My latest completed....
Well I did actually finish this a couple of weeks ago but I'm terrible at pointing the camera at my models for some reason. Good at pointing the camera at real planes whenever I see them, funny that!
German Air Force Alpha Jet 41+39 JBG43 NATO Tiger Meet - Kleine Brogel 1985
This is the Fujimi 1/72 kit. It has some nicely represented panel lines but in other areas comparable to old Matchbox kits. Extremely basic cockpit & very thick clear one piece canopy.
I did have a Pavla vacform canopy intended for the Heller kit but in the end decided to use the kit canopy & took the razor saw to it & cut it up into sections.
As I needed to reinforce where the canopies are attached, I drilled & attached brass rod to represent the telescopic canopy rams, this made for a secure support and attachment.
I added side consoles from scrap plastic & used Pavla MBB Stencel ejection seats.
The only thing I should have addressed was the arrestor hook which looks like a walking stick attached to the rear end, which I might sort out at a later date when I can be bothered!
For decals I used a HaHen decal sheet (Thanks Harald if you're looking!) which provided the cockpit decals & fitted nicely.
His German Air Force Alpha Jet decal sheet had everything I needed for this particular airframe which attended the 1985 Tiger Meet at Kleine Brogel.
Photographic reference from; "The 25th Anniversary NATO Tiger Meet" Coen Van Den Heuvel & Jac Van Tuyn Osprey/Motorbooks International
An obligatory Master brass pitot was used as well as some brass tubing for the Mauser gun.
All paints used were from the Hataka paint range, Mig PLW wash & Xtracrylic matt.
Thanks for looking
  • Like 46
Beautifully painted, beautifully detailed and a gorgeous clean look. That's one great model!
Cheers SAT69, very much appreciated thanks!
Martin
I like your Alpha Jet much, not just you used the Oldenburger markings of the JaboG 43, but also your paint work is very nice, even i like more used worn look, but a Alpha Jet is rarely to see in model forums, thats why your work is top notch.
How i wish the kit manufacturers make a new Alpha Jet in 1:48 or 1:32, its still my dream
Edited by Harry Callahan
I really like your kit of the lovely little Alpha jet. The finish is so good and I do like the German camo scheme. Thanks for sharing.
Edited by tim d
I've always liked the Alpha Jet and that is as good a build as it gets, nicely done.
27 minutes ago, Vultures1 said:
That's a superb result from the old Fujimi kit.  Very nice work!
Cheers mate!
The Fujimi kit isn't too bad considering its vintage.
9 hours ago, F-32 said:
Wow that is a gorgeous build :clap:
Thank you! 😊
Cheers! 😊
13 hours ago, stevej60 said:
A stunning example of a poorly served aircraft in kit form,beautiful paintwork too.
Many thanks stevej60 much appreciated.
I think it's the best on offer, but I reckon good things could be made of the Heller kit as well.
13 hours ago, ForestFan said:
Lovely job on a decades old kit. A new tool kit is long overdue I would say. Well done
Cheers mate, must be well over thirty years old I reckon! 😊
1 minute ago, Courageous said:
Not bad Martin, not bad at all. Nice bit of picture taking too...mobile again?
Stuart
Cheers Stuart, yes using the trusty mobile.
3 hours ago, Doc72 said:
A beautiful "Luftmoped"! Well done!
Excellent, like that knickname! Is that what they were known as?
Cheers!
Martin
Cheers!
Martin
Yes, I think so. Basically many small aircraft are occasionally nicknamed this way, but in the context of the post-war Luftwaffe, the Luftmoped ("aerial moped") is an Alpha Jet. Its predecessor, the G.91, was even smaller, nevertheless it was given the more flattering name Gina.
Hello L2000,
As mentioned above, I was very impressed with the overal outcome of this model from Fujimi.
I had to recheck the scale, to make sure it was not 1/48 scale.
The "real" aircraft has one of the best trackrecords in aviation.
Regards, Orion.
