Dragon 1/48 Ju 188A-1
This is my Dragon 1/48 Ju 188A-1 I built in the Journeys End GB.
This was a good build without too many issues. Of cause the squiggles weren't easy to do and are only my own pattern, as the real one is beyond my skill to get totally correct.
The Eduard PE was used where I felt necessary and the two main guns are masters barrels.
The code letters are home made using an inkjet printer. I may replace these later as there is an Aims Decal sheet that covers this plane.
The white aircaft number on the tail was left off for now as small white letters isn't some you can do on an inkjet printer. I will add these when I get the commercial set.
The wheels are Resin.
No that isn't a split wing. Looks like I need to touchup the leading edge. I only saw that when I put these images up.
Ju 188 Finish image7  Ju 188 Finish image5 Ju 188 Finish image4
Ju 188 Finish image3
Ju 188 Finish image2
Ju 188 Finish image1
  • Like 35
