RobL Posted July 17, 2020 Share Posted July 17, 2020 (edited) Hey all One of the projects I've started recently has balsa wood on it (and will get some more attached to it). I'm wondering how best to go about painting some of it though. For the most part I believe I can just slap black/dark coloured paint on and drybrush it. However there are going to be some parts, made from thin sheet balsa that I want to use the wood grain to my advantage, to achieve a more grey/worn/weathered wood look, although the grain seems to be a little indistinct. Can I get away with airbrushing paint onto balsa wood or should I use a hairy stick? Should I thin the paint to be more like an ink wash? Anyone here with experience with working with balsa wood able to offer some advice on this? Thanks in advance. Edited July 17, 2020 by RobL 1 Link to comment Share on other sites More sharing options...
Rick Brown Posted July 17, 2020 Share Posted July 17, 2020 I personally haven't used balsa for years, but in the old days I used cellulose dope to seal it before painting with hairy stick/Airbrush. The dope was used because tissue paper was attached to it (RC gliders). Based on that, I'd seal it first with some sort of varnish maybe? Balsa soaks up stuff very easily. Watching with interest, as I've a Balsa Chipmunk to do soonish. HTH, Rick. Link to comment Share on other sites More sharing options...
Max Headroom Posted July 17, 2020 Share Posted July 17, 2020 Balsa is porous and needs sealing. Alan ‘balsawood’ Hall used a combination of dope and talc to seal it. This could then be sanded and primed. Trevor 4 1 Link to comment Share on other sites More sharing options...
Tzulscha Posted July 17, 2020 Share Posted July 17, 2020 If you're looking for scale wood you might consider Basswood, Limewood or Linden (or whatever you call it over there). Balsa is quite coarse grained and doesn't look very scale without extra effort. Link to comment Share on other sites More sharing options...
NigelD Posted July 18, 2020 Share Posted July 18, 2020 Back in my youth, many years ago, i remember using something called sanding sealer on balsa. It raised the grain so sanding was necessary but it gave a beautifully smooth and sealed surface. 2 Link to comment Share on other sites More sharing options...
Rick Brown Posted July 18, 2020 Share Posted July 18, 2020 31 minutes ago, NigelD said: Back in my youth, many years ago, i remember using something called sanding sealer on balsa. It raised the grain so sanding was necessary but it gave a beautifully smooth and sealed surface. Yep, I remember that. I used it quite a bit when young for doing school projects. Can you still get it? Rick. Link to comment Share on other sites More sharing options...
Mike Posted July 18, 2020 Share Posted July 18, 2020 40 minutes ago, NigelD said: Back in my youth, many years ago, i remember using something called sanding sealer on balsa. It raised the grain so sanding was necessary but it gave a beautifully smooth and sealed surface. I remember sanding sealer too. Its probably still available, as it was widely used to stop up grain in furniture etc as well as in modelling. Link to comment Share on other sites More sharing options...
Jamie @ Sovereign Hobbies Posted July 24, 2020 Share Posted July 24, 2020 I have quite a bit of R/C background and agree with the above - it needs sealed. Paint onto unsealed balsa will just make the grain swell out. 1 Link to comment Share on other sites More sharing options...
