Roger Newsome Posted August 29, 2020 Share Posted August 29, 2020 24 minutes ago, Retired Bob said: I could just see that in my front garden. A couple of minutes walk and so could I. 🤣 1 Link to comment Share on other sites More sharing options...
Retired Bob Posted August 29, 2020 Author Share Posted August 29, 2020 10 minutes ago, Roger Newsome said: A couple of minutes walk and so could I. 🤣 Only if it has a small plaque "In memory of SWIMBO" 2 Link to comment Share on other sites More sharing options...
Retired Bob Posted September 8, 2020 Author Share Posted September 8, 2020 I finally have the wings attached to the fuselage, it put up a fight when fitting the left (port) wing, so the fuselage joint cracked apart as I tried to eliminate the gap on the wing root, nothing a bit of filler will sort out, As can be seen on the photo, the left engine nacelle was a much poorer fit than the right hand one, it needed some plastic card to shim out the gaps, then a lot of work with micro-chisels, files and sanding sticks to get it all cleaned up. Some more cleaning up before I can get the nose fitted. Thanks for looking. 2 Link to comment Share on other sites More sharing options...
Greg Law Posted September 8, 2020 Share Posted September 8, 2020 that is coming along nicely Bob. I had a similar thing happened to the Ju 88A-1 last night while I was asking up for the RLM70. I knocked the front canopy off. The Roket odorless glue in useless. Now i have to use Kristal clear which never makes a nice joint for me. Link to comment Share on other sites More sharing options...
Retired Bob Posted September 9, 2020 Author Share Posted September 9, 2020 19 hours ago, Greg Law said: I knocked the front canopy off. The Roket odorless glue in useless. Now i have to use Kristal clear which never makes a nice joint for me. It is always a problem getting the canopies glued strongly without risking smears or fogging, I use a similar canopy glue to Kristal clear. Having left my He 111 to set overnight I have filled my wing root gaps with some sprue gloop, hopefully it will give the wings some strength and clean up nicely, it just takes a while to harden. 1 Link to comment Share on other sites More sharing options...
nicholas mayhew Posted October 9, 2022 Share Posted October 9, 2022 @Retired Bob hi Rob, may I ask what scheme you are planning? I am looking for KG55 logos for a 1/32 Bf109 G (yes you read that correctly btw) He111 emblems are way too big but am thinking the 1/48 may be suitable (even though I would have to touch up the shield background colour to look vaguely yellow). Even if the KG55 machine is what you were planning, I wonder would you mind telling me the height and width at widest part of the decals in your kit? At least then I will know if I am on the right track. Cheers Nick Link to comment Share on other sites More sharing options...
