GREG DESTEC Posted July 20, 2020 Share Posted July 20, 2020 Placeholder for the moment. Here is the venerable but still good (i think) He 111 H 6 from Italieri. One of my childhood favorites as it had the "right" upper turret on it. There are three options in the box two of which are torpedo carrying KG 26 machines. I quite fancy the sand coloured one but we'll see. I;m possibly doing it wheels up too. I haven't built a 111 for a long time so i'm looking forward to it. Cheers Greg 5 Link to comment Share on other sites More sharing options...
Arniec Posted July 20, 2020 Share Posted July 20, 2020 Great choice Greg, I have builded this many moons ago and I was quite fond of it. Have a great build. Cheers, 1 Link to comment Share on other sites More sharing options...
Mottlemaster Posted July 21, 2020 Share Posted July 21, 2020 HI Greg , I'm casting my vote for markings into the sand pit . Forgot, l ots of green blotches too . Cheers Alistair 1 Link to comment Share on other sites More sharing options...
Greg Law Posted July 21, 2020 Share Posted July 21, 2020 Good choice Greg. This 1H+FK is on my list too in 1/48 of cause. Just curious, why the wheels up. Personally I like the way the Heinkel sits on the ground. I built your kit back in the eighties. Good luck with it. 1 Link to comment Share on other sites More sharing options...
GREG DESTEC Posted July 22, 2020 Author Share Posted July 22, 2020 7 hours ago, Greg Law said: Good choice Greg. This 1H+FK is on my list too in 1/48 of cause. Just curious, why the wheels up. Personally I like the way the Heinkel sits on the ground. I built your kit back in the eighties. Good luck with it. Hi Greg, I had this idea that I could build it wheels up in flight dropping a torpedo. It would need a base with water effect on it too. But then again I'm always full.of ideas at the start of a project. I will see how it goes. I am also going to be doing builds on the BoB GB as well so it will depend on how much time I have to play with 3 Link to comment Share on other sites More sharing options...
John Posted July 25, 2020 Share Posted July 25, 2020 One of my all time favourite kits since I built my first one, which was in a Revell/Italeri box. The moulding of the various guns supplied is, or at least was, particularly fine and many MG15s especially have found their way into other projects. I think there are MG81s and a MG/FF as well? The only construction issue that springs to mind is that the wing roots are a bit shallow on the underside. I've seen it recommended that the roots are packed to increase the depth but I've always preferred to build up the exterior with a bit of Miliput. It's maybe not quite on a par with the new Airfix kits but definitely still a contender. John 2 Link to comment Share on other sites More sharing options...
GREG DESTEC Posted July 28, 2020 Author Share Posted July 28, 2020 On 7/26/2020 at 12:26 AM, John said: One of my all time favourite kits since I built my first one, which was in a Revell/Italeri box. The moulding of the various guns supplied is, or at least was, particularly fine and many MG15s especially have found their way into other projects. I think there are MG81s and a MG/FF as well? The only construction issue that springs to mind is that the wing roots are a bit shallow on the underside. I've seen it recommended that the roots are packed to increase the depth but I've always preferred to build up the exterior with a bit of Miliput. It's maybe not quite on a par with the new Airfix kits but definitely still a contender. John Hi John, Yes there are alternative weapons provided, which are nicely molded. I have made a start on mine, and have the fuselage and wings assembled. Fit at the wing roots is a bit off but I will play around with it before committing glue to secure the wings to the fuselage. I am currently attempting to rescribe the raised panel.lines. I will post a couple of progress shots shortly. Cheers Greg 2 Link to comment Share on other sites More sharing options...
PlaStix Posted July 28, 2020 Share Posted July 28, 2020 Hi Greg. Looking forward to seeing this in progress. Kind regards, Stix 1 Link to comment Share on other sites More sharing options...
GREG DESTEC Posted July 28, 2020 Author Share Posted July 28, 2020 1 hour ago, PlaStix said: Hi Greg. Looking forward to seeing this in progress. Kind regards, Stix Thanks Stix It's a very straightforward kit and has been trouble free so far 1 Link to comment Share on other sites More sharing options...
Mottlemaster Posted July 28, 2020 Share Posted July 28, 2020 Like Stix ,im looking forward to the pics and to see the results of your panel line work. Cheers Alistair 1 Link to comment Share on other sites More sharing options...
Planebuilder62 Posted July 28, 2020 Share Posted July 28, 2020 Hi Greg I have made a start on mine as well. I took out the big guns - grade 120 sandpaper to the wing roots so they are flush with the wing undersides. Only a small amount of filler is needed in the gap. regards Toby 1 Link to comment Share on other sites More sharing options...
GREG DESTEC Posted July 28, 2020 Author Share Posted July 28, 2020 1 hour ago, Planebuilder62 said: Hi Greg I have made a start on mine as well. I took out the big guns - grade 120 sandpaper to the wing roots so they are flush with the wing undersides. Only a small amount of filler is needed in the gap. regards Toby Thanks Toby, I will best it in mind when I am attaching mine All the best Greg 1 Link to comment Share on other sites More sharing options...
GREG DESTEC Posted August 2, 2020 Author Share Posted August 2, 2020 Hi Folks! Here is some progress to report. As mentioned in my earlier update i have been busy rescribing the main assemblies. This has been time consuming but i think makes for a better looking surface for the model. The raised panel lines were quite prominent and i used a scriber freehand, simply running the pin along the raised line until a groove was formed then applying more pressure to deepen the panel line. Some of these are maybe a bit too deep but not of Matchbox proportions. I then added the wings to the fuselage and the tail planes. If you look at the head on shot you may see things look a bit off. I think either the tail rudder is warped or the left wing (as you look at the photo) is too high. The wings on the upper wing roots had a reasonable fit although i did apply filler all around the joins to try and hide the seam. Theres still some clean up required al over but overall i am quite happy with what i have done so far. TFL Cheers Greg 6 Link to comment Share on other sites More sharing options...
Greg Law Posted August 2, 2020 Share Posted August 2, 2020 Looks like a twisted fuselage. I had this on my Val. In the end I didn't really notice it. 1 Link to comment Share on other sites More sharing options...
GREG DESTEC Posted August 2, 2020 Author Share Posted August 2, 2020 18 minutes ago, Greg Law said: Looks like a twisted fuselage. I had this on my Val. In the end I didn't really notice it. Thanks Greg I'm hoping that will be the case Link to comment Share on other sites More sharing options...
Mottlemaster Posted August 2, 2020 Share Posted August 2, 2020 Just an idea Greg .Howabout cutting off the tail along the panel line just before tail and with a very small twist of the tail clockwise and some light sanding its all sorted . Disclaimer .This idea may just be a load of B**locks with no chance of working . Cheers Alistair 1 2 Link to comment Share on other sites More sharing options...
Arniec Posted August 2, 2020 Share Posted August 2, 2020 Great job Greg. I like wat you did with the rescribing. It is a Pitty that the fuselage is a bit warped, but I know that moder models have this problem. I think it hase to do with the shape of the fuselage. I can remember that I had the same problem with a 1/48 revell kit a few years back. Cheers, 1 Link to comment Share on other sites More sharing options...
Planebuilder62 Posted August 2, 2020 Share Posted August 2, 2020 I had to cut the fin off my Airfix Concorde to get it right so skewed fins are quite common. regards Toby 1 Link to comment Share on other sites More sharing options...
Graham Boak Posted August 2, 2020 Share Posted August 2, 2020 I think that your starboard wing appears to have excessive dihedral, so I suggest you check that before committing to drastic surgery. 1 Link to comment Share on other sites More sharing options...
GREG DESTEC Posted August 2, 2020 Author Share Posted August 2, 2020 Thanks for your comments guys. I'll give it some thought before going any further. Cheers Greg Link to comment Share on other sites More sharing options...
Planebuilder62 Posted August 2, 2020 Share Posted August 2, 2020 Dear Greg On checking my Italeri He111 I think the fin is OK. The problem is with the wing roots. I suggest that both wings are removed, the inboard wing section leading edge should be horizontal. I think there is a moulding problem with the wing lower surface edges being too deep. This pushes up the dihedral. Good luck if you try this drastic surgery Greg. regards Toby 1 Link to comment Share on other sites More sharing options...
GREG DESTEC Posted August 2, 2020 Author Share Posted August 2, 2020 56 minutes ago, Planebuilder62 said: Dear Greg On checking my Italeri He111 I think the fin is OK. The problem is with the wing roots. I suggest that both wings are removed, the inboard wing section leading edge should be horizontal. I think there is a moulding problem with the wing lower surface edges being too deep. This pushes up the dihedral. Good luck if you try this drastic surgery Greg. regards Toby Yikes!! So you reckon I should remove both wings and fit a shim? I dunno if I'm up to that but I'll give it some thought.... Link to comment Share on other sites More sharing options...
Planebuilder62 Posted August 3, 2020 Share Posted August 3, 2020 Not quite Greg. Off with the wings with a sharp knife and then trim back the lower wing inboard edge. No shim needed at the top surface. If liquid cement like Tamiya was used, brush some on the join first to disolve the original glue. Regards Toby 2 1 Link to comment Share on other sites More sharing options...
GREG DESTEC Posted August 5, 2020 Author Share Posted August 5, 2020 Right, having looked at it - AGAIN - i am hoping i can fix this by just doing the left wing. So far i have taken it off with no damage to the rest of the model and looking at it from the front the other wing and the tail look ok. So next is reattaching the wing at the correct angle....... Cheers Greg 4 Link to comment Share on other sites More sharing options...
PlaStix Posted August 5, 2020 Share Posted August 5, 2020 Hi Greg. Hope you are well. Hope you manage to get the wing sorted and re-attached okay. Kind regards, Stix 1 Link to comment Share on other sites More sharing options...
