SR-71 BlackBird Jet Nozzles 1:72 Metallic Details
The Lockheed SR-71 was the ultimate in fast reconnaissance aircraft fielded by the USAF.  With a top speed over Mach 3 (which was never actually disclosed) the aircraft needed a new at the tine Pratt & Whitney J58 engine. The exhausts and afterburner provided quite a distinguishable feature on the air frame. At speeds of over mach three the rotating parts of the engine produced only drag with the afterburner providing 100% of thrust. As with many kits the engine molding while OK in plastic cant compare with the castings available in resin. This new set fro Metallic Details is a four part affair which needs only minimal cleaning up before fitting together. The casting is first rate and these will make your finished model realy pop. Highly recommended.
Review sample courtesy of
