 2 Link to post Share on other sites
giemme 19,844 Posted August 4, 2020 Share Posted August 4, 2020 Thank you Sven, great info! Ciao Link to post Share on other sites
