1/48 Fieseler Fi 156C-3 trop, Tamiya+Eduard
Outstanding paint work Fuad - very very neat indeed. How was this done - freehand?
Malcolm
21 minutes ago, ForestFan said:
That camouflage is superb, what’s the secret?
There is no secret. I used an empty 0.7 mm marker. Filled it with paint Mr.Color 119 RLM79 Sand Gelb.
Edited by Fuad
  • Like 10
  • Thanks 4
To the attention of those who will build this variant. Tamiya used a completely wrong color scheme. In fact, this aircraft was painted according to the standard RLM 70/71/65 scheme. Then on top were the so-called "Wellenmüster" from RLM79.
Furthermore, the fixing struts of construction and fuel lines have been added to the cabin.
Edited by Fuad
24 minutes ago, Enrywar67 said:
Wow!Fabulastic model!Great Idea the marker......do you think a rapidograph shoul be work??
Need to try. An empty marker works for sure.
Thanks Fuad - actually I saw a rather nice Bf 110 at a show earlier in the year and the modeller had used a similar technique though he was able to find an appropriately coloured marker. It looks great! Will give it a try some time.
Malcolm
Hi Fuad,
gorgeous result as always 👍 Many thanks for your tip with the empty marker. Never thought about it but makes sense and I will certainly try this in the future!
Markus
Great result and love that tip. Interesting info on the camouflage inaccuracies - I had no idea. Thanks for sharing and posting this most excellent Storch!
Faud, can I ask how much you have to thin the paint when using a marker?
Thanks
Thanks
If you use exactly the marker that I indicated in the link, then you can use a fairly thick mixture of paint and solvent. The marker will work - don't be afraid.
