Jnunu Posted July 20, 2020 Share Posted July 20, 2020 Hi all. Will be venturing back into the hobby with a 1/35 Tamiya SD.KFZ.7/1. Would like to paint it as per box art - winter whitewash. I have no airbrush and little skill (first model in 30 + years). Any hints/tips/paint type recommendations gratefully received! Research so far is jammed with airbrush and hairspray Thanks Link to comment Share on other sites More sharing options...
nheather Posted July 20, 2020 Share Posted July 20, 2020 You could try using washable white camo paint like this one by Mig Ammo https://www.migjimenez.com/en/acrylic-colors/126-washable-white-camo-8432074000242.html There are bound to be similar products from other companies if you prefer. You would normally spray this stuff on but I reckon you could get by with a brush - the trick is that after it has dried this stuff can then be partially removed and smeared with water (like wet cotton buds). Cheers, Nigel 1 Link to comment Share on other sites More sharing options...
Jasper dog Posted July 21, 2020 Share Posted July 21, 2020 7 hours ago, Jnunu said: Hi all. Will be venturing back into the hobby with a 1/35 Tamiya SD.KFZ.7/1. Would like to paint it as per box art - winter whitewash. I have no airbrush and little skill (first model in 30 + years). Any hints/tips/paint type recommendations gratefully received! Research so far is jammed with airbrush and hairspray Thanks With a bit of practice I'd guess you could do it with a fairly hefty dry brushing. Base colour on and then draw the dry brush white wash down wards and perhaps stiple it on flat surfaces... Best bet, get something to practice on before committing it to the model. 1 1 Link to comment Share on other sites More sharing options...
Jnunu Posted July 21, 2020 Author Share Posted July 21, 2020 8 hours ago, nheather said: You could try using washable white camo paint like this one by Mig Ammo https://www.migjimenez.com/en/acrylic-colors/126-washable-white-camo-8432074000242.html There are bound to be similar products from other companies if you prefer. You would normally spray this stuff on but I reckon you could get by with a brush - the trick is that after it has dried this stuff can then be partially removed and smeared with water (like wet cotton buds). Cheers, Nigel Thanks Nigel. 1 hour ago, Jasper dog said: With a bit of practice I'd guess you could do it with a fairly hefty dry brushing. Base colour on and then draw the dry brush white wash down wards and perhaps stiple it on flat surfaces... Best bet, get something to practice on before committing it to the model. Thanks for the advice. Link to comment Share on other sites More sharing options...
Kingsman Posted July 21, 2020 Share Posted July 21, 2020 In the field it would have been roughly applied with whatever was available. There's a picture online that I now can't find of a Pz IV being whitewashed using rags wrapped round bundles of straw! So applying by brush on the model is perfectly fine. Spraying would give the wrong look anyway. The washable paint sounds like a winner to me. AK Interactive also offer a Washable Agent that you can add to any paint. Whether it works with other brands I don't know 1 Link to comment Share on other sites More sharing options...
nheather Posted July 21, 2020 Share Posted July 21, 2020 33 minutes ago, Das Abteilung said: In the field it would have been roughly applied with whatever was available. There's a picture online that I now can't find of a Pz IV being whitewashed using rags wrapped round bundles of straw! So applying by brush on the model is perfectly fine. Spraying would give the wrong look anyway. The washable paint sounds like a winner to me. AK Interactive also offer a Washable Agent that you can add to any paint. Whether it works with other brands I don't know Too true. Also the real whitewash was water-based so that it could be removed after winter, and as such wasn’t very durable so would weather quite quickly. Also its opacity was quite low so I imagined is was slopped on quite thickly to get coverage. I can imagine the response the commander would get from the crews if he went round saying “remember if you want a decent finish, use many light coats rather than one thick coat, that way you’ll get a nice even and smooth finish without any loss of detail” Cheers, Nigel 2 Link to comment Share on other sites More sharing options...
Jnunu Posted July 21, 2020 Author Share Posted July 21, 2020 7 hours ago, Das Abteilung said: In the field it would have been roughly applied with whatever was available. There's a picture online that I now can't find of a Pz IV being whitewashed using rags wrapped round bundles of straw! So applying by brush on the model is perfectly fine. Spraying would give the wrong look anyway. The washable paint sounds like a winner to me. AK Interactive also offer a Washable Agent that you can add to any paint. Whether it works with other brands I don't know Thanks for that. Link to comment Share on other sites More sharing options...
Ratch Posted July 21, 2020 Share Posted July 21, 2020 I brushed Humbrol Enamel Wash AV202 White on this You might want denser coverage 1 Link to comment Share on other sites More sharing options...
zigster Posted July 22, 2020 Share Posted July 22, 2020 I would say, if anything brush applied looks good, it should be a winter cammo. Start with a thin paint, then add more. Then scratch here and there. 1 Link to comment Share on other sites More sharing options...
Mick4350 Posted July 29, 2020 Share Posted July 29, 2020 And earlier in the war whitewash were applied by the German soldiers with large brushes and even brooms to apply the stuff in the field. 1 Link to comment Share on other sites More sharing options...
Soeren Posted July 29, 2020 Share Posted July 29, 2020 The approach taken here is good as well https://youtu.be/18SAX24X7vo 1 Link to comment Share on other sites More sharing options...
