Julien Posted July 14, 2020 Share Posted July 14, 2020 SF-37E Viggen "Swedish Eyes" (SH72390) 1:72 Special Hobby The Viggen is a rugged fighter/interceptor that was designed to fulfil a need during the deep Cold War to defend Swedish airspace in the event of an incursion by the Soviet Bloc, and to continue the fight from hidden bases near roadways, which the aircraft could use as makeshift landing strips. It was to replace both the Lansen and Draken, and did so extremely well, endearing itself to aviation enthusiasts as it did so due to its unusual double-delta/canard configuration. It was fitted with a single Volvo license built P&W JT8D with an afterburner to give it the performance needed to propel this large aircraft fast enough to accomplish short take-offs. Short landings were made possible by the inclusion of a set of large thrust reversing petals that dropped into the exhaust trunking and expelled the gases forward from slots in the side of the fuselage. The initial AJ37 variant was declared operational in 1972, and required the addition of a trainer variant, dubbed the SK37, which had an additional cockpit placed high above the original, displacing some fuel tankage in the process. The final JA37 variant was brought into service in 1980 with new computer systems, improved radar and engine, as well as other systems and the strength of the airframe, which already utilised titanium to reduce weight. The FS version (Spaning Foto) replaced the radar with cameras in the nose. Additional provision was made for recce pods. They were introduced in 1973 with 28 aircraft being built. They were later upgraded to AJSF-37 beofre being decomissioned in 1998. This means the Swedish Air Force lost a dedicated Photo Recon Asset at this time. The last of the operational Viggens (Thunderbolt) were retired in 2005, replaced by the impressive JAS39 Gripen (Griffon). A number of Viggens are on display in museums – notably Newark in the UK, but the Swedes have retained one in flying condition that can sometimes be seen at British airshows along with a Draken, Lansen and even the Tunnan. If only every country was conscientious in preservation of its aviation history. The Kit The main tooling that this kit originated from is the collaborative effort between Special Hobby and Tarangus in 2018, which has been re-issued a few times over the past two years . This is the first major additional tooling from them, and thanks to their efforts, we now have decent Viggens available. This is the first SF boxing from Special Hobby. In the box you get seven sprues of grey styrene, one of clear parts, a small resin part, a sheet of decals and a glossy colour printed instruction booklet with integrated colour and markings guide at the rear. The tooling is one of the best I have seen in 1/72 there is plenty of detail with well defined but not overly deep panel lines. The only negative part on the tooling are sink marks on the top of the flaps due to the moulded on flap actuators on the underside of the mouldiing. These will be easily filled though, or can be shaded in for weathering back from the flap hinges. It should be noted that while this boxing shares many parts from other boxing of the Viggen only the recce nose is included in the kit so other versions are not possible (as some modellers get really upset over this). Construction starts shockingly enough in the cockpit. The four part ejection seat is built up followed by the cockpit tub. Instrument panel, rudder pedals, control column, and throttles are all added, the tub can then be placed inside the upper front fuselage; the ejection seat is then added in from the top. We then move to the lower front fuselage. Here the aperture for the side looking camera is cut out (dont worry its well marked on the parts), and camera parts can then be added. Next the housing for the APU is built in. The front gear well as well can be glued in at this point. The upper and lower front fuselages can then be joined together around the full length intake trunking. The engine face is then put on the back of the intake trunking thus finishing this part of the build. Next up is the rear fuselage. and wings. First off the upper and lower wings are joined together. Above this the engine exhaust and the Viggen's unique thrust reverser are assembled and placed inside the two part (left & right) upper rear fuselage parts. These in effect only form the top two thirds of the read fuselage as they then join to the top of the main wing assembly. Its worth noting the thrust reverser can be modelled open or closed. The front and rear fuselage sections can then be joined. At the front the recce nose is made up and added with all the camera windows in clear parts. There are no cameras supplied for the nose so its either a case of scratch building or just giving the inside a coat of matt black. Once the nose is on the rather nice one part engine intakes are added. Towards the rear the vertical tail is put on. Various antenna, intakes and fairings are then added to both the upper and lower surfaces of the Viggen. On the underside the undercarriage is then built up and installed with the aircraft's unique twin tandem main wheels going into wells which are on the indie of the main wing parts. The main gear doors are added. Flipping back to the top the front control canards go on. We then flip back to the underside for the air brakes, To finish of the centre line fuel tank is added followed by the clear parts. Markings The glossy decal sheet is printed by Eduard and looks sharp and in register. There are three decal options available from the decal sheet, which are split between grey, splinter camouflage., and a special scheme. SF-37 Viggen 37950/21-48 1st Division, Wing F21 based at Lulea. Featuring a large wolfs head with the Lappish wording for Lonely Wolf on the aircraft. SF-37 Viggen 37960/10-52 1st Division, Wing F10, based at Angleholm. In the famous splinter camo with rare large whit %" on the upper sings. SF-37 Viggen 37957/21-56 1st Division Wing F21 based at Lulea. In the later 2 tone grey scheme. This aircraft was retired to the Czech Air Force Museum Kbely. The easy option is the grey ones, but the most impressive the splinter pattern; the special scheme will require some skill as the blue fades out toward the front. Conclusion The Viggen is a huge, impressive-looking Cold War warrior that has the unique Swedish look to it Detail is good, with excellent decals into the bargain makes this a must-have as far as I'm concerned. If you like Viggens then make sure you get one. Very highly recommended. Review sample courtesy of 12 1 Link to comment Share on other sites More sharing options...
swralph Posted December 8, 2020 Share Posted December 8, 2020 Great review Julien. Just bought this kit because of it. 2 Link to comment Share on other sites More sharing options...
Paramedic Posted December 14, 2020 Share Posted December 14, 2020 Looks like the camera sight looks better in 7nd scale than the resin one they put into the 48th one, afterwards.. lol.. Nice kit though. Link to comment Share on other sites More sharing options...
Team Aer Lingus Posted December 15, 2020 Share Posted December 15, 2020 Great review its such a beautiful looking model I went and bought one looking forward to having a crack at making a decent attempt unlike the one I build as a kid Eamonn 1 Link to comment Share on other sites More sharing options...
Paramedic Posted December 17, 2020 Share Posted December 17, 2020 On 12/15/2020 at 1:11 PM, Team Aer Lingus said: Great review its such a beautiful looking model I went and bought one looking forward to having a crack at making a decent attempt unlike the one I build as a kid Eamonn I´m not the biggest expert but I do know some stuff.. You can always ask me if you need help though. or visit IPMS Gothenburg 8Göteborg) or Stockholm. Viggen is my main aircraft interest so.. ^^ 1 Link to comment Share on other sites More sharing options...
