cherisy Posted July 14, 2020 Share Posted July 14, 2020 Hi I have an Airfix B2 Bluesteel as my next project. My question is this: As it is a large beast I intend to use a rattle can spray paint as I normally brush paint. Which is the best to use? I had heard that Halfords white was a contender. Any advice or pointers would be gratefully received. Thanks in advance Lee Link to comment Share on other sites More sharing options...
wavodavo Posted July 14, 2020 Share Posted July 14, 2020 Yep, Halfords Appliance White - very good. It can also be decanted for airbrush too. 1 Link to comment Share on other sites More sharing options...
Flankerman Posted July 14, 2020 Share Posted July 14, 2020 I'd use Halford's Appliance White' - over a few misted on coats of Halford's White Plastic Primer - with great success. The primer was applied - and then gently sanded down to an eggshell finish before the Appliance White top coat. Appliance White straight onto grey plastic needs care to get a nice dense coverage - hence the use of the primer first to give it something to 'key' to. A good trick is to warm the rattle can in hot tap water before use - and test it on some scrap plastic first - I've encountered 'rogue' cans of White Plastic Primer that spattered on me. Oh! - and shake (rattle) the can after warming it for a good ten minutes before use. Hope This Helps Ken 1 2 Link to comment Share on other sites More sharing options...
Space Ranger Posted July 14, 2020 Share Posted July 14, 2020 I'd probably use Tamiya Fine Surface Primer (white), decanted for airbrush use. Then, once it's cured, buff it to a smooth satin finish, and, if needed, spray a second coat of Humbrol Satin White prior to applying decals. 1 Link to comment Share on other sites More sharing options...
cherisy Posted July 15, 2020 Author Share Posted July 15, 2020 Thanks guys. Halford appliance white with primer it is . Link to comment Share on other sites More sharing options...
neilfergylee Posted July 17, 2020 Share Posted July 17, 2020 (edited) May I just raise a small wave for Humbrol rattlecan matt white? Great coverage, consistent and a good reliable finish. The off-white dielectric parts were airbrushed Vallejo airframe white. Cheers, Neil Edited July 17, 2020 by neilfergylee spilling orrer 1 Link to comment Share on other sites More sharing options...
