Resin Tracks for Churchill and M4 Sherman Tanks - 1:72
Paul A H
1:72 OKB Grigorov
In this review we're looking at a couple of sets of OKB Grigorov's resin replacement tracks. As with the Panther turrets we reviewed a while ago, these don't appear to be intended for a particular base kit, so it'll be up to you to pick the appropriate model and address any fit and finish issues you find. The two sets we have here are both intended for tanks used by the Allies. The Churchill tracks represent the heavy cast steel variant, while the M4 Sherman tracks have added grousers (or cleats) for improved traction over rough surfaces. The tracks are well made, with sharp details and no flaws that I could see. Once removed from the pouring stubs, the tracks are fairly flexible but would probably still benefit from being warmed in hot water prior to fitting in order to improve flexibility.
Tracks for M4 family, T51 with grousers
Tracks for Churchill Tank, Heavy Cast Steel
Conclusion
I can't really fault either of these items from OKB Grigorov. The quality of production is very high indeed and they will provide additional options for modellers wanted to add detail to their small scale tanks. Recommended.
Review sample courtesy of
  • 2 years later...
