Adrian Hills Posted July 28, 2020 Share Posted July 28, 2020 I chose this 1/100 scale kit, originally produced in 1956 to show where plastic models of the venerated Heinkel 111 first originated. There is no disguising the fact that it is wildly innacurate. However, moulded in this multi-coloured plastic gives it a certain charm. As you can see, perhaps the worst part is the iconic glazed nose. I have been thinking that populating it with a couple of figures might help. 2 Link to comment Share on other sites More sharing options...
Arniec Posted July 28, 2020 Share Posted July 28, 2020 nice to see this nostalgic kit here. That nose does look awfull. Hope that a little bit of paint will do it good. Cheers, 1 Link to comment Share on other sites More sharing options...
Adrian Hills Posted July 28, 2020 Author Share Posted July 28, 2020 These are the first steps of my build. As you can see the parts don't quite match up. The rear of the tail and tips of wings are notable. The colours of the plastic are so interesting that it seems a shame to paint it. However, it will need a bit of Milliput and then a scheme from a recognised aircraft - have I mentioned the V1 yet ! 6 Link to comment Share on other sites More sharing options...
Adrian Hills Posted July 28, 2020 Author Share Posted July 28, 2020 Is this the oldest injection kit of a He 111? Airfix was 1962 and the Lindberg 1:64 scale 1958 ( want one of those) 2 Link to comment Share on other sites More sharing options...
Mottlemaster Posted July 29, 2020 Share Posted July 29, 2020 That plastic would look fantastic polished up and coated with gloss varnish. It looks like it will help stop any skill faid with the issues to get brain around. Cheers Alistair 1 Link to comment Share on other sites More sharing options...
Adrian Hills Posted July 29, 2020 Author Share Posted July 29, 2020 Mottlemaster, unfortunately I don’t have that skill Link to comment Share on other sites More sharing options...
Mottlemaster Posted July 29, 2020 Share Posted July 29, 2020 The only thing i know how to polish is the top of my head 3 Link to comment Share on other sites More sharing options...
vppelt68 Posted July 29, 2020 Share Posted July 29, 2020 1 hour ago, Mottlemaster said: The only thing i know how to polish is the top of my head Reading that, doesn´t raise my hair Link to comment Share on other sites More sharing options...
Retired Bob Posted July 29, 2020 Share Posted July 29, 2020 14 hours ago, Mottlemaster said: The only thing i know how to polish is the top of my head You and me both. On 28/07/2020 at 21:18, Adrian Hills said: As you can see, perhaps the worst part is the iconic glazed nose. I have been thinking that populating it with a couple of figures might help. Is there masking set for this kit. A couple of figures, you get half a dozen in that nose. 1 Link to comment Share on other sites More sharing options...
Adrian Hills Posted August 2, 2020 Author Share Posted August 2, 2020 Wings together and yet to Milliput mismatch. I have printed off a couple of drawings and looked at dimensions. My theory is that the moulds were done for the fuselage first and then someone did some measurements to compare it with 1/100 scale. The fuselage is too short so the simple solution to get the correct dimension, which it is, was to attach a glazing that would look better in Kew Gardens !! 4 Link to comment Share on other sites More sharing options...
Mottlemaster Posted August 2, 2020 Share Posted August 2, 2020 2 hours ago, Adrian Hills said: Wings together and yet to Milliput mismatch. I have printed off a couple of drawings and looked at dimensions. My theory is that the moulds were done for the fuselage first and then someone did some measurements to compare it with 1/100 scale. The fuselage is too short so the simple solution to get the correct dimension, which it is, was to attach a glazing that would look better in Kew Gardens !! More Eden Project Can you paint back part of glazing to get shorter glazing ,longer fuselage . Just looked again at yor photo again and see that doesnt work .It will however still look like a He111 J (just) 1 1 Link to comment Share on other sites More sharing options...
Pete in Lincs Posted August 2, 2020 Share Posted August 2, 2020 Crikey! Is this the oldest kit being built on here? In my youth I traveled to Germany and was given a Faller Bf109 (minus tailplanes). If I may, cut the canopy at the back (the top and bottom) to shorten it and things might perhaps look better. I too like the swirls in the plastic. No upper gun position or fuselage windows, hmm. Link to comment Share on other sites More sharing options...
Adrian Hills Posted August 3, 2020 Author Share Posted August 3, 2020 Hi Pete, I have thought of shortening but the whole birdcage but it tapers. I reckon it may not take the cutting and re-profiling as the plastic is so very old. Certainly the green plastic is behaving in a peculiar way. Have just printed out a drawing to give some idea of hole for upper gun position. It does come with glazing for this postion. 1 Link to comment Share on other sites More sharing options...
Adrian Hills Posted August 3, 2020 Author Share Posted August 3, 2020 Stretched some sprue and then cut it to fill holes on bottom of engine nacelle. Found it was best to have flared ends so it didn't disappear in the hole ! This is the scale drawing roughly the right size Cut windows on sides. Thinned inside by windows. Removed blanking plate within canopy. It is now beginning to make sense. Subsequent to Peter's suggestion I am seriously thinking of reducing length of glasshouse. There is about 1.4 mm difference if I cut it but might fudge over that with masking tape canopy framing. I have test cut bits of clear sprue in kit so it might srvive major surgery 6 Link to comment Share on other sites More sharing options...
Adrian Hills Posted August 10, 2020 Author Share Posted August 10, 2020 Well I think Lincolnshire Peter was right. I put it off but finally took Mr Dremel saw to my canopy. The section I removed is 8mm long ! I have also chopped the ventral pod about and adapted canopies from the parts box Sorry for the fuzzy photo. Half the problem is getting the parts in position for the illustrative photos. The photo below is meant to show the tapering of the fuselage to meet narrower width of canopy 5 Link to comment Share on other sites More sharing options...
Pete in Lincs Posted August 10, 2020 Share Posted August 10, 2020 That looks more in proportion. A brave move, but it worked! Link to comment Share on other sites More sharing options...
Adrian Hills Posted August 10, 2020 Author Share Posted August 10, 2020 If I have any problems I’ll blame you (In reality, a big thanks, it was a good suggestion) 1 Link to comment Share on other sites More sharing options...
Arniec Posted August 10, 2020 Share Posted August 10, 2020 Great work! and it looks now more correct than the original. Also a brave move to put a saw in the canopie. Cheers, Link to comment Share on other sites More sharing options...
busnproplinerfan Posted August 10, 2020 Share Posted August 10, 2020 Love the psychedelic plastic. It is almost a shame to paint it just because of that and the ton of putty needed to make it all fit together. got to love the precesion engineering. Link to comment Share on other sites More sharing options...
Adrian Hills Posted August 10, 2020 Author Share Posted August 10, 2020 The coloured plastic is real fun to rub down - what was green on top reveals reddy brown the deeper into the surface one goes. 2 Link to comment Share on other sites More sharing options...
Mottlemaster Posted August 11, 2020 Share Posted August 11, 2020 It seems that the smallest scale has led to the largest amount of work . As said Brave . Link to comment Share on other sites More sharing options...
Adrian Hills Posted August 14, 2020 Author Share Posted August 14, 2020 Started messing around with the interior, filled in wing voids and made a back cockpit panel. Somehow I missed the photograph of the structure I put in for the dorsal gunner to sit on. Fuselage painted grey interior and glued together. Strapped with some kabuki tape and tail held firm with nipple clamps 4 Link to comment Share on other sites More sharing options...
Mottlemaster Posted August 15, 2020 Share Posted August 15, 2020 Adrian , how does a moden glue react with this early plastic ? Link to comment Share on other sites More sharing options...
Adrian Hills Posted August 15, 2020 Author Share Posted August 15, 2020 The glue reacts surprisingly well. I am using thin Revell Professional mini (blue with needle) and Tenax-7R (MEK). Superglue used for some filling jobs and today will try Tamiya putty and Milliput 1 Link to comment Share on other sites More sharing options...
Adrian Hills Posted August 15, 2020 Author Share Posted August 15, 2020 Wings now fitted. You can just see the structure I put under the dorsal hatch for the gunner to sit on. As you can see the fit is not like you get these days. Actually making a basic kit look half decent (ish) is what I really enjoy in modelling. Here you can also see the plate I put in as the rear bulkhead of the cockpit. 7 Link to comment Share on other sites More sharing options...
