Folkbox1 Posted July 9, 2020 Share Posted July 9, 2020 I'm building a 1:1 working scale model 😊 ukulele from a kit.  been thinking that automotive paint from a rattle can from halfords might give a hard wearing finish. Back, sides and back only.   I have wood primer, water based will the halfords paint work ok on this combination of wood, primer and automotive paint Link to comment Share on other sites More sharing options...
Rick Brown Posted July 9, 2020 Share Posted July 9, 2020 I was pondering the same for a Base from a kit too ;-). I reckon it'd be ok. I think a thin coat first and a good smoothing over with a sanding pad, then a few coats of their normal rattle cans should produce a pretty tough paint job.  HTH, Rick. Link to comment Share on other sites More sharing options...
bentwaters81tfw Posted July 9, 2020 Share Posted July 9, 2020 Used Halfords onto MDF. Grey primer and Gloss black. It's a bit thirsty, so needs a few coats, then clear lacquer. Link to comment Share on other sites More sharing options...
Black Knight Posted July 9, 2020 Share Posted July 9, 2020 Before over painting any wood, including MDF, give it a coat of two of thinned PVA glue. I use the cheap PVA out of Poundland thinned with 'Astonish' floor 'polish' (an acrylic varnish) which makes it waterproof when dry 1 Link to comment Share on other sites More sharing options...
Folkbox1 Posted July 9, 2020 Author Share Posted July 9, 2020 Thanks all 😊 Link to comment Share on other sites More sharing options...
bentwaters81tfw Posted July 9, 2020 Share Posted July 9, 2020 1 hour ago, Black Knight said: Before over painting any wood, including MDF, give it a coat of two of thinned PVA glue. I use the cheap PVA out of Poundland thinned with 'Astonish' floor 'polish' (an acrylic varnish) which makes it waterproof when dry Ah yes, forgot to say I gave it a coat of PVA before starting. 2 Link to comment Share on other sites More sharing options...
Rick Brown Posted July 9, 2020 Share Posted July 9, 2020 2 hours ago, Black Knight said: Before over painting any wood, including MDF, give it a coat of two of thinned PVA glue. I use the cheap PVA out of Poundland thinned with 'Astonish' floor 'polish' (an acrylic varnish) which makes it waterproof when dry I also forgot that bit too! Oops. Rick. Link to comment Share on other sites More sharing options...
